Axis Position Logger
25 Feb 2024 18:08 - 25 Feb 2024 18:12 #294417
by Mecanix
Replied by Mecanix on topic Axis Position Logger
Last edit: 25 Feb 2024 18:12 by Mecanix.
The following user(s) said Thank You: Ehsan_R
25 Feb 2024 18:29 #294424
by Ehsan_R
Replied by Ehsan_R on topic Axis Position Logger
ehsan@debian:~/Desktop$ python3 emclog.py
File "/home/ehsan/Desktop/emclog.py", line 193
if moveType in :
SyntaxError: invalid syntax
25 Feb 2024 18:33 - 26 Feb 2024 10:35 #294425
Replied by Aciera on topic Axis Position Logger
Not sure why that got lost, should be:
[edit]
seems the editor doesn't like the square brackets.
if moveType in ['G1', 'G2', 'G3']
[edit]
Last edit: 26 Feb 2024 10:35 by Aciera.
25 Feb 2024 18:34 #294426
by Ehsan_R
Thanks a lot it works
25 Feb 2024 18:55 - 25 Feb 2024 18:58 #294428
by Ehsan_R
How can I create a button in the graphical interface of AXIS to run the program by pressing it?
Or add it as a tab to the GUI
Last edit: 25 Feb 2024 18:58 by Ehsan_R.
- Thank you received: 5945
25 Feb 2024 19:48 #294441
Replied by tommylight on topic Axis Position Logger
Probably using VCP panels
linuxcnc.org/docs/html/gui/pyvcp.html
26 Feb 2024 00:02 #294471
by Mecanix
Aren't those GTK ui Axis Tabs friendly? I could be wrong, and much like Tommy recommended (pyvcp), I think you can also have it all running from inside linuxcnc e.g AXISTAB: [Preview] | [DRO] | [EMCLOG]
Search for GladeVCP if interested in learning new tricks. Something like below, not far off anyway...
INI file
INI file
[DISPLAY]
EMBED_TAB_NAME = EMCLOG
MBED_TAB_LOCATION = ntb_user_tabs1
EMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u ./emclog/emclog.py ./emclog/emclog.ui
26 Feb 2024 00:25 #294476
by phillc54
Replied by phillc54 on topic Axis Position Logger
26 Feb 2024 10:47 #294497
The logger ui uses pyqt not gtk (ie it's not a glade panel).
26 Feb 2024 13:19 #294514
You can execute a python script using a custom M-code:
1. I have the folders 'libemclog' and 'mcodes' in my config folder
2. the [RS274NGC] section of the ini file must contain the path to the 'mcodes' folder:
3. Executing 'm129' opens the loggerui window.
I have modified emclog.py so the file handling (Open, Save, SaveAs) is a bit more user friendly.
Note: I'm on a rip installation so I'm not sure the paths are correct for a deb install.
USER_M_PATH = ./mcodes
Time to create page: 0.207 seconds
