7i90 questions
- JR1050
- Thank you received: 31
27 Feb 2017 21:45 #88711
by JR1050
Replied by JR1050 on topic 7i90 questions
Im gonna claim the Chewbacca defense on that one. I missed it, end of the day. It is however in my hal file...to be continued.
Thank you for your help.
- JR1050
28 Feb 2017 12:47 - 28 Feb 2017 14:20 #88724
by JR1050
seems to load the drivers
user@CMP-0179:~$ halrun
halcmd: halcmd: loadrt hostmot2
<stdin>:1: Unknown command 'halcmd:'
halcmd: loadrt hm2_7i90
halcmd: show pin hm2
Component Pins:
Owner Type Dir Value Name
also tried the same commands at the root account, same results....
Component Pins:
Last edit: 28 Feb 2017 14:20 by JR1050.
- Thank you received: 5316
28 Feb 2017 14:26 #88730
Replied by PCW on topic 7i90 questions
Strange.. maybe permissions but I would expect an error
Another thought I had is that this may be the first time someone has used a "JUSTIO" config
so there might be a bug with hostmot2 when no special I/O is present, so it might be worth trying
running with a more standard firmware config
( you can always disable stepgens and pwmgens etc to get a GPIO only config from any firmware )
The following user(s) said Thank You: JR1050
- JR1050
28 Feb 2017 14:30 #88731
by JR1050
i switched the justio to 7i90_epp_svst1_4_7i47 yesterday afternoon. Suggestion for a bit file? there is a bunch of them.
28 Feb 2017 14:47 #88732
If it does not work with one standard EPP config its not likely to make any difference which config you use
What linuxcnc version and OS version are you using? I can see if i can duplicate things here
- JR1050
28 Feb 2017 14:50 #88733
by JR1050
debian wheezy from the image on the lcnc downlaod page
Originally 2.7.0, now 2.7.8 as I upgraded an hour ago.
Thank you for all your effort !!
28 Feb 2017 20:41 - 28 Feb 2017 20:42 #88776
Theres something strange with the hm2_7i90 and hm2_7i43 drivers under halrun
I get the same results with
halrun
(no pins)
But if I run a standard hal/ini file set (included here), everything works as expected
so there must be some hal file magic that's different here
halrun
(no pins)
Last edit: 28 Feb 2017 20:42 by PCW.
- phillc54
- Thank you received: 2100
28 Feb 2017 21:03 #88779
by phillc54
Replied by phillc54 on topic 7i90 questions
I think I had the same problem and solved it by specifying encoders or stepgens.
Loadrt hm2_7i90 config="num_encoders=-1"
28 Feb 2017 21:06 - 28 Feb 2017 21:08 #88780
Yep, just figured this out myself, you need a non null config string
even config=" " works but config ="" does not
With a null config string, the driver loads with no complaints but never communicates with the card
( This is true of both EPP drivers: hm2_7i43 and hm2_7i90 )
Last edit: 28 Feb 2017 21:08 by PCW.
- JR1050
28 Feb 2017 22:09 #88783
by JR1050
I eliminated all my configs, built a new hm2 stepper deleted all
the ini and Hal files, copied the contents of the zip and edited it.
It worked. Not an easy one to solve and maybe needs to added to the documentation. Thanks your you help and patience. Next is getting the spi working with the Rpi3.
Time to create page: 0.645 seconds
