Brother TC-211
- mblaszkiewicz
- Thank you received: 4
03 Apr 2014 08:09 #45525
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Machine is here. Still in the bed of the truck but here. The machine is fully functioning, but does not accept an rs-232 or g-code.
As far as I have read the machine servo motors are 70v +-10 volt direction.
Ok now some info from the manual
x-y-z power supply has the following connections
l1, l2 +dc, +dc, +dc, +t, -t, pb, -pc, -pc, -pc, e
the servo drivers are
r1?, r2?, bc?, (can barely read them) then u,v,w,e,
The servo motors have the following designations
x,y,z servo motors
Connector a
amp pin no resolver signal name hondo pin no driver pin no
1 plug
2 plug
3 R1 3 CN8-3
4 R2 4 CN8-4
5 R3 5 CN8-5
6 S1 6 CN8-6
7 S4 7 CN8-7
8 S2 8 CN8-8
Connector b
amp pin color code pin name
1 red U
2 white V
3 black W
4 green E
Spindle motor
connector a same as above
motor leads
color code pin name comments
red us 2y-4
white vs 2y-4
black ws 2y-4
green e r2-4
krickson leads
red ch pc4009m
red ch pc4009m
So the big question. Can I use these drives and servos and if I can what do I need for cards controllers etc. and any help would be greatly appericiated. I will work on getting the tech pages scanned asap.
Also any one in the north east (CT) i would be interested in hiring some pro help. As long as I get to keep both arms and legs
x,y,z servo motors
Connector a
1 plug
2 plug
3 R1 3 CN8-3
4 R2 4 CN8-4
5 R3 5 CN8-5
6 S1 6 CN8-6
7 S4 7 CN8-7
8 S2 8 CN8-8
Connector b
1 red U
2 white V
3 black W
4 green E
Spindle motor
motor leads
red us 2y-4
white vs 2y-4
black ws 2y-4
green e r2-4
krickson leads
red ch pc4009m
red ch pc4009m
03 Apr 2014 16:52 #45532
You probably can keep the servos and drives, and it will almost certainly be easiest to do so.
U V W are the three motor power phases, with E being earth/gnd
It sounds like the servos have resolvers, but I am a bit puzzled by the R1 R2 R3 S1 S4 S2 designation.
Is this a bare machine with no controller? It sounds like you only have power, servo motors and servo drives. (Which is probably ideal for a LinuxCNC conversion).
Is there any chance you can produce a diagram of how things are hooked together now, paying special attention to anything unconnected that looks to be where a controller would go.
There is one on YouTube converted to Mach3 which is a sign that it is probably a fairly simple conversion.
Replied by andypugh on topic Brother TC-211
- mblaszkiewicz
03 Apr 2014 20:32 #45538
by mblaszkiewicz
It is a full functioning machine with a brother conversational control. As soon as I get some of the manual scanned I will post it here. Only 480 more pages to go
- mblaszkiewicz
04 Apr 2014 20:00 #45561
by mblaszkiewicz
Since this is a low hp machine. 1.5 hp spindle. Is it possible to run the whole machine on a static phase Converter in the three to five hp range? Also any advice on how to start on tHis project cards etc would be helpful
04 Apr 2014 22:54 #45563
(What is your mains voltage?)
Quite possibly. Have you checked that the input transformer isn't configurable for your mains voltage?Since this is a low hp machine. 1.5 hp spindle. Is it possible to run the whole machine on a static phase Converter in the three to five hp range?
We can't really advise until we know what the control signals are from controller to drives. (and the other way too)Also any advice on how to start on tHis project cards etc would be helpful
- mblaszkiewicz
06 Apr 2014 03:09 - 06 Apr 2014 03:21 #45595
by mblaszkiewicz
Last edit: 06 Apr 2014 03:21 by mblaszkiewicz.
- mblaszkiewicz
06 Apr 2014 04:06 #45597
by mblaszkiewicz
I'm not sure if this is the needed info for the controller/servo. if not let me know, and a clue as to what I am looking for
i1357.photobucket.com/albums/q757/mblasz...0271_zpsa2fbf373.jpg
06 Apr 2014 04:21 #45598
by emcPT
Replied by emcPT on topic Brother TC-211
It seams that your drives accept +-10V analog signals.
If the drives are in working conditions the retrofit will not be expensive or too much hard (well it will be easier)
I would recommend a 5i25 + 7i77 for the control of the servo motors. Probably a 7i74 and a 7i84 will be needed after if a lot of IO is needed (if you want to maintain the control with physical buttons, that I personally like).
- mblaszkiewicz
06 Apr 2014 04:43 #45600
by mblaszkiewicz
Thanks its a start. Now a newbie question. What do all the cards do, and I would love to create a modern panel, and have full use of the tool changer, add a tool setter, and possibly a probe in the future.
06 Apr 2014 04:46 #45601
I would suggest that the first thing to do is to find where the analogue control signals to the drives are connected, and perhaps see if you can make the axes move with a 1.5V battery or similar.
(this needs to be done with some care).
The motors have resolver feedback to the drives, what isn't clear is whether the drives convert that to encoder pulses for the controller or not.
LinuxCNC can work with resolvers (my own machine uses them) but I am not sure if the converters have to create the excitation signal too. (sharing encoder signals is easy, sharing resolver signals might be less easy).
This problem goes away if there are linear scales on the axes.
If the drives are in working conditions the retrofit will not be expensive or too much hard (well it will be easier).
Moderators: cncbasher
Time to create page: 0.379 seconds
