Brother TC-211
- ihavenofish
- Thank you received: 83
17 Feb 2019 20:26 #126690
by ihavenofish
Replied by ihavenofish on topic Brother TC-211
youd need to get better limit switches, but steppers would be fine. inductive switches can home well within a thou.
ill be waiting to see how using the stock drives turns out for you. for me, the stock sanyo drives wound up not tunable. the 211 uses Toshiba though, so maybe they will behave differently.
18 Feb 2019 12:54 #126713
by JohnW
Replied by JohnW on topic Brother TC-211
What size inductive proximity sensors give the best resolution? I have seen M4 & M12 on ebay.
18 Feb 2019 14:27 #126716
by danilom
Replied by danilom on topic Brother TC-211
It might also be dependant on target distance and shape
20 Feb 2019 22:22 - 20 Feb 2019 22:24 #126833
by danilom
How did you wire the relay board? Relays have common +24Vdc so it needs GND from 7i77 to activate ?
Had same problem before, on Hurco MD1 so I adapted the relay board to use common GND.
this is mine first movement after rough tuning just to get things started
Last edit: 20 Feb 2019 22:24 by danilom.
20 Feb 2019 22:27 #126834
Replied by PCW on topic Brother TC-211
One option is a 7I77D which is identical to 7I77 except has sinking outputs
- ihavenofish
21 Feb 2019 06:46 #126845
by ihavenofish
I used transistors on the outputs. I don't remember which ones. I just shrink wrapped them right into the cable.
7i77d sounds better
7i77d sounds better
21 Feb 2019 07:05 #126846
by danilom
If only 7i77d was available in Europe , I'll try to modify the relay board today. If not will go with adding the transistors to translate. Thanks
To add, I am amazed at the wiring masterpiece inside this Japan made machine, you literally can't move any wire. Wires are all wrapped, joined and cut to exact length. Finding which wire leads where is not possible with push pull method .
Moderators: cncbasher
Time to create page: 0.206 seconds
