Set the home pos.
27 Nov 2020 15:14 #190451
Replied by Aciera on topic Set the home pos.
So connect them to the Parallel port and make sure they work when you check them in the "Show Hal configuration" inside LinuxCNC.
Some general information:
linuxcnc.org/docs/2.8/html/config/ini-homing.html
Then you set it up for each [joint] in the ini file
29 Nov 2020 16:39 #190612
by Rørbæk
Replied by Rørbæk on topic Set the home pos.
I have made the hardstops but i dont now abot they work. You write that i shall look on the hal file do i have to have it open while i am moving around with the axis.
am sorry if i am a little slow but i am not used to use linux, and my english is not the best in the world. I am also a not so young man 75 ears old and carpenter of proffesion. so please be pation with me i am very happy that you are helping me.
Henrik
Henrik
30 Nov 2020 07:36 #190657
Ok, maybe best for you to attach your .hal and .ini files. Do you know where to find them and how to attach them here?
30 Nov 2020 13:05 #190670
by Rørbæk
I thought that i have already done that please look on the last pos, on the first page.
Othewise i will try again.
Henrik
Henrik
30 Nov 2020 13:55 #190677
Ah yes, so you did. What pins on the parallel port are the signals from the switches coming in on?
01 Dec 2020 16:33 #190778
by Rørbæk
pin 15 is Z axis
- 13 - X -
- 12 - Y -
- 11 is reserved for probe plate
Henrik
- 13 - X -
- 12 - Y -
Henrik
01 Dec 2020 16:58 - 01 Dec 2020 17:02 #190781
So, add this to your HAL file:
This to the appropriate [JOINT] sections of your INI file:
in [JOINT 0] and [AXIS X] sections you will need to change the Limits to:
Then for the homing:
[JOINT 0]
[JOINT 1]
[JOINT 2]
You will have to fine tune these settings:
linuxcnc.org/docs/html/config/ini-homing.html
[edit]
This assumes that your switches are normally open.
net both-home-x <= parport.0.pin-13-in
net both-home-y <= parport.0.pin-12-in
net both-home-z <= parport.0.pin-15-in
net both-home-x => joint.0.pos-lim-sw-in => joint.0.neg-lim-sw-in => joint.0.home-sw-in
net both-home-y => joint.1.pos-lim-sw-in => joint.1.neg-lim-sw-in => joint.1.home-sw-in
net both-home-x => joint.2.pos-lim-sw-in => joint.2.neg-lim-sw-in => joint.2.home-sw-in
MIN_LIMIT = -0.1
MAX_LIMIT = 390.0
[JOINT 0]
HOME_SEARCH_VEL = -5
HOME_LATCH_VEL = -5
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 2
[JOINT 1]
HOME_LATCH_VEL = -5
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[JOINT 2]
HOME_SEARCH_VEL = 5
HOME_LATCH_VEL = 5
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[edit]
Last edit: 01 Dec 2020 17:02 by Aciera.
The following user(s) said Thank You: Rørbæk
01 Dec 2020 20:25 #190794
by Rørbæk
Thank you i will try tomorrow and let you
Thank you for your time
Henrik
Henrik
02 Dec 2020 11:58 #190867
by Rørbæk
I have changed what wrote plus i have changed the y axis to .1 and 590 as the bed id 60cm
I am i doubt what about the Z axis.
see the Att. thats how the HAL and INI file looks like now.
Henrik
Henrik
02 Dec 2020 13:01 #190870
You need to delete these lines in your HAL:
net home-x => joint.0.home-sw-in
net home-y => joint.1.home-sw-in
net home-z => joint.2.home-sw-in
Then click the home button and report back.
Time to create page: 0.699 seconds
