Pimping the mini-lathe
14 Jun 2020 11:24 #171589
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Episode 19 is now up...
Happy fathers day.
Mark
Happy fathers day.
Mark
The following user(s) said Thank You: tommylight, StoneB
18 Jun 2020 12:23 #172004
by StoneB
Replied by StoneB on topic Pimping the mini-lathe
Hi Mark - it's amazing how much work you're putting it this small lathe, and I love the IKEA shelves idea.
Look forward to see movement, now that we're moving to the CNC part!
Will you be reutilizing the acetal ballscrew mounts, or are we in for a Maho threadmilling video soon?
Pierre
Pierre
20 Jun 2020 16:59 #172169
by RotarySMP
Hi Pierre,
Glad you joined. For others, Pierre, another guy and I met through the internet back in 2003, when we all wanted to CNC our mini-lathes. Since they both had CNC'd mills, they made the parts and I did the CAD work.
I switched from the Nylatron Z axis nut on Trapezoid lead screw, to a cheap rolled ball screw at some point. It is an Imperial lead ball screw, with more back lash than the lead screw it replaced, but has lower friction and allowed higher speeds. I am pretty sure the cheap generic chinese lead screws you can buy with end machining from Ebay or Ali are higher quality. I should look into that.
Another thread milling video???
Mark
Mark
21 Jun 2020 10:19 #172227
by RotarySMP
I just uploaded episode 20 to youtube.
Mark
Mark
- Thank you received: 5979
21 Jun 2020 10:55 #172228
Replied by tommylight on topic Pimping the mini-lathe
BTW, most of the new VFD's can be set to accept 0-5V analog or PWM input for full range of the spindle, so no need for the small board.
Some can not be set to 5V but all do have another input for current control from 4 to 20mA.
21 Jun 2020 10:58 #172229
by RotarySMP
Good to know. Thanks. This VFD is ancient, and seems to only support 0-10vdc control or a potentiometer, so that €10 widget seemed the easiest solution I could find.
Mark
Mark
28 Jun 2020 16:33 #173004
by RotarySMP
Episode 21 is up...
Mark
Mark
28 Jun 2020 20:04 #173026
LOL@lightbulb
05 Jul 2020 10:34 #173660
by RotarySMP
I now have Episode 22 up...
Enjoy,
Mark
Enjoy,
Mark
The following user(s) said Thank You: phillc54, tommylight
06 Jul 2020 06:42 - 06 Jul 2020 07:01 #173712
by RotarySMP
I should have my little NUC powered up today. I remember that it was a PITA to get it to boot from USB. I had to dick around in some UEFI settings I didn't understand. I got it to boot more by luck than by skill, and now have the standard LinuxCNC 2.7 image on it.
I understand that need to both upgrade this to 2.8 and alter the Linux Kernal to replace RTAI with Preempt_rt for the 7i96 driver to work.
Peter (Talla83) has an excellent video on how to do a clean install, but I was wondering if I can use APT-GET or SPM to make the changes to the existing install?
Mark
Mark
Last edit: 06 Jul 2020 07:01 by RotarySMP.
Moderators: piasdom
Time to create page: 0.121 seconds
