Set the home pos.
20 Dec 2020 13:39 #192536
Replied by Aciera on topic Set the home pos.
Oops. Sorry to hear that.
But yes you have to make sure you jog the right way.
- Thank you received: 6006
20 Dec 2020 13:43 #192537
Machine should have hard stops, not use switches as hard stops.
Limit and home switches must be side mounted with enough "on time" to be properly triggered.
Replied by tommylight on topic Set the home pos.
That usually means they are not properly installed.Yes there is a override limits used it and smashed the limit switch.
24 Dec 2020 12:28 #193103
by Rørbæk
Replied by Rørbæk on topic Set the home pos.
Thanks for all your help untill now.
I am a little bussy here around x mas with other things.
Merry X-mas to you.
Henrik
Merry X-mas to you.
Henrik
30 Dec 2020 13:57 #193542
by Rørbæk
I have been quite bussy during x-mas time, but i have changed the endswitches and it works, I have a small problem when the mashine hot the hard stops it bach up but not enough whith parameter do i have to change.
Thanks for your help and have happy new year. Henrik see you in 2021.
30 Dec 2020 15:52 #193554
Not sure what you mean, if the machine hits the end switches outside of the homing process then it should just stop with an error and not backup.
30 Dec 2020 17:21 #193563
HOME_OFFSET =I have been quite bussy during x-mas time, but i have changed the endswitches and it works, I have a small problem when the mashine hot the hard stops it bach up but not enough whith parameter do i have to change.
02 Jan 2021 16:23 #193851
by Rørbæk
Here should be a cake with lights in. The machine have made the first cuttings.
A friend with a diff CNC machine was here to help me with Fusion 360 and the mashine.
02 Jan 2021 17:48 #193863
Nice!
03 Jan 2021 11:26 #193941
by Rørbæk
Yes and its thanks to you here.
16 Jan 2021 00:41 #195503
by Rørbæk
Hi there
I am back again.
As i have told before we have had the machine up and running but i still have problems with the end stop.
When i am homing the mashine it is running out to the micriswithes stops return a litle and then moves forward and hit the microswitches.
So were do i change so it run out hit the sw. return a couples of mm then go forward and stops before it hit the sw. again.
Happy new year Henrik
I am back again.
Time to create page: 0.201 seconds
