Brother TC-211
- mblaszkiewicz
- Thank you received: 4
25 May 2014 19:52 #47306
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
The job' is a 3D artitistic milling about 7.5 inches in dia. with personalized engraving. It is a 60 piece orer, and the are waiting to for me to get running right now, but won't wait forever. If I could do it with the conversational I would. I posted the design out at work on Master cam. its about 200 pages of code.
will have power to the unit by next weekend also. With the possibility of the order thinking of possibly changing to new servos to make the change over easier and faster, and doing tool changes by hand. Only 5 changes per part. last 2 tools should run about 20 min each. 1st 3 about 5 min each.
The only concern I have with a total swap is the spindle drive. It is also a LARGE servo motor, and something I don't really want to change.
25 May 2014 20:00 #47307
It's all a bit early if the machine hasn't even been powered up yet. The chances are that this is a fairly straightforward conversion, basically just needing LinuxCNC to be configured with a control board to set the various enable signals, and then to supply an analogue voltage to the right pins to command the servos.
Then you have the fun of tuning the feedback loop (PID)
Replied by andypugh on topic Brother TC-211
I don't think that will necessarily make things faster. You are adding mechanical puzzles to the existing electrical ones.With the possibility of the order thinking of possibly changing to new servos to make the change over easier and faster
With the right setup it might be easier to do the first op on all parts with tool 1, then all the parts with tool 2, etc.and doing tool changes by hand. Only 5 changes per part. last 2 tools should run about 20 min each. 1st 3 about 5 min each.
25 May 2014 21:39 #47309
Replied by PCW on topic Brother TC-211
I would tend to agree with Andy here, assuming your existing drives/motors work.
The drives you have are about as simple as can be expected:
(Analog velocity command from controller, quadrature position feedback to controller)
New drives will have the same interfacing issues as the existing ones
plus possible additional mechanical and wiring work.
- scubasteve1
25 May 2014 23:33 #47312
by scubasteve1
Replied by scubasteve1 on topic Brother TC-211
Personally (myself having limited direct experience with your situation) I would think to try to see what's going on with the original control and drives and try to just nix the NC and use LXcnc in it's place. Being a Brother made/designed control of that vintage it may be pretty simple-ish drive interface and probibly easier to figure out and find info on how they function than fanuc.....
You have AC brushless servos which are good for preformance. As mentioned the mechanical aspect of swaping servos could be tricky, expesive, or both. Think shaft couplings, power transmission, mounting plates... trying to scrounge for used or new old stock stuff gets scarce and buying new gets expensive or you sacrafice preformance, and still is expensive.
Either if you swap servos and drives or use the originals, you will still need the LinuxCNC integration. Why not tackle that first?
26 May 2014 04:30 #47324
by JR1050
Replied by JR1050 on topic Brother TC-211
Where are you located? What are you expecting out of the machine? Do you just need it running good enuff to make your parts? Do you require a real operator pendent or can you live with the gui and the mouse? Im slow right now and might be willing to come to you. Do you have the computer yet?.m in Florida.
- mblaszkiewicz
26 May 2014 10:00 #47328
by mblaszkiewicz
JR I'm up in CT. I should be getting a letter of commitment in the next couple of days. When I get it I can fly you up here to do the swap over. Just send me an email and I would be willing to make you an offer for a flight and a weekend of work. What I am planning is artistic 3-d milling. so high speed milling. I would love to keep the speeds and feeds the machine has now. Just be able to read g-code files (really big ones) resultion would have to be under .0005 inches, sme for back lash. Any worse and the images would start to blurr and mis match.
28 May 2014 00:25 #47414
by JR1050
Email me a phone number and we can talk. This is more then a weekends worth of work. There are more snakes and trap doors on a retrofit then most can imagine....
- mblaszkiewicz
09 Jun 2014 20:41 #47810
by mblaszkiewicz
Had a nice chat with mesa this weekend. 7i77 and 5i25 kit are on there way. 3 phase power kit is also on the way. Hope to get some movement by this weekend. Wish me luck everyone.
- mblaszkiewicz
15 Jun 2014 09:57 - 15 Jun 2014 09:58 #47977
by mblaszkiewicz
Well got in my 3 phase convertion kit from wny converter and supply. Kt came with everything except the case. I needed to get a few more wire connectors and a little more wire. Everything went good on the build. I will post pics later. I need to mount it to the wall and wire to the 220 1 phase, 3 phase motor then the machine. Unfortunately I got the wrong connector for my machine so back to home depot tomorrow.
Last edit: 15 Jun 2014 09:58 by mblaszkiewicz. Reason: clarify
- mblaszkiewicz
21 Jun 2014 09:08 #48153
by mblaszkiewicz
Finally got the 3 phase working. Friend of mine had someone check the wiring diagram from wny, he changed it up a little and motor started on 1st try. If any one gets a kit from them send me a message and i will explain the changes to get it working.
Moderators: cncbasher
Time to create page: 0.264 seconds
