Mesa 7i92M Support
- tuffduck33
01 Mar 2017 21:24 #88847
by tuffduck33
Replied by tuffduck33 on topic Mesa 7i92M Support
That makes me feel better. Where do we start?
- tuffduck33
02 Mar 2017 00:18 #88853
by tuffduck33
Is there a way I can send you the files I have?
02 Mar 2017 00:35 #88854
Replied by andypugh on topic Mesa 7i92M Support
Just attach the HAL and INI to a message here.
You said you could jog one axis, if I understand correctly?
- tuffduck33
02 Mar 2017 01:28 #88857
by tuffduck33
I can jog all three axis. Cannot home or run a program. It only works when the charge pump is off.
02 Mar 2017 13:13 #88870
To start with the charge-pump:
I think you should have a PWM on the correct pin, but to check.
First open a terminal and clear the dmesg logNow start linuxcnc from the GUI.
Then clear the terminal (or open a new one) and typeCopy and paste all that output to text file, and attach that to a message here.
sudo dmesg -cThen clear the terminal (or open a new one) and type
dmesg
halcmd show pin
halcmd show paramPlease Log in or Create an account to join the conversation.
- tuffduck33
02 Mar 2017 20:43 #88898
by tuffduck33
Hello, here is what showed on the screen.
02 Mar 2017 22:36 #88902
Unfortunately the output of dmesg and the first part of "show pin" has disappeared (probably off the top)
Perhaps do them one at a time.
However, we probably have enough info to activate the charge pump. It needs to be 10 kHz and 50% duty cycle, to add the following to your HAL file (probably at the bottom)
That should get the charge pump working.
Does that make sense? It is worth mentioning that emcmot.00.enable is a signal defined earlier in the HAL file, and a) Could be called anything, as long as it has the same name everywhere it is used (and I don't like that name as it looks too much like a "system" name, and it isn't. and b) In modern Linuxcnc the "newsig" command is not needed.
# G540 Charge Pump
setp hm2_7i92.0.pwmgen.00.value 0.5
setp hm2_7i92.0.pwmgen.pwm_frequency 10000
net emcmot.00.enable => hm2_7i92.0.pwmgen.00.enableThat should get the charge pump working.
- Thank you received: 5334
03 Mar 2017 00:05 - 03 Mar 2017 00:05 #88905
Replied by PCW on topic Mesa 7i92M Support
The pwmgen is used for the spindle analog output on the G540
The chargepump is fed by a stepgen (stepgen 4 on the first connector)
You can get a clean pin-out of your current config with:
mesaflash --device 7i92 --readhmid
(with the default 192.168.1.121 IP address)
if your 7I92M is set for IP address 10.10.10.10 you would need:
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
Last edit: 03 Mar 2017 00:05 by PCW.
03 Mar 2017 00:06 #88906
In that case, ignore most of what I just typed.
- tuffduck33
03 Mar 2017 00:13 #88907
by tuffduck33
Charge pump still a no go. I redid the terminal commands singly and attached the results. I was sent a newer hal and ini from Mesa and have attached them as well.
Time to create page: 2.968 seconds
