Pimping the mini-lathe
07 Jul 2020 06:31 #173816
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Good idea. I booted the Brix yesterday and it still has windows installed. I thought I had LinuxCNC installed, but maybe gave up before I got that far. I'll burn a Debian boot ISO onto a USB stick tonight and see what happens. If it is too painful, I'll use the PC in the MAHO to install it.
Mark
Mark
07 Jul 2020 10:12 #173821
by RotarySMP
Is there any advantage in Mint verse Debian?
07 Jul 2020 11:39 #173824
Not really. Mint is much nicer to use if its a desktop but in your case embedded in a control panel, I think I would take the easy way out and install the Stretch ISO.
Replied by rodw on topic Pimping the mini-lathe
07 Jul 2020 13:48 #173835
by RotarySMP
Could you please post a link to that Rod?
Thanks,
Mark
Thanks,
Mark
- Thank you received: 5979
07 Jul 2020 14:16 #173837
Replied by tommylight on topic Pimping the mini-lathe
www.linuxcnc.org/testing-stretch-rtpreempt/
R13 is the latest
R13 is the latest
07 Jul 2020 15:12 #173849
by RotarySMP
Thanks a lot. I'm downloading it now.
07 Jul 2020 15:24 #173854
You are welcomed, always.
Rod was sleeping, so i stepped in!
07 Jul 2020 16:43 - 07 Jul 2020 16:59 #173866
by RotarySMP
I am having Deja-vu here. It boots fine from USB, but the debian graphical installer, after the language questions, tries to access the non-existant CD-rom drive, and I cant get passed that point.
Same thing happens with the text based installer.
Any ideas, please?
Mark
Any ideas, please?
Mark
Last edit: 07 Jul 2020 16:59 by RotarySMP.
07 Jul 2020 18:09 #173879
Thats strange. I would check the boot order in the BIOS and make sure it does not look there but clutching at straws. I've never seen it do that.
I was indeed sleeping and I have no idea why I am awake at 4:00am
07 Jul 2020 18:14 #173882
by RotarySMP
Probably your guilty conscience for tempting me into buying a GB Brix
When I finish eating icecream, I'll pull the USB and reinsert it. I found that here...
unix.stackexchange.com/questions/170069/...m-not-being-detected
Moderators: piasdom
