Axis Position Logger
15 Mar 2024 14:19 - 16 Mar 2024 07:16 #295965
by partec
Replied by partec on topic Axis Position Logger
Thanks, I haven't gotten that far yet, I'll take a look now
Last edit: 16 Mar 2024 07:16 by partec.
16 Mar 2024 07:17 #296027
by partec
looks fine, handling works so far, I'm currently studying which pieces of hal code might not have been set up for me yet? When I do manual logging, the little miracle disappears, why exactly?
motion.digital-in-NN IN BIT
These pins are used by M66 Pnn wait-for-input mode.
motion.digital-out-NN OUT BIT
These pins are controlled by the M62 through M65 words.
16 Mar 2024 08:01 #296028
Replied by Aciera on topic Axis Position Logger
The best approach would be to start your configuration from a terminal and check for errors while you test it.
The hal connections should be set up by the line you added to the [HAL] section of your ini file.
HALCMD = net logloop motion.digital-out-00 motion.digital-in-00
The following user(s) said Thank You: partec
16 Mar 2024 08:43 #296031
by partec
the little miracle works perfectly, so well!
16 Mar 2024 08:52 #296033
I just tried it on a package installation and there I can reproduce the issue when trying to log with the default file_path. I'll come up with a fix in a bit.
16 Mar 2024 09:57 #296038
should be fixed now:
forum.linuxcnc.org/21-axis/30986-axis-po...gger?start=80#295964
16 Mar 2024 10:02 #296039
by partec
I'm constantly testing, it really hit me again, super exciting, thank you
16 Mar 2024 10:30 #296043
Another small fix for the Log Comment section reappearing on startup.
16 Mar 2024 11:52 #296052
by partec
in axis MDI M129 starts emclog.py and setup works fine so far
use emc-log with 'Manual Log' button seems fine already
my Cam-align button starts MDI_COMMAND=o<log>call and motion.digital-in-00 works now in Halshow
it would be fine to prepare now 'to start a single emc-log trig from this motion.digital-in-00' ?
16 Mar 2024 12:00 #296053
Time to create page: 0.248 seconds
