5i25 + 7i85s +....
16 Nov 2016 16:55 #82867
by casetero
Replied by casetero on topic 5i25 + 7i85s +....
I change the state from high to low and continues 0 V. From low to high and continues 0 V.
The Pin 14 ( non-TX7 ) is always 5 V.
When i set num_stepgens=4, the PIN13 is always 5 V. So i guess the PIN isnt damaged, but there is something that blocks me to control it.
Thank you.
Thank you.
16 Nov 2016 17:10 #82868
Replied by PCW on topic 5i25 + 7i85s +....
Very strange, maybe something wrong in the hal file
16 Nov 2016 17:31 #82870
by casetero
Ok, tomorrow i will try with STX0, the outoput of SERIAL of the 7i85s. Is this PIN suitable for my needs??
Another question, when i will install the 5i25_7i85sspx2i.bit, will i be able to use TX7 for ENABLE and TX6 for PWM, or TX7 wont be able to do gpio??
Thank you!!
Thank you!!
16 Nov 2016 21:28 #82875
Just tried this here:
LinuxCNC 2.7.7, Debian Wheezy
5I25 --> P3 --> 7I85S
5i25_7i85sx2.bit config, 3 stepgens enabled
setp hm2_5i25.0.gpio.002.is_output true
setp hm2_5i25.0.gpio.002.out true
setp hm2_5i25.0.gpio.002.out false
toggle 7I85S TB1 pins 13/14
setp hm2_5i25.0.gpio.003.is_output true
setp hm2_5i25.0.gpio.003.out true
setp hm2_5i25.0.gpio.003.out false
toggle 7I85S TB1 pins 11/12
17 Nov 2016 17:24 #82908
by casetero
With STXO works.
I have flashed the 5i25 with mesaflash too.
Tomorow i will continue with the HAL file to set the pwmgen correctly.
Thank you for your support.
21 Nov 2016 18:22 #83088
by casetero
Hello again,
Im trying to make the HAL file to work.
I have wired the STX0 to ENABLE of SPIN1X and works nice.
I have wired TX7 to PWM and TX6 to DIR.
This is my lines of the HAL file:
setp hm2_5i25.0.gpio.001.is_output 1
net spindle-enable motion.spindle-on => hm2_5i25.0.gpio.001.out hm2_5i25.0.pwmgen.00.enable
net spindle-speed-cmd motion.spindle-speed-out => hm2_5i25.0.pwmgen.00.value
setp hm2_5i25.0.pwmgen.00.scale 17500
When i click in the clockwise button of linuxcnc, the SPIN1X lights the LED of ENABLE and SPEED.
When i click in the anti-clockwise button of linuxcnc, the SPIN1X just lights the ENABLE.
Can i use the TX6 for the direction?? My TX6 is always high no matter which button (anti or clockwise) i press.
Thank you.
Thank you.
21 Nov 2016 20:05 #83093
Replied by andypugh on topic 5i25 + 7i85s +....
Which GPIO do TX6, TX7 and STX0 correspond to?
Perhaps your pwmgen is not set to PWM / DIR but instead is in UP / DOWN mode?
21 Nov 2016 20:44 #83096
With the 7i85ssp config TX7 is PWM and TX6 is direction
22 Nov 2016 08:40 #83112
by casetero
The one who is GPIO is STXO, is used as ENABLE for SPIN1X.
The other two are part of pwmgen, TX7 is PWM and TX6 is DIR.
I´ve set the output_type = 1, being PWM and DIR.
But the thing is that TX6 is always HIGH no matter which button (clock or anti) i press.
22 Nov 2016 09:06 #83113
Can you check that the pwmgen sees a negative input value in the reverse direction?
Time to create page: 0.185 seconds
