5i25 + 7i85s +....
03 May 2019 10:27 #132614
by NC4cnc
Replied by NC4cnc on topic 5i25 + 7i85s +....
Hi Andy,
I have a similar situation so I just jumped in on this thread.
Been wiring the 6i25+7i85S boards for an XYZ mill project but can't seem to make it work. We're still using a Universal PWM from Pico.
I used only XYZ PWM, DIR and XYZ A, B & I encoder signals. That leaves me extra I/Os.
I flashed the boards using the 5i25_7i85SPX2.bit.
This caught my eye: "Note that there are 17 perfectly usable 5V TTL GPIO pins on the second header of the 5i25, though."
Are you referring to the I/O connector 2 on PNCCONF, the same as this 2nd header of 5i25/6i25? And the I/O connector 3 (on PNCCONF), the 25-pin going to the 7i85S?
Hope you can clear this out for me. Thanks. Nuki.
04 May 2019 17:21 #132754
Replied by andypugh on topic 5i25 + 7i85s +....
I don't know what the connector is called in PnCConf.
You might need to disable some functions (stepgens etc) depending on firmware to make those pins available as GPIO
Time to create page: 0.167 seconds
