Set the home pos.
02 Dec 2020 15:37 #190879
by Rørbæk
Replied by Rørbæk on topic Set the home pos.
Will do. i have tryed to start and it report a fail. Will soon be back.
My linuxcnc is in my workshop and are completely disengaged from the internet.
02 Dec 2020 17:09 #190884
by Rørbæk
i tryid to repair some because i got failresponce when i started. Now it starts but giv me the att, answers
see ATT.
see ATT.
02 Dec 2020 17:45 - 02 Dec 2020 17:49 #190888
Replied by Aciera on topic Set the home pos.
That information contains no clues as to what the error is.
Open a terminal and type then post the terminal output of that command:
linuxcnc /home/hsh001/linuxcnc/configs/hhmill/hhmill.ini
[edit]
Are you sure you are starting the right config? I thought your config was named my-mill, so that should usually be my-mill.ini
[edit]
Last edit: 02 Dec 2020 17:49 by Aciera.
03 Dec 2020 09:50 #190945
by Rørbæk
I will follow up on it and let you know.
Henrik
Henrik
03 Dec 2020 11:15 #190952
by Rørbæk
I must have made a f-u now i cant get in touch with the machine controller, So tomorrow i will go and one off my freinds who nows about linux but not cnc and get him to get it up and running . I will get get back to you tomorrow afternoon danish time one our before UTC.
Henrik
Sorry for all the problems
Henrik
03 Dec 2020 12:38 #190959
Don't worry.
07 Dec 2020 19:04 #191338
by Rørbæk
Ok. I am back again. We worked with the CPU and it was diiff. to see whar the problem was but we found it, the parralelcard in the CPU was not in contact it had moved so the CPU couldt not see it. That was fixed, but then there was an issue with the software,some is fixed so the CPU is starting up the CNC is starting up but there is no contact betwen CPU and the CNC mashine. I am sending you a copy of the config files please read them at tell me what the proplem are .
Henrik
Henrik
- Thank you received: 5948
07 Dec 2020 20:06 #191349
Replied by tommylight on topic Set the home pos.
No config attached ?
08 Dec 2020 10:04 #191404
by Rørbæk
I will try again.
08 Dec 2020 10:11 #191405
So what is the error?
Open terminal and type
This should start the last used configuration and then we need the text output in the terminal window.
linuxcnc -l
Time to create page: 0.228 seconds
