Spindle configuration
- Nondepietjes
16 Mar 2017 13:20 #89739
by Nondepietjes
Spindle configuration was created by Nondepietjes
I'm trying to configure my spindle for lathe machine.
I have a encoder and feedback with tacho.
Can somebody take a look at my hal.file?
much appreciated
much appreciated
16 Mar 2017 14:34 #89742
by comjon
Replied by comjon on topic Spindle configuration
You are looking to set S commands on your spindle, to do thread cutting, for example?
- Nondepietjes
16 Mar 2017 14:41 #89743
by Nondepietjes
Replied by Nondepietjes on topic Spindle configuration
yes, and if my hal file is correct. is everything is connected
16 Mar 2017 15:20 #89747
by comjon
I am not at my machine right now, but I think there may be a lathe sample configuration with spindle encoding in the sim folder on LinuxCNC startup.
- Nondepietjes
16 Mar 2017 18:07 #89760
by Nondepietjes
I have tested the hal file, but it appears that my spindle-enable is not connected in my hal file.
Can somebody explain me what i'm doing wrong?
many thanks
many thanks
16 Mar 2017 19:38 #89777
Replied by andypugh on topic Spindle configuration
Is your spindle enable physical wiring corrected to the spinena pin, ro to separate GPIO?
I see
# external output signals
# --- SPINDLE-ON ---
#net spindle-on hm2_5i25.0.7i77.0.0.output-09
Which makes me wonder.
(But nothing drives that spindle-on signal, you should probably delete that commented-out line)
I see
- Nondepietjes
17 Mar 2017 07:56 #89801
by Nondepietjes
Normaly my wiring is correct, i checked it a few times.
i'm working with a mesa 7i77 card and connected my whires to Drive5.
So i have to connect the spindle-on to my spinena pin?
17 Mar 2017 08:43 #89803
Not necessarily, there is a spindle-enable signal that seems to be connected to the right things.
Can you show us a diagram of the wiring to TB5 21, 22, 23, 24 ?
- Nondepietjes
17 Mar 2017 12:43 #89818
by Nondepietjes
My RF signal is connected to the ENA- signal. ENA+ is connected to powersupply.
GRD and ANOUT to the amplifier signals
17 Mar 2017 12:54 #89819
Is that what the spindle drive needs? Often the drive enable needs to connect the enable output to the drive common.
What is the spindle drive?
Time to create page: 0.098 seconds
