Spindle configuration
23 Mar 2017 15:06 #90121
Replied by andypugh on topic Spindle configuration
They should work together now if they worked before, so it might be that the spindle needs to be ramped up slowly.
Do you have the ability to run the spindle slowly? ie, is LinuxCNC in control of spindle speed?
- Nondepietjes
24 Mar 2017 07:54 #90174
by Nondepietjes
Replied by Nondepietjes on topic Spindle configuration
I have found the right connection for the spindle and i can let it turn. But only low speed. When i give al 0.5V signal the RF begins to shut on and of. If i give a 0.4V or below that signal it turns slowly.
24 Mar 2017 13:04 #90200
This is no longer a LinuxCNC question, and so I am only able to guess what the problem might be, and probably guess less effectively than you.
Maybe the tachometer (or command) is reversed and that causes an error at high speeds?
Is every terminal that was previously connected when it worked still connected to something?
- Nondepietjes
27 Mar 2017 13:28 #90365
by Nondepietjes
When the spîndel goes to higher voltage the relay on X2 board is continuosly shut on and off
27 Mar 2017 14:23 #90371
Perhaps the power supply to the board is weak?
- Nondepietjes
03 May 2017 05:23 #92561
by Nondepietjes
I have fund some more information about the X2 panel.
So when i try to set a voltage of 0.5V the relay K500 is switched on and of.
K500 is on the bottem left.
when K500 switched on and of the RF light is switched on and off and everything is going in pulses.
Maby somebody that understand this schedule.
Thank for having a look.
Time to create page: 0.131 seconds
