Brother TC-211
- mblaszkiewicz
- Thank you received: 4
03 Jul 2014 17:51 #48417
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
I also got some crimps jumpers test leads and a set of micro screwdrivers. And small crimp on ends for the 26 gauge ribbon cable to make installation of the 7i77 easier.
- mblaszkiewicz
05 Jul 2014 02:07 #48433
by mblaszkiewicz
Ok 1st hiccup. In configuring the linux cnc my 5i25 card is not listed for basic machine config. Any ideas or thoughts. Also no internet to the linux pc.
05 Jul 2014 02:29 #48434
Replied by PCW on topic Brother TC-211
As a first step, I would get internet working, then update Linuxcnc to 2.5.4
- mblaszkiewicz
05 Jul 2014 03:39 - 05 Jul 2014 04:06 #48436
by mblaszkiewicz
Is there anyway to upgrade thru a usb key. The pc I am using has a wireless card. (can't tell if it is working. Where is the device manager) and the modem is across the house. Don't really want to break down the pc move it then bring it back
Last edit: 05 Jul 2014 04:06 by mblaszkiewicz. Reason: added
05 Jul 2014 04:20 #48437
Its theoretically possible but _much_ easier with internet access
- mblaszkiewicz
05 Jul 2014 04:38 - 05 Jul 2014 05:17 #48438
by mblaszkiewicz
ok ok moving computer upstairs for an update should be back in about 15 minutes
Last edit: 05 Jul 2014 05:17 by mblaszkiewicz.
- mblaszkiewicz
05 Jul 2014 05:40 #48439
by mblaszkiewicz
Ok updated linuxcnc, still no 5i25 on pncconfig. What do I do.
05 Jul 2014 05:48 #48440
I thought that LinuxCNC 2.5.4 had the xml files the pncconf needs but maybe not
www.linuxcnc.org/index.php/english/forum...ml-files-for-pncconf
- mblaszkiewicz
05 Jul 2014 08:29 #48441
by mblaszkiewicz
Having no luck getting the files into locations. I tried the auto way and using sudo nautilus.The file is unreadable and has a white x on it
05 Jul 2014 08:53 - 05 Jul 2014 09:19 #48442
Heres one way to do it:
download 5i25_xml.zip
firefox puts this is your Download directory
so now
so now
cd ~
cd Downloads
sudo cp 5i25_xml.zip /lib/firmware/hm2/
cd /lib/firmware/hm2
sudo unzip 5i25_xml.zip
Last edit: 05 Jul 2014 09:19 by PCW. Reason: typo
Moderators: cncbasher
Time to create page: 0.386 seconds
