Set the home pos.
- Thank you received: 5948
16 Jan 2021 01:08 #195506
Replied by tommylight on topic Set the home pos.
From what i understand, add a - to home_latch_velocity, or remove it if it already has it.
16 Jan 2021 02:18 #195514
by Rørbæk
Replied by Rørbæk on topic Set the home pos.
OK thanks trying tommorov its 3 a clock in the morning and i have to sleep
16 Jan 2021 11:08 #195526
Seems we are in the same timezone!
17 Jan 2021 11:26 #195648
by Rørbæk
I am Danish
17 Jan 2021 14:46 #195666
Probably an hour or two before you in timezone, in Kosovo.
Lucky you, the best country to live in.I am Danish
17 Jan 2021 15:50 #195680
by Rørbæk
change of the sign in front worked. so now i am only batteling with the program saying that its running out of defined area.
I am in european mitteltime one hour after you.
it not so fine at the moment wiyh the covid thing
thanks see you
thanks see you
Time to create page: 0.101 seconds
