Errors preventing LinuxCNC from starting.
28 Oct 2017 16:14 #100941
Replied by PCW on topic Errors preventing LinuxCNC from starting.
Don't know about the maxgeo.split error but gedit is part of gnome so won't be
present unless your Linux installation is gnome based, however you can add it with:
sudo apt-get install gedit
28 Oct 2017 16:29 - 28 Oct 2017 16:30 #100943
I wouldn't recommend it. It brings on just about all of Gnome with it.
Change the INI file to "Mousepad" if you just want an text editor.
If you want a good text editor, then Geany has few dependencies and is a fair bit more advance than Gedit.
Replied by andypugh on topic Errors preventing LinuxCNC from starting.
Last edit: 28 Oct 2017 16:30 by andypugh.
The following user(s) said Thank You: cintsa cnc
- Thank you received: 1369
29 Oct 2017 03:55 - 29 Oct 2017 03:56 #100963
Replied by Todd Zuercher on topic Errors preventing LinuxCNC from starting.
Gedit is not installed by default in the current live versions of the Linuxcnc iso. It isn't difficult to install with an internet connection, but there are a large number of dependencies that must also be installed for it to work. For this reason installing it without an internet connection is a little more difficult.
You can also use other text editors, such as the default mousepad one that is included with the iso. Just change the entry in the ini file where it says gedit to mousepad.
Last edit: 29 Oct 2017 03:56 by Todd Zuercher.
Time to create page: 0.098 seconds
