Biesse Rover 346 Retrofit
23 Feb 2017 18:50 - 23 Feb 2017 18:52 #88553
by bevins
Replied by bevins on topic Biesse Rover 346 Retrofit
For the RS485 ports to communicate with the rs485 I/O of the machine and still need the servo control of the 7i77.
/EDIT I guess your going to tell me the 5i25 is capable to handle RS485 buses?
Last edit: 23 Feb 2017 18:52 by bevins.
23 Feb 2017 19:07 #88554
by bevins
The 7i74 is a RS-422/485 interface? Can use it fir rs-485? then I would just need the 5i25.... correct?
23 Feb 2017 20:06 #88555
Replied by PCW on topic Biesse Rover 346 Retrofit
channel 7 of the 7I74 can do RS-485
There are a couple of hurdles to jump however
1. Can you get documentation on the serial protocol?
2. Can it work with the existing HostMOt2 hardware/UART/PktUART driver?
23 Feb 2017 22:01 #88559
by bevins
Not sure i can get documentation, but i have access to a machine and equipment that can read the protocol.
What is the uart chip on the 7i74, and i dont know if it can use the driver. I would guess it would need work.
23 Feb 2017 22:04 #88560
There is no UART chip on the 7I74, just differential drivers and receivers
the UART is in the FPGA
23 Feb 2017 22:24 #88561
by bevins
I am guessing modbus and usb-rs-485 converter would be easier since this is already developed..
I know this is not in realtime space so the question arises would it be fast enough consistantly to be used in CL and I/O for the machine?
27 Feb 2017 01:28 - 27 Feb 2017 01:29 #88650
by bevins
Last edit: 27 Feb 2017 01:29 by bevins.
27 Feb 2017 13:54 #88662
by bevins
27 Feb 2017 13:57 - 25 Mar 2017 01:59 #88663
by bevins
Last edit: 25 Mar 2017 01:59 by bevins.
25 Mar 2017 01:55 - 25 Mar 2017 01:57 #90233
by bevins
Remap of M6 is done and working. Needs alot of adjustments, speeding up things and timing but WOW, what an adventure.....
I am using time.sleep(x), but going to look at checking when move is comnpleted, then move on. Also need to add different delays and speeds for different cycles.
Thanks for the help guys....
I asked for tool 1, tool2 is in spindle. It drops off tool 2 in pocket and goes and picks up tool 1.
Last edit: 25 Mar 2017 01:57 by bevins.
Time to create page: 0.259 seconds
