Brother TC-211
- mblaszkiewicz
- Thank you received: 4
14 Apr 2014 06:11 #45925
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
I tried running a scope on cn8-13 and cn9-7 and manually turned the servo motor but got no readings. Does the machine have to be powered to get anything from it
14 Apr 2014 06:59 #45927
Replied by PCW on topic Brother TC-211
Those outputs are standard quadrature (4096 counts/turn) so are easy to interface
(no additional hardware needed except linuxcnc interface)
The drives need to be powered for the quadrature output to work
14 Apr 2014 07:17 #45929
This shows that the drives output digital quadrature pulses. This makes things very easy, and rather cheaper.
Do you fancy running the machine with a PCI card, a parallel-port connected card or a rather experimental ethernet interface?
Replied by andypugh on topic Brother TC-211
I found these in the manual. Is it the info you need for the resolvers
i1357.photobucket.com/albums/q757/mblasz...0541_zps9c5da8bc.jpg
- mblaszkiewicz
14 Apr 2014 07:27 - 14 Apr 2014 07:28 #45931
by mblaszkiewicz
I was waiting for more info before putting togther a pc. I have an amd quad processor avaiable, so the easiest and most robust would be great. Also the most input output options. I have a tool changer to work with
Last edit: 14 Apr 2014 07:28 by mblaszkiewicz. Reason: aded info
14 Apr 2014 07:33 #45932
Lots of choices:
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Supported_Hardware
But mainly look at Pico and Mesa as they both offer direct support in this forum. (In fact you have been talking to one of them already). I am uncomfortable making recommendations, though I have no commercial links to either.
Lots of choices:
- mblaszkiewicz
14 Apr 2014 08:18 #45933
by mblaszkiewicz
OK I went to the list and I'm totally lost at this point. What would the best card or cards to get everything running. my main control board has a fifty pin, 30 pin and x, y z and spindle connectors.
14 Apr 2014 22:32 #45941
I suspect that the main choice will be between
pico-systems.com/PPMC.html
and
store.mesanet.com/index.php?route=produc...83_84&product_id=214
But, depending on exactly what the signals are, there may be other combinations that fit better.
and
- mblaszkiewicz
16 Apr 2014 08:11 #45977
by mblaszkiewicz
Any reps from mesa or pico that wish to chime in with info and suggestions I would really love your input.
16 Apr 2014 21:33 #45984
Probably any LinuxCNC analog servo control system will work (including ours (Mesa), Pico systems, Vital systems etc) The next step is to find what other I/O is needed and how it is wired. If you have the machine drawings, this is a really big help here.
Then you can take a look at LinuxCNC compatible interface hardware and see how well it matches your interface requirements. Note that no interface hardware is going to connect directly to your existing controller connectors, so you will have at the minimum
a fair sized re-wiring job.
16 Apr 2014 23:58 #45995
by jmelson
reads a resolver and converts to an encoder-type signal.
A resolver is a transformer that varies its coupling by rotation. It has no electronics
in it. It needs to have an AC excitation signal sent to it, and then the resolver
reading circuit senses the output from the windings and converts that to
position info.
Jon
Replied by jmelson on topic Brother TC-211
\Nope, that info looks like it refers to encoders, or the output of a module thatI found these in the manual. Is it the info you need for the resolvers
position info.
Jon
Moderators: cncbasher
Time to create page: 0.181 seconds
