Brother TC-211
- mblaszkiewicz
- Thank you received: 4
30 Sep 2014 20:37 #51686
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
The Max velocity is in the ini file or in the Hal? . I think when I used the config program it defaulted to 60 and I never adjusted it.
30 Sep 2014 20:44 #51687
It is generally in the INI file, it's a quick experiment to increase it. (I would do it in stages....)
Replied by andypugh on topic Brother TC-211
- mblaszkiewicz
02 Oct 2014 08:06 #51721
by mblaszkiewicz
Ok got a basic tune on the machine, just one last problem. I changed my spindle over to port 5 on my 7i77 card (the switchable on) now I can't start my spindle. Anyone have a quick bit of code to fix it.
02 Oct 2014 10:05 #51723
Replied by PCW on topic Brother TC-211
I would net hm2_5i25.0.7i77.0.1.spinena to the spindle enable signal
- mblaszkiewicz
04 Oct 2014 06:59 #51774
by mblaszkiewicz
Thanks again to Pete on IRC. I now have a fully functioning machine (almost). I can use it as is now.
- mblaszkiewicz
09 Oct 2014 04:45 #51908
by mblaszkiewicz
Well making chips today (wood) I will post a pic when its done in a few hours. The only issue is the speed. The machine is running slow. Only about 60 ipm. I have it programmed for 150 ipm. I have a copy of my hal and ini attached if any one sees what I have wrong I would appericiate the fix or hint. The machine should rapid at almost 800 ipm. (787 ipm) fpr x and y and 590 ipm for z
09 Oct 2014 08:22 #51911
I wonder if it is
[DISPLAY]
MAX_LINEAR_VELOCITY = 1.000000
That would be 1 inch per second = 60 ipm. (Though I don't think it should be that, it's easy to change to find out)
I wonder if it is
[DISPLAY]
- mblaszkiewicz
13 Oct 2014 07:18 - 13 Oct 2014 16:14 #51987
by mblaszkiewicz
Well thanks again Andy. Speed is up to 600 ipm. Also here are the first to pieces I did as tests. Just real rough carvings.
And a little video
vid1357.photobucket.com/albums/q757/mbla...5900_zps740880a4.mp4
Well can't get the video to show. If a mod could fix the link please
And a little video
Last edit: 13 Oct 2014 16:14 by andypugh. Reason: I couldn't get the video to work as a link either, so it's just a URL now
- scubasteve1
19 Oct 2014 04:56 #52181
by scubasteve1
Replied by scubasteve1 on topic Brother TC-211
Nice!
high IPM is just an awesome time-saver, even if not cutting at high IPM. IMO, most mills are limited to 5-8k usable rpm, and a smaller machine such as yours would be happy with a 3/8" EM @ 0.030" stepover 0.5" DOC and 200-300ipm cutting alum, steel might need a tad less step-over, still keep the IPM high and engagement angle low on the cutter. I would really like to know how your setup handles higher IPM cutting.
02 Nov 2014 16:06 #52684
by uli12us
Replied by uli12us on topic Brother TC-211
You must have 780 ipm max velocity. Do you need this really, I would decrease to 600 ipm, although these machines can up to 1800 ipm. But if you make the first part, that speed is much to high, if you have a fault, you haven't any chance to stop the machine before the crash.
Moderators: cncbasher
Time to create page: 0.508 seconds
