5i25 + 7i85s +....
10 Nov 2016 11:19 - 10 Nov 2016 11:51 #82647
by casetero
Replied by casetero on topic 5i25 + 7i85s +....
Thank you!
I think i have wired it correctly. Now i´m messing with the HAL file.
The thing is that i dont have a specific PIN for the TX6 and TX7, these are the phisical outputs of my 7i85s that i want to use for the ENABLE and PWM purpose of the SPIN1X.
How are they labeled in the HAL configuration?? There appear position-cmd and velocity-cmd for example, but i guess they aren´t the PINS i have to use.
Any advice??
Thank you again!
EDIT= In the manual of the 7i85s i´ve seen the GPIO´s of the card. It works nice. Thank you!!
Any advice??
Thank you again!
Last edit: 10 Nov 2016 11:51 by casetero.
10 Nov 2016 14:51 #82660
Replied by PCW on topic 5i25 + 7i85s +....
For running the SPINX1 you need a FPGA configuration with a PWM generator
what FPGA configuration are you using?
You can read out the FPGA pinout with:
sudo mesaflash --device 5i25 --readhmid
The following user(s) said Thank You: casetero
10 Nov 2016 16:09 #82665
by casetero
My FPGA system is 5i25+7i85s. I have connected to it 3 encoders and 3 motors. So i have DIF OUT 6,7 free.
I have run the command :
and it returns
sudo : mesaflash : command not found
The LED´s of the ENABLE and DIR are lighting in the SPIN1X. I have wired the ENABLE PIN of the SPIN1X to the PIN TX7 of the 7i85s. In the manual says that this TX7 PIN is the IO19, but i switch on off this pin and the LED doesnt switch off, so i guess that this PIN is always 0.
What am i doing wrong??
Thank you!
and it returns
Thank you!
10 Nov 2016 17:06 - 10 Nov 2016 17:19 #82670
by casetero
Ok, i have installed the mesaflash and this is what i take from the command:
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 RXData1 (In)
14 1 IOPort SSerial 0 TXData1 (Out)
2 2 IOPort StepGen 3 Step/Table1 (Out)
15 3 IOPort StepGen 3 Dir/Table2 (Out)
3 4 IOPort StepGen 2 Step/Table1 (Out)
16 5 IOPort StepGen 2 Dir/Table2 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort StepGen 1 Dir/Table2 (Out)
5 8 IOPort StepGen 0 Step/Table1 (Out)
6 9 IOPort StepGen 0 Dir/Table2 (Out)
7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 11 IOPort MuxedQCount 0 MuxQ-A (In)
9 12 IOPort MuxedQCount 0 MuxQ-B (In)
10 13 IOPort MuxedQCount 0 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 1 MuxQ-A (In)
12 15 IOPort MuxedQCount 1 MuxQ-B (In)
13 16 IOPort MuxedQCount 1 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 RXData2 (In)
14 18 IOPort SSerial 0 TXData2 (Out)
2 19 IOPort StepGen 7 Step/Table1 (Out)
15 20 IOPort StepGen 7 Dir/Table2 (Out)
3 21 IOPort StepGen 6 Step/Table1 (Out)
16 22 IOPort StepGen 6 Dir/Table2 (Out)
4 23 IOPort StepGen 5 Step/Table1 (Out)
17 24 IOPort StepGen 5 Dir/Table2 (Out)
5 25 IOPort StepGen 4 Step/Table1 (Out)
6 26 IOPort StepGen 4 Dir/Table2 (Out)
7 27 IOPort MuxedQCountSel 4 MuxSel0 (Out)
8 28 IOPort MuxedQCount 2 MuxQ-A (In)
9 29 IOPort MuxedQCount 2 MuxQ-B (In)
10 30 IOPort MuxedQCount 2 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 3 MuxQ-A (In)
12 32 IOPort MuxedQCount 3 MuxQ-B (In)
13 33 IOPort MuxedQCount 3 MuxQ-IDX (In)
As i understand im trying to use the IO19 for P2 and IO2 for P3, which is the HAL name for these PINS?? Which do i have to use??
Thank you!!
EDIT--> In the HAL file do i have to put num_stepgens=4 to activate these PINS? or do i let as it is num_stepgens=3??
Thank you!!
Last edit: 10 Nov 2016 17:19 by casetero.
10 Nov 2016 17:29 #82671
Assuming you mean 19 and 20:
setp hm2_5i25.0.gpio.019.is-output 1
setp hm2_5i25.0.gpio.020.is-output 1
net signalname some.hal.pin => hm2_5i25.0.gpio.019.out
net anothersignalname another.hal.pin => hm2_5i25.0.gpio.020.out
4. Otherwise 0 would mean 1.
Replied by andypugh on topic 5i25 + 7i85s +....
10 Nov 2016 17:43 #82674
You probably want to use 5i25_7i85sspx2.bit since it has PWM gens on TX6 and 7 (on both P3 and P2)
10 Nov 2016 17:49 #82675
by casetero
The question was concerning to one PIN, with mesaflash it shows this PIN as IO19 and IO2. In the manual of the 7i85s it says:
FPGA PRIM I/0 -->IO2
FPGA SEC I/0 -->IO19
For the function TX7. In my system the SPIN1X is wired to the 7i85s so i guess the GPIO IO19 is the HAL PIN i have to use. But maybe im guessing too much.
The question of the num_stepgens=4 or 3, is because i have 3 motors in my system so i have always had num_stepgens=3, but i dont know if have to change to 4 in order to activate this PIN, but as my purpose is to use this PIN as GPIO i dont know if i have to add another stepgen to my HAL file.
Thank you!!
Thank you!!
10 Nov 2016 17:57 #82676
What daughterboards are connected to P3 (GPIO 0..16) and P2 (GPIO 17..33) ?
Where do you want the SPINX1 to connect (P2 or P3)
In any case, the firmware you have will not work with the SPINX1 because the SPINX1 requires a PWM generator
so you must use 5i25_7i85sspx2.bit or something like it that has both stepgens and PWMgens
10 Nov 2016 18:12 #82677
by casetero
I have a 5i25 connected via PCI slot to my PC and a 7i85s connected to the 5i25 via paralel port cable. My SPIN1X is connected to the 7i85s via the DIF OUT 7 to the ENABLE. I dont know what P3 and P2 means, sorry.
I guess i need to use the the hm2_5i25.0.gpio.019.out, but im not sure. Do i have to activate another stepgen in the HAL file to make it usable??
I have downloaded the 5i25_7i85sspx2.bit file. How can i install it?
Thank you!
Thank you!
10 Nov 2016 18:16 #82678
No, you have to specifically _disable_ the stepgen to make the pin available as GPIO.
So, with num_stepgens = 3 the pins allocated to stepgens 4,5,6 and 7 become available as GPIO pins.
Time to create page: 0.137 seconds
