7i90 questions
08 May 2017 19:39 #92868
by JR1050
Replied by JR1050 on topic 7i90 questions
PCW,
Would it be possible to get a 7i90 bit file with a couple of step gens, smart serial and a couple of encoder inputs. Needs have changed and we now need an encoder to get accurate positioning. Ill need both spi and epp. Thank you.
JR
JR
08 May 2017 21:46 #92879
Replied by PCW on topic 7i90 questions
Sure, do you have a suggested pinout?
09 May 2017 11:59 #92910
by JR1050
how about ?
p1-stepgens
p2-encoders
p3- sserial
Since i managed to put spi on both sides of the 7i90 flash, what are my options for loading the new bit file. I had no luck getting mesaflash to run on a rspi3 and my desk top has no spi. I have an engineer friend who can load it from Jtag, trying to avoid the drive to the other end of the county. thanks
p1-stepgens
p2-encoders
p3- sserial
15 May 2017 11:41 #93219
by JR1050
PCW, i know you are busy, kinda need this in the next couple days.Thanks
15 May 2017 20:18 #93238
I'll try and get to this sometime today, it a mess here because we are moving
16 May 2017 23:18 #93283
well, a day late and a dollar short...
freeby.mesanet.com/7i90.zip
The following user(s) said Thank You: JR1050
26 May 2017 17:26 #93679
by JR1050
Thanks, quick question. Can the encoder be wired right to the pins on the 7i90 board(its a 5v encoder) or is a board like a 7i33 needed?
26 May 2017 21:15 #93685
You can wire a single ended (TTL) encoder to the 7I90
just keep it away from noisy signals
30 May 2017 20:07 #93856
by JR1050
It appears that the newest version of ssi(version 3) is incompatible with the firmware on the 7i84, as i get a message about 50% of the time to upgrade the 7i84. Im having trouble with halui loading, the ssi timing out , halrun wont load the hm2-rspi driver but hal will when it is invoked from lcnc. How does one upgrade the 7i84 firmware? Any suggestions as to what is causing all of this? Prior to loading the above bit file, there were no problems except an occasional hm2 driver error.
31 May 2017 02:02 #93865
There is no new version of SSLBP nor are there any different 7I84 firmware versions
I expect there is some signal integrity issue with the SPI bus or some thing similar
possibly a cable issue or ground loop issue. It could also be driver related since there seem to be some
SPI clock speed setting issues with the driver (running at 50 MHz for the first transfers)
If the SPI clock runs at 50 MHz you would get quite flaky results and differences in bitfiles since
you would be running right at the limits
If I get time in the next week or so I will write a version of the SPI interface that uses digital filtering on the clock
signal to make the interface less susceptible to poor signal quality, this will require a lower clock rate, perhaps 20 MHz
