Set the home pos.
24 Nov 2020 18:43 #190211
by Rørbæk
Set the home pos. was created by Rørbæk
Hallo gents!
Mi problem is linux tells me that the machine is not homed so it can not do what i want to do...
I am a newbe to linux but the CPU is now working so i can use the steppermotors from the kebord and i can start the spindle on the controlbox but that is it.
I am looking for help so if there is a dane amongst you i will bee very thankfull otherwise i am greatfull for all help.
Rørbæk
Rørbæk
24 Nov 2020 19:16 #190212
Replied by Aciera on topic Set the home pos.
Homing will get your machine in a predefined position so that LinuxCNC is able to check the Gcode for limit violations.
Do you have home switches on your machine at all?
- Thank you received: 1370
24 Nov 2020 19:21 #190213
Replied by Todd Zuercher on topic Set the home pos.
Does your machine have home or limit switches? (Limit switches can be uses as home switches.)
Which user interface are you using? Different gui have sightly different homing procedures. (Especially on a machine without home switches configured.)
Have you read the parts of the manual pertaining to configuring homing? There are some different settings that must be made for setting up a machine without home switches, and setting up one with them.
25 Nov 2020 11:19 #190251
by Rørbæk
Replied by Rørbæk on topic Set the home pos.
Thank you both. yes i am aware what the homme position means. I have tried to change in thet setup menu but i still get the message
that i am violating the limits when i am trying to start anything.
I have read the 900 pages manuel both some of it not understandable for me.
I am going to day and bying some switches and mount i hope that as you point out will be a part of the solution.
I will return =thanks
25 Nov 2020 11:41 #190252
Ok, make sure you post your HAL and INI.
25 Nov 2020 17:04 #190273
by Rørbæk
Do you mean you would like to see them ???
25 Nov 2020 19:31 #190281
What you describe sounds like you either have a problem with how your soft limits are configured or with the basic direction of movement (+ and - directions are confused).
The settings for the soft limits are in your ini configuration file. Posting a copy of that would be helpful, As well as a description of the mechanics of your machine. (Is it a moving table, or gantry?) What parts of your machine move in which direction when you jog + or -? What are the travel limits of your machine? What value have you assigned to the home position, and where is that relative to the switch you are using for your home switch?
26 Nov 2020 21:01 #190371
by Rørbæk
To day the machine is back and working in a way.
No movement of its owen.
The machine is a 6040cncest. I have Y axis moving forward and backwards. fixed plate . A X axis moving left and right. And the Z axis op and down on a gantry.
The Mach3 CD ( yes cd ) was corrupted efter 4 diffrent cpu with 4 diffrent OS.
So we have got a new parralel port frem china ( kontrolbox ) and the same with the cpu.
So there is some kind of connection manuelly
. I am at the moment installing micriswitches 6 diff places.
Wi have given it a secure ground for electrical grounding.
+ there were missing 5 v powersupply to raise a relay
26 Nov 2020 21:02 #190372
by Rørbæk
I was traying to take a copy of the ini file i didnt work out i will return tommorow again.
Thanks all
Thanks all
27 Nov 2020 14:55 #190449
by Rørbæk
Here is the hal and ini files
I have mouted the microswitches but not cnnected them yet
Henrik
Henrik
Time to create page: 0.206 seconds
