5i25 + 7i85s +....
28 Dec 2016 17:50 #84815
by Emanresu
Replied by Emanresu on topic 5i25 + 7i85s +....
All right!
Besides there is a 2nd logik/hardware-based PID inside the Servocontroller anyway.
30 Dec 2016 21:28 #84933
by Emanresu
Ok, i have to disturb once again...
My Motordriver is set to 1600 Step/rev.
In Pncconf:
- If i pick a Setup of 1 step/mm (open Loop / no encoder)
- Set a Test Area of 1mm in Axis Tune
The MESA Card schould send 1 Step right?
In Pncconf:
30 Dec 2016 21:50 #84936
Replied by PCW on topic 5i25 + 7i85s +....
Its likely to... but if you have 1 mm steps and a 1.0001 mm move you might generate 2 steps
and if you have 1 mm steps and a 0.9999 mm move you might not generate any steps
Also depends on where you started
- Thank you received: 1370
30 Dec 2016 21:57 #84938
Replied by Todd Zuercher on topic 5i25 + 7i85s +....
I'll be honest I've never been able to make PNCConf"s test and tune section do anything. Best just to use it to make a basic configuration, then fiddle with it from there.
30 Dec 2016 22:11 #84939
by Emanresu
For some reason it doesnt match at all.
Motor does multible smooth Turns and im able to change the Speed.
There shouldnt be a Speed change possible wih a single Step.....
(Or i have steps with analog Vpp Super Step mode! Patented!)
30 Dec 2016 22:28 #84940
by Emanresu
Hm...
Leadscrew 16mm + 1600step/rev = Stepper Scale 1000000,000 Is that plausible?
30 Dec 2016 22:48 #84941
1600 steps = 16mm motion so
100 steps = 1mm motion
so the scale is 100 (steps per mm)
30 Dec 2016 22:56 #84942
by Emanresu
Yep, so we both are better in calculating then my PC
31 Dec 2016 15:41 #84961
by Emanresu
Todd Zuercher was also right...
After a while of hand editing, it is almost more comfortable than pncconf.
Is it possible, that Linux CNC cant operate above 6000mm/min?
It doesnt matter, what my Stepscale is. Above 6000mm/min ill get a "joint 0 following error".
-> 500stp/mm * 6.000mm/min = 3.000.000stp/min -> 50Khz -> Error at about 6200mm/min
-> 100stp/mm * 6.000mm/min = 600.000stp/min -> 10Khz -> Error at about 6200mm/min
Open loop so far. No encoder.
31 Dec 2016 15:53 - 31 Dec 2016 16:08 #84963
No, Linuxcnc has no important speed limitations
(I have a test config that does about 3 million mm/m = ~90 MPH and 10 MHz step rates)
If you get a following error, its probably a hal/ini file problem of some kind
If you post you hal and ini files I can probably see what's wrong
Last edit: 31 Dec 2016 16:08 by PCW.
Time to create page: 0.107 seconds
