Brother TC-211
17 Sep 2014 20:45 #51269
Depending on the day, or the reason, either a 2004 Yamaha R1, a 2003 GasGasEC200 or a 1921 Ner-a-Car Model A.
Replied by andypugh on topic Brother TC-211
On a side question what kind of bike do you ride. (Your avatar)
- mblaszkiewicz
- Thank you received: 4
18 Sep 2014 03:30 #51287
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Ok back home and debugging again
and another error
Debug file information:
Brother_TC-211.hal:246: Pin 'hm2_5i25.0.7i77.0.1.encoder.03.position' does not exist
4803
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
and line 246
net spindle-orient-fb hm2_5i25.0.7i77.0.1.encoder.03.position => orient.0.position
no idea on the fix
and another error
4803
and line 246
no idea on the fix
18 Sep 2014 03:57 #51288
net spindle-orient-fb hm2_5i25.0.7i77.0.1.encoder.03.position => orient.0.position[/quote]
My fault again. If you look at the other encoders they look like this:
hm2_5i25.0.encoder.00.position
I had forgotten that the encoder modules live on the 5i25 board, and the 7i77 just passes them through.
One thing that can help here is to insert the linein the HAL file temporarily after the loadrt section. That gives you the definitive list of all the HAL pins, but you only see the output if you start LinuxCNC from the command line.
Anyway, the fix here is to change the offending line to
Onwards! We have a good few hours until I need sleep.
But just think how much you are learning about HAL debugging.Ok back home and debugging again
and another error
show pin
net spindle-orient-fb hm2_5i25.0.encoder.03.position => orient.0.position
18 Sep 2014 04:00 #51289
Do you know how to access the IRC channel? We can do live support/chat there.
- mblaszkiewicz
18 Sep 2014 05:15 #51290
by mblaszkiewicz
Just got back in wifey draged me away to do errands
No on the trc channel , but I will look it up. This time linux starteds all the way then ended quickly
Brother_TC-211.hal:247: Pin 'pid.spindle.command' was already linked to signal 'spindle-orient-pos'
5190
and a little lost.
do I just delete the line ???
5190
and a little lost.
- mblaszkiewicz
18 Sep 2014 05:21 #51291
by mblaszkiewicz
I think I made it there
- mblaszkiewicz
21 Sep 2014 08:09 - 21 Sep 2014 08:29 #51389
by mblaszkiewicz
Thanks again to andy and pete for there help on irc to get my orientation all taken care of. Started checking the machine and I have a reading error in the x axis so far. moved 3 inches (by program) and checked with a size block (+-.0002) and had to move another .050. So from 1 side of the block to the other it was 3.050 reading from the Computer. Is it an encoder issue or ball screw error comp. I only moved the machine in 1 direction btw.
Also What pins do I look at to tune my servo's correctly.
Last edit: 21 Sep 2014 08:29 by mblaszkiewicz.
22 Sep 2014 06:55 #51416
I would expect the Brother ballscrews to be excellent. It may be that something is loose or worn. You probably need to check moving in both directions to see if it is backlash or a linear error.
- mblaszkiewicz
22 Sep 2014 07:53 #51417
by mblaszkiewicz
I'm pretty sure it is a linear problem. I only Moved in the x pos direction during the check. I also found an error in the z axis of. Apex. .015 all in the z minus direction. I haven't done any back lash checks yet. I was wondering if it could be a metric ball screw or I have the encoder counts wrong
- scubasteve1
22 Sep 2014 08:10 #51418
by scubasteve1
Replied by scubasteve1 on topic Brother TC-211
How about error over distance, is it constant? how much error over 1", 2" 5", etc. i.e. maybe the encoders are 2048ppr rather than 2000ppr. Or, more complicated here, the encoder connections are not physically wired how the cards are reading them or visa-versa.
Moderators: cncbasher
Time to create page: 0.355 seconds
