Pimping the mini-lathe
18 May 2020 07:04 #168131
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Hi Bob,
If I was really driven to replace that gear, I'd buy Gearotic, and make up a fourth axis to mill it, but don't see the necessity.
Mark
Mark
24 May 2020 10:00 #168774
by RotarySMP
Episode 16 is up. Getting closer to LinuxCNC by the week...
Mark
Mark
- Thank you received: 5988
24 May 2020 10:21 #168777
Replied by tommylight on topic Pimping the mini-lathe
Always nice.
24 May 2020 10:24 - 24 May 2020 10:28 #168778
by RotarySMP
Glad to provide a little light entertainment. Thanks for watching.
Soon the LinuxCNC config work will start again, and then I'll be posting more questions, as it is my first use of a Mesa Ethernet card.
Mark
Mark
Last edit: 24 May 2020 10:28 by RotarySMP.
07 Jun 2020 10:00 #170461
by RotarySMP
Last week I screwed up, so Episode 17 is only a fraction of what it should have been,
This weeks Episode 18 is back to the usual standard...
Mark
Mark
13 Jun 2020 12:39 #171421
by RotarySMP
I have started to look at the motion control aspects of this build. Found this thread on getting a PWM signal out of the 7i96 to control a VFD.
forum.linuxcnc.org/27-driver-boards/3923...96-which-pin-for-pwm
The LinuxCNC manual has a good instruction with example of how to connect the "S" word command to that PWM output:
What do I have to change in the Bitfile to get the 7i96 to load that one PWM?
Mark
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
net spindle-speed-cmd motion.spindle-speed-out => pwmgen.0.value
net spindle-on motion.spindle-on => pwmgen.0.enable
net spindle-pwm pwmgen.0.pwm => parport.0.pin-09-out
# Set the spindle's top speed in RPM
setp pwmgen.0.scale 1800
Mark
13 Jun 2020 13:44 #171443
Replied by PCW on topic Pimping the mini-lathe
As long as you have loaded the
7i96d_1pwm.bit
Bitfile, PWM should be present, as long as it's not disabled in the hal file
with a "num_pwmgens=0" token in the hm2_eth driver command line.
7i96d_1pwm.bit
13 Jun 2020 13:47 #171447
by RotarySMP
Thanks PCW. The 7i96 is currently in the "as delivered"configuration. Is that the default bitfile which MESA loads?
Mark
Mark
13 Jun 2020 14:02 #171454
The as shipped 7I96 has the 7i96d.bit bitfile loaded
This has 5 stepgens and no PWM.
To load 7i96d_1pwm.bit you would need to fetch the 7i96.zip archive from Mesa,
extract the 7i96d_1pwm.bit bitfile and run these commands:
mesaflash --device 7i96 --addr [the cards current ip address] --write 7i96d_1pwm.bit
mesaflash --device 7i96 --addr [the cards current ip address] --reload
13 Jun 2020 17:21 #171466
by RotarySMP
Thanks very much.
Moderators: piasdom
Time to create page: 0.210 seconds
