5i25 + 7i85s +....
22 Nov 2016 18:01 #83142
by casetero
Replied by casetero on topic 5i25 + 7i85s +....
I think is a 7i85s. How can i diferenciate it??
Actually i control 3 motors with step+dir. I think this can be done just by 7i85s, cant it?
In the page of mesanet i cant see any differences in the photos.
Thank you.
Thank you.
22 Nov 2016 18:21 - 22 Nov 2016 18:24 #83143
by casetero
I cant see the back of the card now because is mounted in a electric box, all wired. Im pretty sure that is a 7i85s, because i bought it with this post:
forum.linuxcnc.org/27-driver-boards/26525-mesa-doubt
When i did mesaflash --device 5i25 --readhmid before flashing it i saw sep/dir outputs. The 7i85 can handle step/dir outputs too?
I have stepgens working with it since i installed it.
Thank you.
EDIT: It is powered with the DB-25 paralel port cable from the 5i25.
Thank you.
Last edit: 22 Nov 2016 18:24 by casetero.
22 Nov 2016 19:31 #83145
Replied by PCW on topic 5i25 + 7i85s +....
Try swapping TX6 and TX7 It looks like the PWM is on TX6 and direction on TX7
The following user(s) said Thank You: Emanresu
25 Dec 2016 15:04 #84683
by Emanresu
Replied by Emanresu on topic 5i25 + 7i85s +....
Hello together, (sorry,... German...)
im replying to this post cuz i noticed someone with an working 5i25+7i85s combination
I usually try to get my experiance by manuals and/or try and error...
But after 3 Days with Google as best friend, i guess it will take me a year to become a HAL-Error analytics Professor
by my selfe.
Situation:
Firmware is 5i25_7i85sspx2 ( 3x Step/Dir + 1x PWM + 4 Encoder )
I did a quick configuration with PnCConf and ended up with this....
Error Message:
"x-pos-fb" can not add OUT pin "hm2_5i25.encoder.01.position", it already has OUT pin "hm2_5i25.0.stepgen.02.position-fb"
Part of the HAL-File:
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output <= hm2_5i25.0.stepgen.02.velocity-cmd
net x-pos-fb <= hm2_5i25.0.stepgen.02.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_5i25.0.stepgen.02.enable
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.01.position
net x-vel-fb <= hm2_5i25.0.encoder.01.velocity
net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
I guess i understand, the conflict. But why does this happen, and what im supposed to do now?
After an Google Oddysee i just noticed, im not the only one with such beginner Problems.
But no one seems to have my Problem. ( 1 or 2 in Russia... but i allready struggle with 2 Languages... dont need a 3rd one )
I hope its just a piece of Cake for you Guys. And thx for any Help!
by my selfe.
Situation:
Error Message:
25 Dec 2016 17:36 #84684
Are you using encoder feedback? If so the position feedback must come from
the encoder, not the stepgen so if this is a pncconf created hal file its a pncconf
bug that must be fixed by hand editing the hal file
25 Dec 2016 20:06 - 25 Dec 2016 20:08 #84685
by Emanresu
Thx for your Reply!
Well, thats the point, where i get lost of Track.
Your information sounds simple, but im not able to do it.
I understand, HAL is kind a like a network of signals linked to each other.
But i dont get the coherencies.
Maybe my way of thinking as an electronics engineer is just confusing me.
Im not able to see those wires to the single components.
-Where does hm2_5i25.0.stepgen.02.position-fb come from?
- FB = Feedback? So it sounds right for x-pos-fb
- Also hm2_5i25.0.encoder.01.position seems like an perfeckt match.
So where is the beginning?
-> +5V from the Screwterminal reach the logic...
-> a "name" is generated for the Terminal -> hm2_5i25.0.encoder.01.position
-> x-pos-fb gets its dependence by "net x-pos-fb <= hm2_5i25.0.encoder.01.position"
So... when and where was "x-pos-fb" generated???
Im really sorry about my stupide questions. But i run in circles whenever i look into the HAL.
On the other hand it seems just es simple as TTL-Logic.... i just miss "something"...
And Yes: I use the Encoder output from the Servodrive. Later ill replace it with Linearscales.
Last edit: 25 Dec 2016 20:08 by Emanresu.
25 Dec 2016 20:36 #84687
It might be helpful to first familiarize you self a bit with basic hal concepts:
linuxcnc.org/docs/2.5/html/hal/basic_hal.html
Basically pins like hm2_5i25.0.stepgen.02.position-fb are hal pins that connect to hardware,
(man hostmot2 will give you the base names of all possible Hostmot2 hardware pins)
Pins like axis.0.motor-pos-fb are hal pins that connect to LinuxCNCs functional blocks
(man motion will list most of the motion related pins)
LinuxCNC customization to a particular interface hardware set and control type
largely consists of connection of LinuxCNCs functional blocks to the specific
interface hardware that you are using.
Pin connections between the different LinuxCNC modules are done with net commands
for example
net x-pos-fb hm2_5i25.0.encoder.01.position
net x-pos-fb pid.0.feedback
Connects a hardware encoder position pin to a PID components feedback input
as will the equivalent:
net x-pos-fb hm2_5i25.0.encoder.01.position pid.0.feedback
Note that the first token after the net command is the signal name, x-pos-fb in this case
If the signal name does not exist, it is created by the first net command
Also note that the signal names are arbitrary so
net blue-tubas hm2_5i25.0.encoder.01.position
net blue-tubas pid.0.feedback
is equivalent to the previous net pair (though perhaps a bit harder to read)
for example
25 Dec 2016 21:31 #84689
by Emanresu
Well, i allready read the Tutorial from your link and also the LinuxCNC_HAL_Manual.
( Maybe to often and i need a break )
In my understanding x-pos-fb is my wire...
It comes to live and gets its name when i cut it from the spool.
Now i have two endings, and im allowed to connect a single input and multible outputs.
It feels simple to me, but i dont geht the whole picture.
Is there some kind of an list with all existing joints and an explanation?
For Example... what happens if i just delete the Line:
In my understanding, i just dont need it, cuz ill get the encoder Information by:
and send it to:
Atleast im not even sure, if my setup is right....
Shouldn´t it be:
hm2_5i25.7i85s.encoder.01.position
instead of:
hm2_5i25.0.encoder.01.position?
Or doesnt it matter because its an path trough anyway. (System doesnt know, whats behind the 5i25)
and send it to:
Shouldn´t it be:
instead of:
25 Dec 2016 22:19 - 25 Dec 2016 22:25 #84690
Shouldn´t it be:
instead of:
No, theres no daughtercard name in the hostmot2 pin/parameter names except for sserial devices
For motion pins, you can read the motion man page:
man motion
For available Hostmot2 pins/parameters with you current hardware/firmware you can show them all with
halrun -I
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci
halcmd: show pin
halcmd show param
instead of:
man motion
halrun -I
halcmd: show pin
halcmd show param
Last edit: 25 Dec 2016 22:25 by PCW.
25 Dec 2016 23:14 #84692
by Emanresu
Thx again, i really appreciate it!
Yep, i remember that from about two days ago. But it just gave me more questions.
In my firmware, i have 3 Step/Dir, 1 PWM, 4 Encoder.
By "show pin show param" i still see 4 Step/Dir
Well, lets make my Spoilers complete....
HAL - File
Im just afraid to make a helping hand bugged with that many text to rawl through...
It has Time!
Warning: Spoiler!
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 RXData1 (In)
14 1 IOPort SSerial 0 TXData1 (Out)
2 2 IOPort PWMGen 0 PWM (Out)
15 3 IOPort PWMGen 0 Dir (Out)
3 4 IOPort StepGen 2 Step (Out)
16 5 IOPort StepGen 2 Dir (Out)
4 6 IOPort StepGen 1 Step (Out)
17 7 IOPort StepGen 1 Dir (Out)
5 8 IOPort StepGen 0 Step (Out)
6 9 IOPort StepGen 0 Dir (Out)
7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 11 IOPort MuxedQCount 0 MuxQ-A (In)
9 12 IOPort MuxedQCount 0 MuxQ-B (In)
10 13 IOPort MuxedQCount 0 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 1 MuxQ-A (In)
12 15 IOPort MuxedQCount 1 MuxQ-B (In)
13 16 IOPort MuxedQCount 1 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 RXData2 (In)
14 18 IOPort SSerial 0 TXData2 (Out)
2 19 IOPort PWMGen 1 PWM (Out)
15 20 IOPort PWMGen 1 Dir (Out)
3 21 IOPort StepGen 6 Step (Out)
16 22 IOPort StepGen 6 Dir (Out)
4 23 IOPort StepGen 5 Step (Out)
17 24 IOPort StepGen 5 Dir (Out)
5 25 IOPort StepGen 4 Step (Out)
6 26 IOPort StepGen 4 Dir (Out)
7 27 IOPort MuxedQCountSel 4 MuxSel0 (Out)
8 28 IOPort MuxedQCount 2 MuxQ-A (In)
9 29 IOPort MuxedQCount 2 MuxQ-B (In)
10 30 IOPort MuxedQCount 2 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 3 MuxQ-A (In)
12 32 IOPort MuxedQCount 3 MuxQ-B (In)
13 33 IOPort MuxedQCount 3 MuxQ-IDX (In)
Warning: Spoiler!
Owner Type Dir Value Name
5 s32 OUT 0 hm2_5i25.0.encoder.00.count
5 s32 OUT 0 hm2_5i25.0.encoder.00.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.00.index-enable
5 bit OUT FALSE hm2_5i25.0.encoder.00.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.00.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.00.input-index
5 bit IN FALSE hm2_5i25.0.encoder.00.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.00.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.00.position
5 float OUT 0 hm2_5i25.0.encoder.00.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.00.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.00.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.00.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.00.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.00.reset
5 float OUT 0 hm2_5i25.0.encoder.00.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.01.count
5 s32 OUT 0 hm2_5i25.0.encoder.01.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.01.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.01.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.01.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.01.input-index
5 bit IN FALSE hm2_5i25.0.encoder.01.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.01.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.01.position
5 float OUT 0 hm2_5i25.0.encoder.01.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.01.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.01.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.01.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.01.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.01.reset
5 float OUT 0 hm2_5i25.0.encoder.01.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.02.count
5 s32 OUT 0 hm2_5i25.0.encoder.02.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.02.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.02.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.02.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.02.input-index
5 bit IN FALSE hm2_5i25.0.encoder.02.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.02.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.02.position
5 float OUT 0 hm2_5i25.0.encoder.02.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.02.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.02.quad-error-enable
5 s32 OUT 1 hm2_5i25.0.encoder.02.rawcounts
5 s32 OUT 1 hm2_5i25.0.encoder.02.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.02.reset
5 float OUT 0 hm2_5i25.0.encoder.02.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.03.count
5 s32 OUT 0 hm2_5i25.0.encoder.03.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.03.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.03.input-a
5 bit OUT FALSE hm2_5i25.0.encoder.03.input-b
5 bit OUT TRUE hm2_5i25.0.encoder.03.input-index
5 bit IN FALSE hm2_5i25.0.encoder.03.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.03.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.03.position
5 float OUT 0 hm2_5i25.0.encoder.03.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.03.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.03.quad-error-enable
5 s32 OUT 1 hm2_5i25.0.encoder.03.rawcounts
5 s32 OUT 1 hm2_5i25.0.encoder.03.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.03.reset
5 float OUT 0 hm2_5i25.0.encoder.03.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.04.count
5 s32 OUT 0 hm2_5i25.0.encoder.04.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.04.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.04.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.04.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.04.input-index
5 bit IN FALSE hm2_5i25.0.encoder.04.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.04.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.04.position
5 float OUT 0 hm2_5i25.0.encoder.04.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.04.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.04.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.04.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.04.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.04.reset
5 float OUT 0 hm2_5i25.0.encoder.04.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.05.count
5 s32 OUT 0 hm2_5i25.0.encoder.05.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.05.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.05.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.05.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.05.input-index
5 bit IN FALSE hm2_5i25.0.encoder.05.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.05.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.05.position
5 float OUT 0 hm2_5i25.0.encoder.05.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.05.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.05.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.05.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.05.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.05.reset
5 float OUT 0 hm2_5i25.0.encoder.05.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.06.count
5 s32 OUT 0 hm2_5i25.0.encoder.06.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.06.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.06.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.06.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.06.input-index
5 bit IN FALSE hm2_5i25.0.encoder.06.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.06.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.06.position
5 float OUT 0 hm2_5i25.0.encoder.06.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.06.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.06.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.06.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.06.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.06.reset
5 float OUT 0 hm2_5i25.0.encoder.06.velocity
5 s32 OUT 0 hm2_5i25.0.encoder.07.count
5 s32 OUT 0 hm2_5i25.0.encoder.07.count-latched
5 bit I/O FALSE hm2_5i25.0.encoder.07.index-enable
5 bit OUT TRUE hm2_5i25.0.encoder.07.input-a
5 bit OUT TRUE hm2_5i25.0.encoder.07.input-b
5 bit OUT FALSE hm2_5i25.0.encoder.07.input-index
5 bit IN FALSE hm2_5i25.0.encoder.07.latch-enable
5 bit IN FALSE hm2_5i25.0.encoder.07.latch-polarity
5 float OUT 0 hm2_5i25.0.encoder.07.position
5 float OUT 0 hm2_5i25.0.encoder.07.position-latched
5 bit OUT FALSE hm2_5i25.0.encoder.07.quad-error
5 bit IN FALSE hm2_5i25.0.encoder.07.quad-error-enable
5 s32 OUT 0 hm2_5i25.0.encoder.07.rawcounts
5 s32 OUT 0 hm2_5i25.0.encoder.07.rawlatch
5 bit IN FALSE hm2_5i25.0.encoder.07.reset
5 float OUT 0 hm2_5i25.0.encoder.07.velocity
5 u32 IN 0x007F2815 hm2_5i25.0.encoder.muxed-sample-frequency
5 bit OUT TRUE hm2_5i25.0.gpio.000.in
5 bit OUT FALSE hm2_5i25.0.gpio.000.in_not
5 bit IN FALSE hm2_5i25.0.gpio.000.out
5 bit OUT TRUE hm2_5i25.0.gpio.001.in
5 bit OUT FALSE hm2_5i25.0.gpio.001.in_not
5 bit IN FALSE hm2_5i25.0.gpio.001.out
5 bit OUT FALSE hm2_5i25.0.gpio.002.in
5 bit OUT TRUE hm2_5i25.0.gpio.002.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.003.in
5 bit OUT TRUE hm2_5i25.0.gpio.003.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.004.in
5 bit OUT TRUE hm2_5i25.0.gpio.004.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.005.in
5 bit OUT TRUE hm2_5i25.0.gpio.005.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.006.in
5 bit OUT TRUE hm2_5i25.0.gpio.006.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.007.in
5 bit OUT TRUE hm2_5i25.0.gpio.007.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.008.in
5 bit OUT TRUE hm2_5i25.0.gpio.008.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.009.in
5 bit OUT TRUE hm2_5i25.0.gpio.009.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.010.in
5 bit OUT TRUE hm2_5i25.0.gpio.010.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.011.in
5 bit OUT FALSE hm2_5i25.0.gpio.011.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.012.in
5 bit OUT FALSE hm2_5i25.0.gpio.012.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.013.in
5 bit OUT TRUE hm2_5i25.0.gpio.013.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.014.in
5 bit OUT FALSE hm2_5i25.0.gpio.014.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.015.in
5 bit OUT TRUE hm2_5i25.0.gpio.015.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.016.in
5 bit OUT TRUE hm2_5i25.0.gpio.016.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.017.in
5 bit OUT FALSE hm2_5i25.0.gpio.017.in_not
5 bit IN FALSE hm2_5i25.0.gpio.017.out
5 bit OUT TRUE hm2_5i25.0.gpio.018.in
5 bit OUT FALSE hm2_5i25.0.gpio.018.in_not
5 bit IN FALSE hm2_5i25.0.gpio.018.out
5 bit OUT FALSE hm2_5i25.0.gpio.019.in
5 bit OUT TRUE hm2_5i25.0.gpio.019.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.020.in
5 bit OUT TRUE hm2_5i25.0.gpio.020.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.021.in
5 bit OUT TRUE hm2_5i25.0.gpio.021.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.022.in
5 bit OUT TRUE hm2_5i25.0.gpio.022.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.023.in
5 bit OUT TRUE hm2_5i25.0.gpio.023.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.024.in
5 bit OUT TRUE hm2_5i25.0.gpio.024.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.025.in
5 bit OUT TRUE hm2_5i25.0.gpio.025.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.026.in
5 bit OUT TRUE hm2_5i25.0.gpio.026.in_not
5 bit OUT FALSE hm2_5i25.0.gpio.027.in
5 bit OUT TRUE hm2_5i25.0.gpio.027.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.028.in
5 bit OUT FALSE hm2_5i25.0.gpio.028.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.029.in
5 bit OUT FALSE hm2_5i25.0.gpio.029.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.030.in
5 bit OUT FALSE hm2_5i25.0.gpio.030.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.031.in
5 bit OUT FALSE hm2_5i25.0.gpio.031.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.032.in
5 bit OUT FALSE hm2_5i25.0.gpio.032.in_not
5 bit OUT TRUE hm2_5i25.0.gpio.033.in
5 bit OUT FALSE hm2_5i25.0.gpio.033.in_not
5 bit IN FALSE hm2_5i25.0.led.CR01
5 bit IN FALSE hm2_5i25.0.led.CR02
5 bit IN FALSE hm2_5i25.0.pwmgen.00.enable
5 float IN 0 hm2_5i25.0.pwmgen.00.value
5 bit IN FALSE hm2_5i25.0.pwmgen.01.enable
5 float IN 0 hm2_5i25.0.pwmgen.01.value
5 s32 OUT 0 hm2_5i25.0.read.time
5 s32 OUT 0 hm2_5i25.0.read_gpio.time
5 bit IN FALSE hm2_5i25.0.stepgen.00.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.00.counts
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.00.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.00.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.00.enable
5 float IN 0 hm2_5i25.0.stepgen.00.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.position-fb
5 float IN 0 hm2_5i25.0.stepgen.00.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.00.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.01.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.01.counts
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.01.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.01.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.01.enable
5 float IN 0 hm2_5i25.0.stepgen.01.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.position-fb
5 float IN 0 hm2_5i25.0.stepgen.01.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.01.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.02.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.02.counts
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.02.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.02.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.02.enable
5 float IN 0 hm2_5i25.0.stepgen.02.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.position-fb
5 float IN 0 hm2_5i25.0.stepgen.02.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.02.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.03.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.03.counts
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.03.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.03.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.03.enable
5 float IN 0 hm2_5i25.0.stepgen.03.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.position-fb
5 float IN 0 hm2_5i25.0.stepgen.03.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.03.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.04.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.04.counts
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.04.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.04.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.04.enable
5 float IN 0 hm2_5i25.0.stepgen.04.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.position-fb
5 float IN 0 hm2_5i25.0.stepgen.04.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.04.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.05.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.05.counts
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.05.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.05.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.05.enable
5 float IN 0 hm2_5i25.0.stepgen.05.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.05.position-fb
5 float IN 0 hm2_5i25.0.stepgen.05.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.05.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.06.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.06.counts
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.06.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.06.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.06.enable
5 float IN 0 hm2_5i25.0.stepgen.06.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.06.position-fb
5 float IN 0 hm2_5i25.0.stepgen.06.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.06.velocity-fb
5 bit IN FALSE hm2_5i25.0.stepgen.07.control-type
5 s32 OUT 0 hm2_5i25.0.stepgen.07.counts
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_err_at_match
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_ff_vel
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_pos_minus_prev_cmd
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_s_to_match
5 s32 OUT 0 hm2_5i25.0.stepgen.07.dbg_step_rate
5 float OUT 0 hm2_5i25.0.stepgen.07.dbg_vel_error
5 bit IN FALSE hm2_5i25.0.stepgen.07.enable
5 float IN 0 hm2_5i25.0.stepgen.07.position-cmd
5 float OUT 0 hm2_5i25.0.stepgen.07.position-fb
5 float IN 0 hm2_5i25.0.stepgen.07.velocity-cmd
5 float OUT 0 hm2_5i25.0.stepgen.07.velocity-fb
5 bit I/O FALSE hm2_5i25.0.watchdog.has_bit
5 s32 OUT 0 hm2_5i25.0.write.time
5 s32 OUT 0 hm2_5i25.0.write_gpio.time
halcmd: show param
Parameters:
5 bit RW FALSE hm2_5i25.0.encoder.00.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.00.filter
5 bit RW FALSE hm2_5i25.0.encoder.00.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.00.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.00.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.00.scale
5 float RW 0.5 hm2_5i25.0.encoder.00.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.01.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.01.filter
5 bit RW FALSE hm2_5i25.0.encoder.01.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.01.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.01.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.01.scale
5 float RW 0.5 hm2_5i25.0.encoder.01.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.02.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.02.filter
5 bit RW FALSE hm2_5i25.0.encoder.02.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.02.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.02.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.02.scale
5 float RW 0.5 hm2_5i25.0.encoder.02.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.03.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.03.filter
5 bit RW FALSE hm2_5i25.0.encoder.03.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.03.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.03.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.03.scale
5 float RW 0.5 hm2_5i25.0.encoder.03.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.04.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.04.filter
5 bit RW FALSE hm2_5i25.0.encoder.04.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.04.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.04.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.04.scale
5 float RW 0.5 hm2_5i25.0.encoder.04.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.05.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.05.filter
5 bit RW FALSE hm2_5i25.0.encoder.05.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.05.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.05.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.05.scale
5 float RW 0.5 hm2_5i25.0.encoder.05.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.06.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.06.filter
5 bit RW FALSE hm2_5i25.0.encoder.06.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.06.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.06.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.06.scale
5 float RW 0.5 hm2_5i25.0.encoder.06.vel-timeout
5 bit RW FALSE hm2_5i25.0.encoder.07.counter-mode
5 bit RW TRUE hm2_5i25.0.encoder.07.filter
5 bit RW FALSE hm2_5i25.0.encoder.07.index-invert
5 bit RW FALSE hm2_5i25.0.encoder.07.index-mask
5 bit RW FALSE hm2_5i25.0.encoder.07.index-mask-invert
5 float RW 1 hm2_5i25.0.encoder.07.scale
5 float RW 0.5 hm2_5i25.0.encoder.07.vel-timeout
5 bit RW FALSE hm2_5i25.0.gpio.000.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.000.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.000.is_output
5 bit RW FALSE hm2_5i25.0.gpio.001.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.001.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.001.is_output
5 bit RW FALSE hm2_5i25.0.gpio.002.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.002.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.003.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.003.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.004.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.004.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.005.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.005.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.006.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.006.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.007.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.007.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.008.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.008.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.009.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.009.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.010.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.010.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.017.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.017.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.017.is_output
5 bit RW FALSE hm2_5i25.0.gpio.018.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.018.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.018.is_output
5 bit RW FALSE hm2_5i25.0.gpio.019.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.019.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.020.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.020.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.021.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.021.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.022.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.022.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.023.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.023.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.024.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.024.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.025.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.025.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.026.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.026.is_opendrain
5 bit RW FALSE hm2_5i25.0.gpio.027.invert_output
5 bit RW FALSE hm2_5i25.0.gpio.027.is_opendrain
5 bit RW FALSE hm2_5i25.0.io_error
5 s32 RW 1 hm2_5i25.0.pwmgen.00.output-type
5 float RW 1 hm2_5i25.0.pwmgen.00.scale
5 s32 RW 1 hm2_5i25.0.pwmgen.01.output-type
5 float RW 1 hm2_5i25.0.pwmgen.01.scale
5 u32 RW 0x00004E20 hm2_5i25.0.pwmgen.pdm_frequency
5 u32 RW 0x00004E20 hm2_5i25.0.pwmgen.pwm_frequency
5 s32 RW 0 hm2_5i25.0.read.tmax
5 bit RO FALSE hm2_5i25.0.read.tmax-increased
5 s32 RW 0 hm2_5i25.0.read_gpio.tmax
5 bit RO FALSE hm2_5i25.0.read_gpio.tmax-increased
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.00.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.00.maxvel
5 float RW 1 hm2_5i25.0.stepgen.00.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.00.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.00.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.01.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.01.maxvel
5 float RW 1 hm2_5i25.0.stepgen.01.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.01.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.01.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.02.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.02.maxvel
5 float RW 1 hm2_5i25.0.stepgen.02.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.02.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.02.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.03.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.03.maxvel
5 float RW 1 hm2_5i25.0.stepgen.03.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.03.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.03.stepspace
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.04.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.04.maxvel
5 float RW 1 hm2_5i25.0.stepgen.04.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.04.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.04.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.05.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.05.maxvel
5 float RW 1 hm2_5i25.0.stepgen.05.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.05.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.05.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.06.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.06.maxvel
5 float RW 1 hm2_5i25.0.stepgen.06.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.06.stepspace
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-0
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-1
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-2
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.06.table-data-3
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.dirhold
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.dirsetup
5 float RW 1 hm2_5i25.0.stepgen.07.maxaccel
5 float RW 0 hm2_5i25.0.stepgen.07.maxvel
5 float RW 1 hm2_5i25.0.stepgen.07.position-scale
5 u32 RW 0x00000000 hm2_5i25.0.stepgen.07.step_type
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.steplen
5 u32 RW 0x00077FE2 hm2_5i25.0.stepgen.07.stepspace
5 u32 RW 0x004C4B40 hm2_5i25.0.watchdog.timeout_ns
5 s32 RW 0 hm2_5i25.0.write.tmax
5 bit RO FALSE hm2_5i25.0.write.tmax-increased
5 s32 RW 0 hm2_5i25.0.write_gpio.tmax
5 bit RO FALSE hm2_5i25.0.write_gpio.tmax-increased
halcmd: show param
Parameters:
HAL - File
Warning: Spoiler!
# Generated by PNCconf at Sun Dec 25 15:40:27 2016
# Änderungen an dieser Datei werden beim nächsten
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=8 num_pwmgens=2 num_stepgens=8 sserial_port_0=00xxxx"
setp hm2_5i25.0.pwmgen.pwm_frequency 20000
setp hm2_5i25.0.pwmgen.pdm_frequency 6000000
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i25.0.write servo-thread
# external output signals
# external input signals
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_5i25.0.stepgen.02.dirsetup [AXIS_0]DIRSETUP
setp hm2_5i25.0.stepgen.02.dirhold [AXIS_0]DIRHOLD
setp hm2_5i25.0.stepgen.02.steplen [AXIS_0]STEPLEN
setp hm2_5i25.0.stepgen.02.stepspace [AXIS_0]STEPSPACE
setp hm2_5i25.0.stepgen.02.position-scale [AXIS_0]STEP_SCALE
setp hm2_5i25.0.stepgen.02.step_type 0
setp hm2_5i25.0.stepgen.02.control-type 1
setp hm2_5i25.0.stepgen.02.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.02.maxvel [AXIS_0]STEPGEN_MAXVEL
#net x-pos-fb <= hm2_5i25.0.stepgen.02.position-fb
# ---setup home / limit switch signals---
net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_5i25.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_5i25.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_5i25.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_5i25.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_5i25.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_5i25.0.stepgen.01.step_type 0
setp hm2_5i25.0.stepgen.01.control-type 1
setp hm2_5i25.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd <= axis.1.motor-pos-cmd
net y-vel-cmd <= axis.1.joint-vel-cmd
net y-output <= hm2_5i25.0.stepgen.01.velocity-cmd
#net y-pos-fb <= hm2_5i25.0.stepgen.01.position-fb
net y-pos-fb => axis.1.motor-pos-fb
net y-enable <= axis.1.amp-enable-out
net y-enable => hm2_5i25.0.stepgen.01.enable
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.02.position
net y-vel-fb <= hm2_5i25.0.encoder.02.velocity
net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
net y-home-sw => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_5i25.0.stepgen.00.dirsetup [AXIS_2]DIRSETUP
setp hm2_5i25.0.stepgen.00.dirhold [AXIS_2]DIRHOLD
setp hm2_5i25.0.stepgen.00.steplen [AXIS_2]STEPLEN
setp hm2_5i25.0.stepgen.00.stepspace [AXIS_2]STEPSPACE
setp hm2_5i25.0.stepgen.00.position-scale [AXIS_2]STEP_SCALE
setp hm2_5i25.0.stepgen.00.step_type 0
setp hm2_5i25.0.stepgen.00.control-type 1
setp hm2_5i25.0.stepgen.00.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.00.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output <= hm2_5i25.0.stepgen.00.velocity-cmd
#net z-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_5i25.0.stepgen.00.enable
setp hm2_5i25.0.encoder.03.counter-mode 0
setp hm2_5i25.0.encoder.03.filter 1
setp hm2_5i25.0.encoder.03.index-invert 0
setp hm2_5i25.0.encoder.03.index-mask 0
setp hm2_5i25.0.encoder.03.index-mask-invert 0
setp hm2_5i25.0.encoder.03.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.03.position
net z-vel-fb <= hm2_5i25.0.encoder.03.velocity
net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.03.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.03.rawcounts
net z-home-sw => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
setp pid.s.maxerror .0005
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.pwmgen.00.output-type 1
setp hm2_5i25.0.pwmgen.00.scale [SPINDLE_9]OUTPUT_SCALE
net spindle-output => hm2_5i25.0.pwmgen.00.value
net machine-is-enabled => hm2_5i25.0.pwmgen.00.enable
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_5i25.0.encoder.00.position
net spindle-vel-fb-rps <= hm2_5i25.0.encoder.00.velocity
net spindle-index-enable <=> hm2_5i25.0.encoder.00.index-enable
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
#setp scale.spindle.gain 60
#setp lowpass.spindle.gain 1.000000
#net spindle-vel-fb-rps => scale.spindle.in
#net spindle-fb-rpm scale.spindle.out => abs.spindle.in
#net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
#net spindle-fb-rpm-abs-filtered lowpass.spindle.out
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
loadrt trivkins
loadrt hostmot2
# AXIS X
# AXIS Y
# AXIS Z
# SPINDLE S
It has Time!
Time to create page: 0.207 seconds
