Brother TC-211
- mblaszkiewicz
- Thank you received: 4
17 Sep 2014 07:12 - 17 Sep 2014 07:19 #51250
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
version 2.5.4. And Ill reset and try the man orient
no luck on the command line input
Last edit: 17 Sep 2014 07:19 by mblaszkiewicz.
- mblaszkiewicz
17 Sep 2014 07:28 #51251
by mblaszkiewicz
Ok I just upgraded to 2.63
- mblaszkiewicz
17 Sep 2014 07:31 - 17 Sep 2014 07:36 #51252
by mblaszkiewicz
Ran it again and got a new error message
Debug file information:
Brother_TC-211.hal:238: pin 'hm2_5i25.0.encoder.00.index-enable' is connected to a signal
3579
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
I went in and edited the encoder to 03. Thats the spindle encoder, and got another error.
Brother_TC-211.hal:242: Unknown command 'aetp'
3927
and the bad line
aetp pid.0.maxoutput 90
should it read
aetp pid.03.maxoutput 90
3579
3927
and the bad line
should it read
Last edit: 17 Sep 2014 07:36 by mblaszkiewicz.
17 Sep 2014 07:38 #51253
We are making progress, getting towards the bottom of the file now. (line 238)
This is a mistake on my part again.
# make sure the encoder is aligned to index
setp hm2_5i25.0.encoder.00.index-enable 1
Needs to be encoder.03.index-enable for the spindle. (Copy and paste error, sorry)
Replied by andypugh on topic Brother TC-211
- mblaszkiewicz
17 Sep 2014 07:48 - 17 Sep 2014 07:50 #51254
by mblaszkiewicz
Brother_TC-211.hal:242: parameter or pin 'pid.0.maxoutput' not found
4139
Still something wrong here
And the hal file section
#SPINDLE ORIENT CHANGES
setp hm2_5i25.0.encoder.03.scale 4098
#set the orientation angle here
setp orient.0.angle 180
setp hm2_5i25.0.encoder.03.index-enable 1
# these values will require adjustment!!!!!
setp pid.spindle.Pgain 1
setp pid.spindle.Igain 0.001
setp pid.0.maxoutput 90 <line 242 the error line
4139
Last edit: 17 Sep 2014 07:50 by mblaszkiewicz.
17 Sep 2014 07:55 #51255
This is what happens when I try to write a HAL file without a LinuxCNC machine to test it on. (though without a 7i77 I could never have tested this file).
Anyway, the problem here is that it isn't pid.0, it is pid.spindle.maxoutput
I even got it right in the two lines above the error...
- mblaszkiewicz
17 Sep 2014 07:59 #51256
by mblaszkiewicz
Brother_TC-211.hal:245: Pin 'orient-pos' does not exist
4320
net spindle orient-pos orient.0.command => pid.spindle.command
Ok I have no idea at all
4320
- mblaszkiewicz
17 Sep 2014 08:05 #51257
by mblaszkiewicz
You can fly over anytime you want and play away
17 Sep 2014 16:17 #51260
Sorry, it was 2am last night, I had to log out.
I can see why that one is hard to decode. The problem is another typo.
The format of a "net" command is
net signal pin pin pin pin....
Unfortunately I put a space instead of a hyphen in the signal name, so the net command is creating a signal called "spindle" then trying to connect a pin called "orient-pos" to it.
The line needs to be
net spindle-orient-pos orient.0.command => pid.spindle.command
- mblaszkiewicz
17 Sep 2014 20:34 #51268
by mblaszkiewicz
I will do that change tonight. At work now. Again thanks so much for the help.
On a side question what kind of bike do you ride. (Your avatar)
Moderators: cncbasher
Time to create page: 0.348 seconds
