Pimping the mini-lathe
- Thank you received: 5979
06 Jul 2020 08:18 #173728
Replied by tommylight on topic Pimping the mini-lathe
Linux Mint
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Debian 10
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
Most probably you can change the kernel and for sure you can install 2.8, but if you have RTAI, that is Debian Wheezy so there is no support for it, meaning anything you want to install is going to be a pain.
Debian 10
06 Jul 2020 10:13 #173740
Replied by rodw on topic Pimping the mini-lathe
Don't listen to Tommy, Mark. Everybody who uses a Gigabyte Brix really should experience the fun of compiling the kernel on Linux Mint like I had to do before we had all these various shortcuts.
I still recall the horrors 4 years later........
I've got an Odroid H2+ motherboard coming in the next few days which I hope I will let me do something similar to what you are doing but my Brix is mounted to the back of the monitor... Its a bit messy there though. Lots of coiled up cables....
I'm thinking though my next cabinet will be a DIY plasma cut version so all the holes are cut before its folded up. So I'll only need zero tools! I did a simple one the other day and it came up like a bought one once it was powder coated!
06 Jul 2020 10:43 - 06 Jul 2020 11:35 #173743
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Thanks guys.
Rod, I bought the Brix because you seemed so enthusiast about it. Little did I know you were into S&M and just trying to lure an unsuspecting victim into your fetish world
Thanks Tommy, So I can't avoid try to get something to boot from USB again. Bummer.
Mark
Mark
Last edit: 06 Jul 2020 11:35 by RotarySMP.
06 Jul 2020 11:05 #173745
Mint will boot and install even on UEFI as i tested on 2 PC's, not sure about Debian as i never tested it on UEFI machines.
LOL on S&M, he seems to be quite into it, mostly the M part of it !Thanks Tommy, So I can't avoid try to get something to boot from USB again. Bummer.
Mark
06 Jul 2020 11:12 #173746
S&M aside, the best way to get a bootable USB is to use the free win32diskimager on Windows. It has never failed me and I never could get a bootable USB written with Linux.
But back in the S&M days I did read a post on a Linux forum somewhere that indicated that there were ongoing reliability issues with USB writing on Linux.... I think some S&M will ensue next time round cos I ditched my Windows at home in favour of Linux MInt! I did keep a very old laptop to program my Lam Stepper Drivers though...
I hope you get it going it seems from Clive S that the BIOS may be different where you are.... But I was able to install MInt (And the kernel) on a Brix J1900 and a Brix N3160 so your model is in the ball park.
And finally may I say I can't believe that someone could record over 20 videos on the mini lathe! What dedication!
Thanks guys.
Rod, I bought the Brix because you seemed so enthuiast about it. Little did I know yu were into S&M and just trying to lure an unsuspecting victim into your fetish world
Mark
06 Jul 2020 11:34 #173747
by RotarySMP
Ouch, you hit me where it hurt I hope I am not encouraging anyone else to do something this dumb. I only wanted to learn to scrape, and then it seemed like good click bait to start a Youtube channel. Now I have to finish it, and then probably sell it. A CNC conversion of a Proxxon mini lathe recently went for €2500 in the classifieds here, so maybe someone is desperate for a scraped turd.
I dont think the problem was in making bootable USB sticks. I have done that often enough (I use Rufus for windows). The problem seemed to be in getting the Brix to recognise that the bootable USB stick was there.
I'll have to see what is on that brix once I get that 19V PSU repackaged and connected.
Mark
Mark
06 Jul 2020 11:39 #173749
I never had a problem there. its all in the boot settings/UEFI etc. But I did get very familiar with the Gigabyte BIOS!
Mark
06 Jul 2020 11:42 #173750
Yes, I think MInt booted straight up on this laptop via UEFI.
Mark
- Mike_Eitel
- Thank you received: 185
06 Jul 2020 20:10 #173769
by Mike_Eitel
Replied by Mike_Eitel on topic Pimping the mini-lathe
If you have too much to fidle around with your final board...
Just take an other motherboard that works and use it to install the ssd.
Plug it back and probably you have a turning system.
At least i did successfully..
Mike
Mike
06 Jul 2020 20:38 #173772
Install on another PC, put that drive into the machine PC and you are set.
That works from the time of Ubuntu 8.04.Just take an other motherboard that works and use it to install the ssd.
Moderators: piasdom
