Axis Position Logger
25 Feb 2024 14:13 #294364
linuxcnc.org/docs/html/code/building-linuxcnc.html
Replied by Aciera on topic Axis Position Logger
If you mean to modify the source code then you would need to do run-in-place installation and build linuxcnc on your local PC.Can someone explain to me how to edit this project or create something similar?
- Thank you received: 5945
25 Feb 2024 14:45 #294369
Replied by tommylight on topic Axis Position Logger
Position logger is a separate project by JT, so i do not know/think building LinuxCNC would help.
The issue is with old python used by it, so editing it to use python3 should be enough, although no idea how much work would that entail.
25 Feb 2024 15:54 #294390
Ah yes thanks, sometimes I get confused going from one thread to another.
25 Feb 2024 16:26 - 25 Feb 2024 17:22 #294394
So, to get the source you would download the .deb folder using the wget command as described here:
jethornton.github.io/emclog/install.html
Then right click on the downloaded 'emclog_1.0.0_all.deb' and choose 'Extract Here'
In the extracted folder extract the folder 'data.tar.xz'
You will find the pyhton file 'emclog' in the extracted 'usr/bin' folder.
This file you will need to update to python3.
[edit]
You will also need the gui file 'emclog.ui' from the folder 'emclog_1.0.0_all/usr/lib/python3/dist-packages/libemclog'
[edit2]
Just found the GitHub page for these two files:
github.com/jethornton/emclog/blob/master/emclog/src/emclog.ui
[edit]
[edit2]
Last edit: 25 Feb 2024 17:22 by Aciera.
25 Feb 2024 16:58 #294402
by Ehsan_R
Replied by Ehsan_R on topic Axis Position Logger
Hello
I am very new to Python programming
Would it be possible for you to give me a more complete explanation of how you did what you did or send me the files you edited?
forum.linuxcnc.org/21-axis/30986-axis-po...gger?start=30#247082
25 Feb 2024 17:14 - 25 Feb 2024 17:17 #294406
by Ehsan_R
[edit]
I applied these changes
How do I create the installable file after that?
[edit]
Last edit: 25 Feb 2024 17:17 by Ehsan_R.
25 Feb 2024 17:25 #294409
you can run it from a terminal with (make sure the file 'emclog.py' is marked as executable):
$ python3 <your_path_here>/emclog.py
The following user(s) said Thank You: Ehsan_R
25 Feb 2024 17:47 #294414
by Ehsan_R
I changed these program lines like thisI got this error
How do I fix it?
#!/usr/bin/python3
import os, sys, math
if sys.version_info[0] > 3:
raise Exception("Python 3 is required.")
ehsan@debian:~/Desktop$ python3 emclog.py
File "/home/ehsan/Desktop/emclog.py", line 16, in <module>
IN_AXIS = os.environ.has_key("AXIS_PROGRESS_BAR")
AttributeError: '_Environ' object has no attribute 'has_key'
How do I fix it?
25 Feb 2024 17:52 #294415
Just a few things to get you started, I copied 'emclog.ui' into my home directory and I got the gui started with the following code (start Linuxcnc first):
#! /usr/bin/python3
import configparser
import linuxcnc
from PyQt5 import uic
from PyQt5.QtWidgets import (QApplication, QMainWindow, QCheckBox, QRadioButton,
QMessageBox, QFileDialog, QMenu)
from PyQt5.QtCore import Qt, QTimer, QEvent
IN_AXIS = os.environ["LINUXCNCVERSION"]
if os.path.split(os.environ.get("PYTHONPATH")) == '/usr/bin':
GUI_PATH = '/home/user'
print('Installed')
else:
print (os.path.split(os.environ.get("PYTHONPATH")))
class MainWindow(QMainWindow):
def __init__(self):
super(MainWindow, self).__init__()
self.s = linuxcnc.stat() # create a connection to the status channel
try: # make sure linuxcnc is running
self.s.poll()
except linuxcnc.error:
msg = QMessageBox()
msg.setIcon(QMessageBox.Critical)
msg.setWindowTitle('Error')
msg.setText('LinuxCNC is not running')
msg.setInformativeText('Start LinuxCNC first.')
msg.setStandardButtons(QMessageBox.Ok)
msg.exec_()
exit()
projectPath = os.path.abspath(os.path.dirname(sys.argv[0]))
uic.loadUi(os.path.join(GUI_PATH, 'emclog.ui'), self)
self.qclip = QApplication.clipboard()
self.gcodeLW.installEventFilter(self)
self.axes = [(i) for i in range(9)if self.s.axis_mask & (1<<i)]
self.setupConnections()
self.timer = QTimer()
self.timer.timeout.connect(self.update)
self.timer.start(100)
self.recordTimer = QTimer()
self.recordTimer.timeout.connect(self.log)
self.lastPosition = []
self.dinLog = False
self.dinInput = self.dioSB.value()
self.pref_path = os.path.join(os.path.expanduser("~"), '.emclog_preferences')
self.config = configparser.SafeConfigParser()
self.setupGUI()
self.show()
def eventFilter(self, source, event):
if (event.type() == QEvent.ContextMenu and
source is self.gcodeLW):
contextMenu = QMenu()
deleteLine = contextMenu.addAction('Delete Line')
action = contextMenu.exec_(self.mapToGlobal(event.pos()))
if action == deleteLine:
self.gcodeLW.takeItem(self.gcodeLW.currentRow())
return True
return super(MainWindow, self).eventFilter(source, event)
def setupConnections(self):
self.actionOpen.triggered.connect(self.OpenFile)
self.actionSave.triggered.connect(self.SaveFile)
self.actionSave_As.triggered.connect(self.SaveFileAs)
self.actionSavePreferences.triggered.connect(self.SavePreferences)
self.actionExit.triggered.connect(self.exit)
self.logPB.clicked.connect(self.log)
self.addExtraPB.clicked.connect(self.addExtra)
if IN_AXIS:
self.sendToAxisPB.setEnabled(True)
self.sendToAxisPB.clicked.connect(self.sendToAxis)
self.actionCopy.triggered.connect(self.copy)
self.startPB.clicked.connect(self.record)
self.stopPB.clicked.connect(self.record)
self.dioSB.valueChanged.connect(self.changeInput)
def changeInput(self):
def OpenFile(self):
if os.path.isdir(os.path.expanduser('~/linuxcnc/nc_files')):
configsDir = os.path.expanduser('~/linuxcnc/nc_files')
else:
configsDir = os.path.expanduser('~/')
fileName = QFileDialog.getOpenFileName(self,
caption="Select a G code File",
directory=configsDir,
filter='*.ngc',
options=QFileDialog.DontUseNativeDialog,)
if fileName:
self.gcodeLW.clear()
with open(fileName[0], 'r') as f:
for line in f:
self.gcodeLW.addItem(line.strip('\n'))
iniFile = (fileName[0])
print(fileName[0])
with open(fileName[0]) as f:
text = f.read()
self.gCodeViewer.insertPlainText(text)
def SaveFile(self):
else:
fileName, _ = QFileDialog.getSaveFileName(self,
caption="Save G Code",
options=QFileDialog.DontUseNativeDialog)
if fileName:
gcode = '\n'.join(self.gcodeLW.item(i).text() for i in range(self.gcodeLW.count()))
with open(fileName, 'w') as f:
f.write(gcode)
def SaveFileAs(self):
self.SaveFile()
# lets create that config file for next time...
cfgfile = open("c:\\next.ini",'w')
# add the settings to the structure of the file, and lets write it out...
Config.add_section('Person')
Config.set('Person','HasEyes',True)
Config.set('Person','Age', 50)
Config.write(cfgfile)
cfgfile.close()
def SavePreferences(self):
if not os.path.exists(self.pref_path):
self.config.add_section('MAIN')
self.config.set('MAIN','dio', str(self.dioSB.value()))
with open(self.pref_path, 'w') as cfgfile:
self.config.write(cfgfile)
# f.write(str(self.dioSB.value()))
def setupGUI(self):
self.positionCB.addItem('Relative', 'relative')
self.positionCB.addItem('Absolute', 'absolute')
# check axes that are and disable axes that are not
for i in range(9):
getattr(self, 'axisCB_' + str(i)).setChecked(i in self.axes)
if os.path.exists(self.pref_path):
self.config.read(self.pref_path)
self.dioSB.setValue(self.config.getint('MAIN', 'dio'))
def record(self):
if self.startPB.isChecked():
print('Starting {}'.format(self.intervalSB.value()))
timerInterval = self.intervalSB.value() * 1000
self.recordTimer.start(timerInterval)
elif self.stopPB.isChecked():
print('Stopping')
self.recordTimer.stop()
def log(self):
axes = []
for checkbox in self.axesGB.findChildren(QCheckBox): # get axes list
if checkbox.isChecked():
axes.insert(0, str(checkbox.objectName()[-1]))
gcode = []
currentPosition = []
for radio in self.moveGB.findChildren(QRadioButton):
if radio.isChecked(): # add the move type
gcode.append(str(radio.property('gcode')) + ' ')
moveType = str(radio.property('gcode'))
for axis in axes: # add each axis position
axisLetter = str(getattr(self, 'axisCB_' + axis).property('axis'))
position = str(getattr(self, 'positionLB_' + axis).text())
currentPosition.append(float(position))
gcode.append(axisLetter + position)
if moveType in :
if self.arcRadiusLE.text() == '':
self.mbox('{} moves require an arc radius'.format(moveType))
return
if len(self.lastPosition) == 0:
self.mbox('A G0 or G1 move must be done before a {} move'
.format(moveType))
x1 = self.lastPosition[0]
x2 = currentPosition[0]
y1 = self.lastPosition[1]
y2 = currentPosition[1]
if x1 == x2 and y1 == y2:
self.mbox('{} move needs a different end point'.format(moveType))
return
xMid = (x1 + x2) / 2
yMid = (y1 + y2) / 2
slope = (y2 - y1) / (x2 - x1)
distance = math.sqrt(pow((x1 - x2),2) + pow((y1 - y2),2))
radius = float(self.arcRadiusLE.text())
if radius < (distance / 2):
self.mbox('Radius can not be smaller than {0:0.4f}'.format(distance/2))
return
#cosine
c = 1/math.sqrt(1+((slope * -1)*(slope * -1)))
#sine
s = (slope * -1)/math.sqrt(1+((slope * -1)*(slope * -1)))
if moveType == 'G2':
i = xMid + radius * (c)
j = yMid + radius * (s)
gcode.append(' I{0:.{2}f} J{1:.{2}f}'.format(i, j, self.precisionSB.value()))
elif moveType == 'G3':
i = xMid + (-radius) * (c)
j = yMid + (-radius) * (s)
if moveType in : # check for a feed rate
feedMatch = self.gcodeLW.findItems('F', Qt.MatchContains)
if len(feedMatch) > 0: # check last feed rate to see if it is different
lastMatch = str(feedMatch[-1].text()).split()
if lastMatch[-1][1:] != self.feedLE.text():
gcode.append(' F{}'.format(str(self.feedLE.text())))
if not self.gcodeLW.findItems('F', Qt.MatchContains):
if self.feedLE.text():
else:
self.mbox('A feed rate must be entered for a {} move'.format(moveType))
return
self.gcodeLW.addItem(''.join(gcode))
for axis in axes:
self.lastPosition.append(float(getattr(self, 'positionLB_' + axis).text()))
def addExtra(self):
self.gcodeLW.addItem(self.extraLE.text())
def update(self):
self.s.poll()
if self.positionCB.currentData() == 'relative':
# sum the offsets with a negative sign
offsets = tuple(-sum(i) for i in zip(self.s.g5x_offset,self.s.g92_offset))
display = tuple(sum(i) for i in zip(offsets,self.s.actual_position))
else:
display = self.s.actual_position
for i in self.axes:
getattr(self, 'positionLB_' + str(i)).setText('{0:0.{1}f}'.format(display, self.precisionSB.value()))
if self.s.din[self.dinInput] and not self.dinLog:
self.log()
self.dinLog = True
print('remote log')
elif not self.s.din[self.dinInput] and self.dinLog:
self.dinLog = False
def copy(self):
items = []
gcode = [str(self.gcodeLW.item(i).text()) for i in range(self.gcodeLW.count())]
self.qclip.setText('\n'.join(gcode))
def mbox(self, message):
msg = QMessageBox()
msg.setText(message)
msg.exec_()
def sendToAxis(self):
sys.stdout.write(self.gcodeLW(0, 1))
def exit(self):
exit()
def main():
app = QApplication(sys.argv)
ex = MainWindow()
sys.exit(app.exec_())
if __name__ == "__main__":
main()
Warning: Spoiler!
#! /usr/bin/python3
import configparser
import linuxcnc
print('Installed')
else:
def __init__(self):
self.s.poll()
msg = QMessageBox()
msg.exec_()
exit()
self.dinLog = False
self.setupGUI()
self.show()
return True
if IN_AXIS:
def OpenFile(self):
else:
filter='*.ngc',
if fileName:
for line in f:
print(fileName[0])
text = f.read()
def SaveFile(self):
else:
if fileName:
f.write(gcode)
self.SaveFile()
cfgfile.close()
def setupGUI(self):
for i in range(9):
def record(self):
print('Stopping')
def log(self):
axes = []
gcode = []
if moveType in :
return
.format(moveType))
return
return
#cosine
#sine
else:
return
for axis in axes:
def addExtra(self):
def update(self):
self.s.poll()
else:
for i in self.axes:
self.log()
self.dinLog = True
print('remote log')
self.dinLog = False
def copy(self):
items = []
msg = QMessageBox()
msg.exec_()
def exit(self):
exit()
def main():
ex = MainWindow()
main()
25 Feb 2024 17:57 #294416
Note that this modification is not correct
but the original is also not working:
[i] def sendToAxis(self):
sys.stdout.write(self.gcodeLW(0, 1))[/i]
sys.stdout.write(self.g_code.get(0.0, END))
Time to create page: 0.177 seconds
