Mesa 7i92M Support
05 Mar 2017 13:05 - 05 Mar 2017 13:16 #89038
You need to replace all the "parport.0.pin-NN-in" pins with the hm2_7i92.0.gpio-NNN-in pins in the HAL file.
If you look at the pin listing produced earlier you will see that there are lots of them, though, and the NNN numbers on the 7i92 do not correspond 1 to 1 with the parport.0.NN numbers.
The correspondence would have been printed out by the dimes command, but you don't seem to have given us that, or the mesaflash command that PCW gave you to try. But in the absence of those, here it is from the Mesa firmware source code.
So I _think_ that, for example,would becomeExcept that isn't right, because the G540 (in hardware) makes the Parport-03/GPIO-04 into an output-only pin. As far as I can tell the G540 only offers you 4 input pins, and three of those might be needed for a spindle encoder.
Unlike a parallel port the GPIO pins on the 7i92 can be individually set to be inputs and outputs, and you have 17 of them on the secondary header available
How many physical input pins do you need?
Replied by andypugh on topic Mesa 7i92M Support
The following lines need to be changed to use the GPIO on the G540, not the parallel port. Directions on the web on how to accomplish this, not easy to find.
Base func sec unit sec func GPIO pin -- external DB25
"00"&NullTag & NullPin, -- I/O 00 PIN 1 Output 2 just GPIO
"00"& PWMTag & PWMAOutPin, -- I/O 01 PIN 14 Spindle DAC PWM
"00" & StepGenTag & StepGenStepPin, -- I/O 02 PIN 2 X Step
"00" & NullTag & NullPin, -- I/O 03 PIN 15 Fault in just GPIO
"00" & StepGenTag & StepGenDirPin, -- I/O 04 PIN 3 X Dir
"04" & StepGenTag & StepGenStepPin, -- I/O 05 PIN 16 Charge Pump (16 KHz)
"01" & StepGenTag & StepGenStepPin, -- I/O 06 PIN 4 Y Step
"00" & NullTag & NullPin, -- I/O 07 PIN 17 Output 1 just GPIO
"01" & StepGenTag & StepGenDirPin, -- I/O 08 PIN 5 Y Dir
"02" & StepGenTag & StepGenStepPin, -- I/O 09 PIN 6 Z Step
"02" & StepGenTag & StepGenDirPin, -- I/O 10 PIN 7 Z Dir
"03" & StepGenTag & StepGenStepPin, -- I/O 11 PIN 8 A Step
"03" & StepGenTag & StepGenDirPin, -- I/O 12 PIN 9 A Dir
"00" & QCountTag & QCountQAPin, -- I/O 13 PIN 10 Input 1 (Quad A)
"00" & QCountTag & QCountQBPin, -- I/O 14 PIN 11 Input 2 (Quad B)
"00" & QCountTag & QCountIdxPin, -- I/O 15 PIN 12 Input 3 (Quad Idx)
"00" & NullTag & NullPin, -- I/O 16 PIN 13 Input 4 just GPIO
# --- JOG-X-POS ---
net jog-x-pos <= parport.0.pin-03-in
# --- JOG-X-POS ---
net jog-x-pos <= hm2_7i92.0.gpio-004-in-in
Last edit: 05 Mar 2017 13:16 by andypugh.
- tuffduck33
05 Mar 2017 21:53 - 06 Mar 2017 00:46 #89063
by tuffduck33
Replied by tuffduck33 on topic Mesa 7i92M Support
Definitely way more complicated than I imagined. The basic setup I have uses 3 steppers, e-stop, 3 home switches. I have never been able to get the G540 and the VFD to work together so I have done it manually. I have rerun the terminal commands and have posted them below;
debian@debian:~$ mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 2 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort PWM 0 PWM (Out)
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort StepGen 4 Step/Table1 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort None
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort QCount 0 Quad-A (In)
11 14 IOPort QCount 0 Quad-B (In)
12 15 IOPort QCount 0 Quad-IDX (In)
13 16 IOPort None
IO Connections for P1
1 17 IOPort None
14 18 IOPort PWM 1 PWM (Out)
2 19 IOPort StepGen 5 Step/Table1 (Out)
15 20 IOPort None
3 21 IOPort StepGen 5 Dir/Table2 (Out)
16 22 IOPort StepGen 9 Step/Table1 (Out)
4 23 IOPort StepGen 6 Step/Table1 (Out)
17 24 IOPort None
5 25 IOPort StepGen 6 Dir/Table2 (Out)
6 26 IOPort StepGen 7 Step/Table1 (Out)
7 27 IOPort StepGen 7 Dir/Table2 (Out)
8 28 IOPort StepGen 8 Step/Table1 (Out)
9 29 IOPort StepGen 8 Dir/Table2 (Out)
10 30 IOPort QCount 1 Quad-A (In)
11 31 IOPort QCount 1 Quad-B (In)
12 32 IOPort QCount 1 Quad-IDX (In)
13 33 IOPort None
debian@debian:~$
debian@debian:~$ sudo dmesg -c
[ 0.274117] PCI: pci_cache_line_size set to 64 bytes
[ 0.274285] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.274292] reserve RAM buffer: 00000000bfe4b000 - 00000000bfffffff
[ 0.274297] reserve RAM buffer: 00000000bfeed000 - 00000000bfffffff
[ 0.274302] reserve RAM buffer: 00000000bff00000 - 00000000bfffffff
[ 0.274702] hpet clockevent registered
[ 0.274710] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.274717] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.274727] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.284074] AMD NB: Cannot enumerate AMD northbridges.
[ 0.284080] Switching to clocksource hpet
[ 0.292194] pnp: PnP ACPI init
[ 0.292238] ACPI: bus type pnp registered
[ 0.296120] pnp 00:00: [bus 00-ff]
[ 0.296126] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.296132] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.296136] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.296142] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.296150] pnp 00:00: [mem 0x000e0000-0x000effff window]
[ 0.296155] pnp 00:00: [mem 0xf8000000-0xfebfffff window]
[ 0.296159] pnp 00:00: [mem 0xc0000000-0xf0000000 window]
[ 0.296277] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.296323] pnp 00:01: [mem 0xf0000000-0xf3ffffff]
[ 0.296329] pnp 00:01: [mem 0xfed13000-0xfed13fff]
[ 0.296333] pnp 00:01: [mem 0xfed14000-0xfed17fff]
[ 0.296338] pnp 00:01: [mem 0xfed18000-0xfed18fff]
[ 0.296342] pnp 00:01: [mem 0xfed19000-0xfed19fff]
[ 0.296346] pnp 00:01: [mem 0xfed1c000-0xfed1ffff]
[ 0.296351] pnp 00:01: [mem 0xfed20000-0xfed9ffff]
[ 0.296355] pnp 00:01: [mem 0x000c0000-0x000dffff]
[ 0.296360] pnp 00:01: [mem 0x000e0000-0x000fffff]
[ 0.296513] system 00:01: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 0.296520] system 00:01: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.296527] system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.296533] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.296539] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.296546] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.296552] system 00:01: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.296560] system 00:01: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.296567] system 00:01: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.296574] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.297097] pnp 00:02: [io 0x0000-0x000f]
[ 0.297103] pnp 00:02: [io 0x0081-0x0083]
[ 0.297107] pnp 00:02: [io 0x0087]
[ 0.297112] pnp 00:02: [io 0x0089-0x008b]
[ 0.297116] pnp 00:02: [io 0x008f]
[ 0.297120] pnp 00:02: [io 0x00c0-0x00df]
[ 0.297125] pnp 00:02: [dma 4]
[ 0.297210] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.297247] pnp 00:03: [io 0x0070-0x0071]
[ 0.297252] pnp 00:03: [io 0x0074-0x0077]
[ 0.297269] pnp 00:03: [irq 8]
[ 0.297347] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.297388] pnp 00:04: [io 0x00f0]
[ 0.297402] pnp 00:04: [irq 13]
[ 0.297484] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.297527] pnp 00:05: [io 0x0061]
[ 0.297612] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.297645] pnp 00:06: [io 0x0500-0x053f]
[ 0.297650] pnp 00:06: [io 0x0400-0x047f]
[ 0.297655] pnp 00:06: [io 0x0092]
[ 0.297659] pnp 00:06: [io 0x0680-0x06ff]
[ 0.297663] pnp 00:06: [io 0x0010-0x001f]
[ 0.297668] pnp 00:06: [io 0x0072-0x0073]
[ 0.297672] pnp 00:06: [io 0x0080]
[ 0.297676] pnp 00:06: [io 0x0084-0x0086]
[ 0.297680] pnp 00:06: [io 0x0088]
[ 0.297684] pnp 00:06: [io 0x008c-0x008e]
[ 0.297689] pnp 00:06: [io 0x0090-0x009f]
[ 0.297844] system 00:06: [io 0x0500-0x053f] has been reserved
[ 0.297852] system 00:06: [io 0x0400-0x047f] could not be reserved
[ 0.297858] system 00:06: [io 0x0680-0x06ff] has been reserved
[ 0.297865] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.298435] pnp 00:07: [irq 12]
[ 0.298522] pnp 00:07: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.298598] pnp 00:08: [io 0x0060]
[ 0.298603] pnp 00:08: [io 0x0064]
[ 0.298613] pnp 00:08: [irq 1]
[ 0.298703] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.299128] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.299138] pnp 00:09: [irq 4]
[ 0.299336] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.299581] pnp 00:0a: [mem 0xfec00000-0xfec000ff]
[ 0.299674] pnp 00:0a: Plug and Play ACPI device, IDs PNP0003 (active)
[ 0.299797] pnp: PnP ACPI: found 11 devices
[ 0.299801] ACPI: ACPI bus type pnp unregistered
[ 0.311059] pci 0000:01:00.0: no compatible bridge window for [mem 0xfffe0000-0xffffffff pref]
[ 0.311074] PCI: max bus depth: 1 pci_try_num: 2
[ 0.311138] pci 0000:00:1c.3: BAR 15: assigned [mem 0xd2500000-0xd26fffff 64bit pref]
[ 0.311149] pci 0000:00:1c.3: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.311157] pci 0000:00:1c.2: BAR 15: assigned [mem 0xd2700000-0xd28fffff 64bit pref]
[ 0.311164] pci 0000:00:1c.2: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.311171] pci 0000:00:1c.0: BAR 15: assigned [mem 0xd2900000-0xd2afffff 64bit pref]
[ 0.311178] pci 0000:00:1c.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.311189] pci 0000:01:00.0: BAR 6: can't assign mem pref (size 0x20000)
[ 0.311195] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.311202] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xd1ffffff]
[ 0.311207] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.311215] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.311220] pci 0000:00:1c.0: bridge window [io 0x5000-0x5fff]
[ 0.311227] pci 0000:00:1c.0: bridge window [mem 0xd2200000-0xd22fffff]
[ 0.311233] pci 0000:00:1c.0: bridge window [mem 0xd2900000-0xd2afffff 64bit pref]
[ 0.311242] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.311247] pci 0000:00:1c.2: bridge window [io 0x4000-0x4fff]
[ 0.311254] pci 0000:00:1c.2: bridge window [mem 0xd2300000-0xd23fffff]
[ 0.311260] pci 0000:00:1c.2: bridge window [mem 0xd2700000-0xd28fffff 64bit pref]
[ 0.311269] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.311273] pci 0000:00:1c.3: bridge window [io 0x3000-0x3fff]
[ 0.311281] pci 0000:00:1c.3: bridge window [mem 0xd2400000-0xd24fffff]
[ 0.311287] pci 0000:00:1c.3: bridge window [mem 0xd2500000-0xd26fffff 64bit pref]
[ 0.311296] pci 0000:00:1e.0: PCI bridge to [bus 05-05]
[ 0.311301] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.311308] pci 0000:00:1e.0: bridge window [mem 0xd2000000-0xd20fffff]
[ 0.311343] pci 0000:00:01.0: setting latency timer to 64
[ 0.311373] pci 0000:00:1c.0: setting latency timer to 64
[ 0.311395] pci 0000:00:1c.2: setting latency timer to 64
[ 0.311417] pci 0000:00:1c.3: setting latency timer to 64
[ 0.311429] pci 0000:00:1e.0: setting latency timer to 64
[ 0.311435] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.311439] pci_bus 0000:00: resource 1 [mem 0x00000000-0xfffffffff]
[ 0.311443] pci_bus 0000:01: resource 1 [mem 0xd0000000-0xd1ffffff]
[ 0.311447] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.311452] pci_bus 0000:02: resource 0 [io 0x5000-0x5fff]
[ 0.311455] pci_bus 0000:02: resource 1 [mem 0xd2200000-0xd22fffff]
[ 0.311459] pci_bus 0000:02: resource 2 [mem 0xd2900000-0xd2afffff 64bit pref]
[ 0.311464] pci_bus 0000:03: resource 0 [io 0x4000-0x4fff]
[ 0.311468] pci_bus 0000:03: resource 1 [mem 0xd2300000-0xd23fffff]
[ 0.311472] pci_bus 0000:03: resource 2 [mem 0xd2700000-0xd28fffff 64bit pref]
[ 0.311476] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 0.311480] pci_bus 0000:04: resource 1 [mem 0xd2400000-0xd24fffff]
[ 0.311484] pci_bus 0000:04: resource 2 [mem 0xd2500000-0xd26fffff 64bit pref]
[ 0.311488] pci_bus 0000:05: resource 0 [io 0x1000-0x1fff]
[ 0.311492] pci_bus 0000:05: resource 1 [mem 0xd2000000-0xd20fffff]
[ 0.311496] pci_bus 0000:05: resource 4 [io 0x0000-0xffff]
[ 0.311500] pci_bus 0000:05: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.311634] NET: Registered protocol family 2
[ 0.314985] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.318406] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.324298] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.326390] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.326395] TCP reno registered
[ 0.326492] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.326721] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.327110] NET: Registered protocol family 1
[ 0.327475] pci 0000:01:00.0: Boot video device
[ 0.327504] pci 0000:05:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.327519] PCI: CLS 0 bytes, default 64
[ 0.327674] Unpacking initramfs...
[ 0.707551] Freeing initrd memory: 10384k freed
[ 0.715815] audit: initializing netlink socket (disabled)
[ 0.715844] type=2000 audit(1488736129.708:1): initialized
[ 0.735759] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.736306] VFS: Disk quotas dquot_6.5.2
[ 0.736388] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.736567] msgmni has been set to 6034
[ 0.736967] alg: No test for stdrng (krng)
[ 0.737033] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.737040] io scheduler noop registered
[ 0.737043] io scheduler deadline registered
[ 0.737075] io scheduler cfq registered (default)
[ 0.737317] pcieport 0000:00:01.0: setting latency timer to 64
[ 0.737372] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.737485] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.737539] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X
[ 0.737659] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.737712] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
[ 0.737833] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.737886] pcieport 0000:00:1c.3: irq 43 for MSI/MSI-X
[ 0.738099] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.738168] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.738172] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.738970] ERST: Table is not found!
[ 0.738974] GHES: HEST is not enabled!
[ 0.739114] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.759556] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.880669] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.916294] Linux agpgart interface v0.103
[ 0.917025] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.920424] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.920441] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.920817] mousedev: PS/2 mouse device common for all mice
[ 0.920901] rtc_cmos 00:03: RTC can wake from S4
[ 0.921156] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.921251] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.921283] cpuidle: using governor ladder
[ 0.921287] cpuidle: using governor menu
[ 0.921975] TCP cubic registered
[ 0.922066] NET: Registered protocol family 10
[ 0.923716] Mobile IPv6
[ 0.923723] NET: Registered protocol family 17
[ 0.923732] Registering the dns_resolver key type
[ 0.924073] PM: Hibernation image not present or could not be loaded.
[ 0.924109] registered taskstats version 1
[ 0.924723] rtc_cmos 00:03: setting system clock to 2017-03-05 17:48:50 UTC (1488736130)
[ 0.924815] Initializing network drop monitor service
[ 0.928109] Freeing unused kernel memory: 916k freed
[ 0.928707] Write protecting the kernel read-only data: 6144k
[ 0.932168] Freeing unused kernel memory: 548k freed
[ 0.936508] Freeing unused kernel memory: 652k freed
[ 0.941665] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.963728] udevd[64]: starting version 175
[ 1.081157] SCSI subsystem initialized
[ 1.083613] usbcore: registered new interface driver usbfs
[ 1.087505] usbcore: registered new interface driver hub
[ 1.095801] libata version 3.00 loaded.
[ 1.096570] usbcore: registered new device driver usb
[ 1.099723] ata_piix 0000:00:1f.1: version 2.13
[ 1.099826] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.103017] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.115629] scsi0 : ata_piix
[ 1.125349] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.127688] scsi1 : ata_piix
[ 1.133200] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.133207] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.143959] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x20b0 irq 14
[ 1.143967] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x20b8 irq 15
[ 1.144854] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.144865] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.145002] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.145046] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.145065] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.150606] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.151196] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xd2100000
[ 1.156094] ata2: port disabled--ignoring
[ 1.164172] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.166806] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.166815] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.166821] usb usb1: Product: EHCI Host Controller
[ 1.166827] usb usb1: Manufacturer: Linux 3.2.0-4-rt-amd64 ehci_hcd
[ 1.166832] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.182793] hub 1-0:1.0: USB hub found
[ 1.182812] hub 1-0:1.0: 8 ports detected
[ 1.185594] e100 0000:05:08.0: eth0: addr 0xd2004000, irq 20, MAC addr 00:16:76:1f:1b:8e
[ 1.187708] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.187716] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.187818] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.187933] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[ 1.188170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.188175] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.188179] usb usb2: Product: UHCI Host Controller
[ 1.188183] usb usb2: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.188186] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.193994] hub 2-0:1.0: USB hub found
[ 1.194011] hub 2-0:1.0: 2 ports detected
[ 1.195605] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.195694] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.199318] scsi2 : ata_piix
[ 1.199908] scsi3 : ata_piix
[ 1.201450] ata3: SATA max UDMA/133 cmd 0x20c8 ctl 0x20e4 bmdma 0x20a0 irq 19
[ 1.201456] ata4: SATA max UDMA/133 cmd 0x20c0 ctl 0x20e0 bmdma 0x20a8 irq 19
[ 1.201682] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.201691] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.201760] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.201857] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[ 1.201968] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.201973] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.201977] usb usb3: Product: UHCI Host Controller
[ 1.201981] usb usb3: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.201984] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.208117] hub 3-0:1.0: USB hub found
[ 1.208136] hub 3-0:1.0: 2 ports detected
[ 1.213249] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.213257] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.213420] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.213593] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[ 1.213692] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.213698] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.213702] usb usb4: Product: UHCI Host Controller
[ 1.213705] usb usb4: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.213709] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.221148] hub 4-0:1.0: USB hub found
[ 1.221165] hub 4-0:1.0: 2 ports detected
[ 1.225423] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.225431] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.225531] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.225666] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[ 1.225770] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.225775] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.225780] usb usb5: Product: UHCI Host Controller
[ 1.225783] usb usb5: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.225786] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.232569] hub 5-0:1.0: USB hub found
[ 1.232615] hub 5-0:1.0: 2 ports detected
[ 1.240206] firewire_ohci: Added fw-ohci device 0000:05:05.0, OHCI v1.10, 4 IR + 8 IT contexts, quirks 0x2
[ 1.312331] ata1.00: ATAPI: HL-DT-ST DVDRAM GSA-4167B, DL11, max UDMA/33
[ 1.328210] ata1.00: configured for UDMA/33
[ 1.334877] scsi 0:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-4167B DL11 PQ: 0 ANSI: 5
[ 1.367294] ata3.00: ATA-8: WDC WD5000AAKS-07V0A0, 05.01D05, max UDMA/133
[ 1.367301] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.380388] ata3.00: configured for UDMA/133
[ 1.380563] scsi 2:0:0:0: Direct-Access ATA WDC WD5000AAKS-0 05.0 PQ: 0 ANSI: 5
[ 1.424775] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.424783] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.425768] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.426448] sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.426612] sd 2:0:0:0: [sda] Write Protect is off
[ 1.426619] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.426687] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.431542] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.431721] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1.467769] sda: sda1 sda2 < sda5 >
[ 1.468641] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.712030] Refined TSC clocksource calibration: 2799.995 MHz.
[ 1.712040] Switching to clocksource tsc
[ 1.740221] firewire_core: created device fw0: GUID 0090270001980d0d, S400
[ 1.880028] usb 4-1: new full-speed USB device number 2 using uhci_hcd
[ 2.053661] usb 4-1: New USB device found, idVendor=058f, idProduct=9360
[ 2.053668] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.053673] usb 4-1: Product: USB Reader
[ 2.053676] usb 4-1: Manufacturer:
[ 2.053680] usb 4-1: SerialNumber: 2004888
[ 2.061931] Initializing USB Mass Storage driver...
[ 2.062187] scsi4 : usb-storage 4-1:1.0
[ 2.062380] usbcore: registered new interface driver usb-storage
[ 2.062385] USB Mass Storage support registered.
[ 2.232867] PM: Starting manual resume from disk
[ 2.232875] PM: Hibernation image partition 8:5 present
[ 2.232879] PM: Looking for hibernation image.
[ 2.233240] PM: Image not found (code -22)
[ 2.233244] PM: Hibernation image not present or could not be loaded.
[ 2.371433] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.064705] scsi 4:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 3.067700] scsi 4:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 3.070700] scsi 4:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 3.073699] scsi 4:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 3.075161] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 3.075590] sd 4:0:0:1: Attached scsi generic sg3 type 0
[ 3.076113] sd 4:0:0:2: Attached scsi generic sg4 type 0
[ 3.076589] sd 4:0:0:3: Attached scsi generic sg5 type 0
[ 3.109698] sd 4:0:0:2: [sdd] Attached SCSI removable disk
[ 3.124697] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 3.128697] sd 4:0:0:3: [sde] Attached SCSI removable disk
[ 3.133687] sd 4:0:0:1: [sdc] Attached SCSI removable disk
[ 4.079765] udevd[356]: starting version 175
[ 4.493730] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 4.493746] ACPI: Sleep Button [SLPB]
[ 4.512704] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 4.512717] ACPI: Power Button [PWRF]
[ 4.536202] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 4.575844] intel_rng: Firmware space is locked read-only. If you can't or
[ 4.575847] intel_rng: don't want to disable this in firmware setup, and if
[ 4.575849] intel_rng: you are certain that your system has a functional
[ 4.575851] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 4.697914] iTCO_vendor_support: vendor-support=0
[ 4.744684] [drm] Initialized drm 1.1.0 20060810
[ 4.886668] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 4.886903] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[ 4.887023] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.987387] leds_ss4200: no LED devices found
[ 5.180395] wmi: Mapper loaded
[ 5.442403] nouveau 0000:01:00.0: setting latency timer to 64
[ 5.442434] [drm] nouveau 0000:01:00.0: Detected an NV40 generation card (0x046100a3)
[ 5.445637] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 5.549543] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 5.549551] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 5.549588] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 5.549595] [drm] nouveau 0000:01:00.0: Bios version 05.72.22.49
[ 5.549601] [drm] nouveau 0000:01:00.0: TMDS table version 1.1
[ 5.549606] [drm] nouveau 0000:01:00.0: TMDS table script pointers not stubbed
[ 5.559414] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 5.559421] [drm] nouveau 0000:01:00.0: DCB version 3.0
[ 5.559427] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000300 00000028
[ 5.559432] [drm] nouveau 0000:01:00.0: DCB outp 01: 02011310 00000028
[ 5.559436] [drm] nouveau 0000:01:00.0: DCB outp 02: 01011312 00000000
[ 5.559442] [drm] nouveau 0000:01:00.0: DCB outp 03: 020223f1 00c0c080
[ 5.559446] [drm] nouveau 0000:01:00.0: DCB conn 00: 0000
[ 5.559452] [drm] nouveau 0000:01:00.0: DCB conn 01: 2130
[ 5.559457] [drm] nouveau 0000:01:00.0: DCB conn 02: 0210
[ 5.559463] [drm] nouveau 0000:01:00.0: DCB conn 03: 0211
[ 5.559469] [drm] nouveau 0000:01:00.0: DCB conn 04: 0213
[ 5.559480] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD25F
[ 5.559587] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xD58E
[ 5.574763] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xDB2C
[ 5.574793] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xDCA7
[ 5.575953] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xDF00
[ 5.577775] [TTM] Zone kernel: Available graphics memory: 1545838 kiB
[ 5.577781] [TTM] Initializing pool allocator
[ 5.578606] [TTM] Initializing DMA pool allocator
[ 5.579796] [drm] nouveau 0000:01:00.0: Detected 128MiB VRAM (DDR2)
[ 5.592408] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 5.594945] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 5.664194] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[ 5.679146] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 5.679152] [drm] No driver support for vblank timestamp query.
[ 5.688959] [drm] nouveau 0000:01:00.0: 1 available performance level(s)
[ 5.688969] [drm] nouveau 0000:01:00.0: 0: core 450MHz shader 450MHz memory 648MHz fanspeed 100%
[ 5.688975] [drm] nouveau 0000:01:00.0: c: core 199MHz memory 391MHz
[ 5.691067] [drm] nouveau 0000:01:00.0: 0xC61E: Parsing digital output script table
[ 5.744409] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 3)
[ 5.860814] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x49000, bo ffff880036ecf800
[ 5.860981] fbcon: nouveaufb (fb0) is primary device
[ 5.881814] Console: switching to colour frame buffer device 160x64
[ 5.884506] fb0: nouveaufb frame buffer device
[ 5.884510] drm: registered panic notifier
[ 5.884519] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 7.290177] Adding 6286332k swap on /dev/sda5. Priority:-1 extents:1 across:6286332k
[ 7.323760] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 7.566761] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.723720] loop: module loaded
[ 9.253774] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.256171] e100 0000:05:08.0: eth0: NIC Link is Up 100 Mbps Full Duplex
[ 9.269198] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.865948] RPC: Registered named UNIX socket transport module.
[ 9.865955] RPC: Registered udp transport module.
[ 9.865958] RPC: Registered tcp transport module.
[ 9.865962] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 9.914205] FS-Cache: Loaded
[ 9.977153] FS-Cache: Netfs 'nfs' registered for caching
[ 9.989792] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.263659] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 13.698846] Bluetooth: Core ver 2.16
[ 13.698891] NET: Registered protocol family 31
[ 13.698898] Bluetooth: HCI device and connection manager initialized
[ 13.698905] Bluetooth: HCI socket layer initialized
[ 13.698910] Bluetooth: L2CAP socket layer initialized
[ 13.698928] Bluetooth: SCO socket layer initialized
[ 13.761197] Bluetooth: RFCOMM TTY layer initialized
[ 13.761210] Bluetooth: RFCOMM socket layer initialized
[ 13.761215] Bluetooth: RFCOMM ver 1.11
[ 13.920324] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.920331] Bluetooth: BNEP filters: protocol multicast
[ 14.411106] lp: driver loaded but no devices found
[ 14.434401] ppdev: user-space parallel port driver
[ 20.096014] eth0: no IPv6 routers present
[ 3677.167223] ip_tables: (C) 2000-2006 Netfilter Core Team
[10138.760026] usb 1-4: new high-speed USB device number 3 using ehci_hcd
[10139.010483] usb 1-4: New USB device found, idVendor=1b1c, idProduct=1ab1
[10139.010490] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[10139.010495] usb 1-4: Product: Voyager
[10139.010498] usb 1-4: Manufacturer: Corsair
[10139.010501] usb 1-4: SerialNumber: AA00000000000070
[10139.011046] scsi5 : usb-storage 1-4:1.0
[10140.479308] scsi 5:0:0:0: Direct-Access Corsair Voyager 1100 PQ: 0 ANSI: 0 CCS
[10140.483659] sd 5:0:0:0: Attached scsi generic sg6 type 0
[10141.565640] sd 5:0:0:0: [sdf] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB)
[10141.566763] sd 5:0:0:0: [sdf] Write Protect is off
[10141.566770] sd 5:0:0:0: [sdf] Mode Sense: 43 00 00 00
[10141.567877] sd 5:0:0:0: [sdf] No Caching mode page found
[10141.567884] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[10141.572131] sd 5:0:0:0: [sdf] No Caching mode page found
[10141.572138] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[10141.573161] sdf: sdf1
[10141.576386] sd 5:0:0:0: [sdf] No Caching mode page found
[10141.576395] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[10141.576402] sd 5:0:0:0: [sdf] Attached SCSI removable disk
[10143.730688] FAT-fs (sdf1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[10335.241993] usb 1-4: USB disconnect, device number 3
debian@debian:~$
debian@debian:~$ dmesg
[12749.312024] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[12749.562427] usb 1-4: New USB device found, idVendor=1b1c, idProduct=1ab1
[12749.562434] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[12749.562439] usb 1-4: Product: Voyager
[12749.562442] usb 1-4: Manufacturer: Corsair
[12749.562446] usb 1-4: SerialNumber: AA00000000000070
[12749.563771] scsi6 : usb-storage 1-4:1.0
[12750.660105] scsi 6:0:0:0: Direct-Access Corsair Voyager 1100 PQ: 0 ANSI: 0 CCS
[12750.664588] sd 6:0:0:0: Attached scsi generic sg6 type 0
[12750.664709] sd 6:0:0:0: [sdf] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB)
[12750.665828] sd 6:0:0:0: [sdf] Write Protect is off
[12750.665835] sd 6:0:0:0: [sdf] Mode Sense: 43 00 00 00
[12750.666948] sd 6:0:0:0: [sdf] No Caching mode page found
[12750.666957] sd 6:0:0:0: [sdf] Assuming drive cache: write through
[12750.671955] sd 6:0:0:0: [sdf] No Caching mode page found
[12750.671963] sd 6:0:0:0: [sdf] Assuming drive cache: write through
[12750.673239] sdf: sdf1
[12750.679823] sd 6:0:0:0: [sdf] No Caching mode page found
[12750.679832] sd 6:0:0:0: [sdf] Assuming drive cache: write through
[12750.679839] sd 6:0:0:0: [sdf] Attached SCSI removable disk
[12750.942377] FAT-fs (sdf1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
debian@debian:~$
debian@debian:~$ halcmd show pin
Component Pins:
Owner Type Dir Value Name
debian@debian:~$
debian@debian:~$ halcmd show param
Component Pins:
debian@debian:~$
Last edit: 06 Mar 2017 00:46 by andypugh.
05 Mar 2017 22:28 #89064
Replied by PCW on topic Mesa 7i92M Support
Notice the first two columns of number in the pinout listing of P2?
The first number is the DB25 equivalent parallel port pin number and the second is the
GPIO number used on the HAL file to address the pin.
So for example if you had a limit switch connected to DB25 pin 10, that would be GPIO013 in the hal file
so hm2_7i92.0.gpio.013.in (or perhaps hm2_7i92.0.gpio.013.in_not if the inverted version was needed)
Did you fix the missing IP address issue? if there are no pins shown by halcmd that suggests
that the driver did not load.
- tuffduck33
05 Mar 2017 23:05 #89067
by tuffduck33
Okay I understand the first 2 paragraphs of the relationship of parallel port pin number and the GPIO number. I have a list of all of the pin assignments from the old stepgen. Do these pin numbers correspond to the the parallel port pins?
Yes, I did add IP address into the ini file as
DRIVER=hm2_eth board_ip="10.10.10.10"
BOARD=7i92
CONFIG="num_encoders=0 num_stepgens=5"
and added this to the hal file. loadrt hm2_eth board_ip="10.10.10.10"
What did I miss?
BOARD=7i92
What did I miss?
05 Mar 2017 23:32 #89068
Yes, in parallel port configurations the I/O pins of hal_parport component are named by DB25 pin number
Also need either:
CONFIG-"whatever"
in you ini file
and
loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG)
in your hal file
_OR_
loadrt hm2_eth board_ip="10.10.10.10" config="whatever"
in your hal file
but not both
Which you need depends on your hal/ini structure (whether the driver config information is in the hal or ini file)
can you post you _current_ hal/ini files?
Also need either:
CONFIG-"whatever"
in you ini file
and
in your hal file
_OR_
in your hal file
but not both
- tuffduck33
05 Mar 2017 23:40 - 06 Mar 2017 00:48 #89069
by tuffduck33
Okay
The hal file is:
The ini file is
The message that comes up when I run the linuxcnc gui is : (I am guessing the GIPO pin references are missing?)
The hal file is:
# Generated by PNCconf at Fri Feb 24 20:17:55 2017
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i92.0.write servo-thread
# --- ESTOP-OUT ---
net estop-out hm2_7i92.0.gpio.000.in
# --- SPINDLE-CW ---
net spindle-cw hm2_7i92.0.gpio.001.in
# --- CHARGE-PUMP ---
net charge-pump hm2_7i92.0.gpio.005.in
# ---G540 Charge Pump---
setp hm2_7i92.0.stepgen.04.steplen 50000
setp hm2_7i92.0.stepgen.04.position-scale 1
setp hm2_7i92.0.stepgen.04.step_type 0
setp hm2_7i92.0.stepgen.04.control-type 1
setp hm2_7i92.0.stepgen.04.velocity-cmd 10000
net machine-is-enabled => hm2_7i92.0.stepgen.04.enable
# external input signals
# --- JOG-X-POS ---
net jog-x-pos <= hm2_7i92.0.gpio.004.in
# --- JOG-Y-NEG ---
net jog-y-neg <= hm2_7i92.0.gpio.008.in_not
# --- JOG-Z-POS ---
net jog-z-pos <= hm2_7i92.0.gpio.010.in
# --- JOG-A-POS ---
net jog-a-pos <= hm2_7i92.0.gpio.012.in
# --- HOME-X ---
net home-x <= hm2_7i92.0.gpio.014.in
# --- HOME-Y ---
net home-y <= hm2_7i92.0.gpio.015.in
# --- HOME-Z ---
net home-z <= hm2_7i92.0.gpio.016.in
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i92.0.stepgen.01.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i92.0.stepgen.01.dirhold [AXIS_0]DIRHOLD
setp hm2_7i92.0.stepgen.01.steplen [AXIS_0]STEPLEN
setp hm2_7i92.0.stepgen.01.stepspace [AXIS_0]STEPSPACE
setp hm2_7i92.0.stepgen.01.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i92.0.stepgen.01.step_type 0
setp hm2_7i92.0.stepgen.01.control-type 1
setp hm2_7i92.0.stepgen.01.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.01.maxvel [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output <= hm2_7i92.0.stepgen.01.velocity-cmd
net x-pos-fb <= hm2_7i92.0.stepgen.01.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_7i92.0.stepgen.01.enable
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i92.0.stepgen.02.dirsetup [AXIS_1]DIRSETUP
setp hm2_7i92.0.stepgen.02.dirhold [AXIS_1]DIRHOLD
setp hm2_7i92.0.stepgen.02.steplen [AXIS_1]STEPLEN
setp hm2_7i92.0.stepgen.02.stepspace [AXIS_1]STEPSPACE
setp hm2_7i92.0.stepgen.02.position-scale [AXIS_1]STEP_SCALE
setp hm2_7i92.0.stepgen.02.step_type 0
setp hm2_7i92.0.stepgen.02.control-type 1
setp hm2_7i92.0.stepgen.02.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.02.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd <= axis.1.motor-pos-cmd
net y-vel-cmd <= axis.1.joint-vel-cmd
net y-output <= hm2_7i92.0.stepgen.02.velocity-cmd
net y-pos-fb <= hm2_7i92.0.stepgen.02.position-fb
net y-pos-fb => axis.1.motor-pos-fb
net y-enable <= axis.1.amp-enable-out
net y-enable => hm2_7i92.0.stepgen.02.enable
net home-y => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i92.0.stepgen.03.dirsetup [AXIS_2]DIRSETUP
setp hm2_7i92.0.stepgen.03.dirhold [AXIS_2]DIRHOLD
setp hm2_7i92.0.stepgen.03.steplen [AXIS_2]STEPLEN
setp hm2_7i92.0.stepgen.03.stepspace [AXIS_2]STEPSPACE
setp hm2_7i92.0.stepgen.03.position-scale [AXIS_2]STEP_SCALE
setp hm2_7i92.0.stepgen.03.step_type 0
setp hm2_7i92.0.stepgen.03.control-type 1
setp hm2_7i92.0.stepgen.03.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.03.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output <= hm2_7i92.0.stepgen.03.velocity-cmd
net z-pos-fb <= hm2_7i92.0.stepgen.03.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_7i92.0.stepgen.03.enable
net home-z => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---charge pump signals---
net estop-out => charge-pump.enable
net charge-pump <= charge-pump.out
# ---coolant signals---
#net coolant-mist <= iocontrol.0.coolant-mist
#net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
#net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
The ini file is
[HOSTMOT2]
#DRIVER=hm2_eth board_ip="192.168.1.121"
BOARD=7i92
[EMC]
# Name of machine, for use with display, etc.
MACHINE = HM2-Stepper
# Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others
#DEBUG = 0x00000003
#DEBUG = 0x00000007
DEBUG = 1
[DISPLAY]
# Name of display program, e.g., tkemc
#DISPLAY = tkemc
DISPLAY = axis
# Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME = 0.100
# Path to help file
HELP_FILE = tkemc.txt
# Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET = RELATIVE
# Initial display setting for position, COMMANDED or ACTUAL
POSITION_FEEDBACK = ACTUAL
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 30
# Prefix to be used
PROGRAM_PREFIX = ../../nc_files/
# Introductory graphic
INTRO_TIME = 5
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
# Name of task controller program, e.g., milltask
TASK = milltask
# Cycle time, in seconds, that task controller will sleep between polls
CYCLE_TIME = 0.010
[RS274NGC]
# File containing interpreter variables
PARAMETER_FILE = hm2-stepper.var
[EMCMOT]
EMCMOT = motmod
# Timeout for comm to emcmot, in seconds
COMM_TIMEOUT = 1.0
# Interval between tries to emcmot, in seconds
COMM_WAIT = 0.010
# Servo task period, in nanoseconds
SERVO_PERIOD = 1000000
[HAL]
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALFILE = LinuxCNC_Mesa7i92.hal
# list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD = save neta
[TRAJ]
AXES = 3
COORDINATES = X Y Z
#HOME = 0 0 0
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.001
[AXIS_0]
# Step timing is 2.5 us steplen + 2.5 us stepspace
# That gives 5 us step period = 200 KHz max step freq
# Scale is 2000 steps/rev * 5 revs/inch = 10000 steps/inch
# This gives a maxvel of 200000/10000 = 20 ips
TYPE = LINEAR
MAX_VELOCITY = 15
MAX_ACCELERATION = 100
# Set Stepgen max 20% higher than the axis
STEPGEN_MAX_VEL = 18
STEPGEN_MAX_ACC = 120
BACKLASH = 0.000
# scale is 2000 steps/rev * 4.9875 revs/inch
SCALE = 9970
MIN_LIMIT = -30.0
MAX_LIMIT = 30.0
FERROR = .0002
MIN_FERROR = .0001
#HOME = 0.000
#HOME_OFFSET = 0.10
#HOME_SEARCH_VEL = 0.10
#HOME_LATCH_VEL = -0.01
#HOME_USE_INDEX = YES
#HOME_IGNORE_LIMITS = YES
# these are in nanoseconds
DIRSETUP = 2000
DIRHOLD = 2000
STEPLEN = 2500
STEPSPACE = 2500
# PID tuning params
DEADBAND = 0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.00011
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 0.0005
[AXIS_1]
TYPE = LINEAR
MAX_VELOCITY = 15
BACKLASH = 0.000
SCALE = 10000
MIN_LIMIT = -30.0
MAX_LIMIT = 30.0
FERROR = .0002
MIN_FERROR = .0001
#HOME = 0.000
#HOME_OFFSET = 0.10
DIRSETUP = 2000
DIRHOLD = 2000
STEPLEN = 2500
STEPSPACE = 2500
# PID tuning params
DEADBAND = 0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.00011
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 0.0005
[AXIS_2]
TYPE = LINEAR
MAX_VELOCITY = 15
BACKLASH = 0.000
SCALE = 10000
MIN_LIMIT = -30.0
MAX_LIMIT = 30.0
FERROR = .0002
MIN_FERROR = .0001
#HOME = 0.000
#HOME_OFFSET = 0.10
DIRSETUP = 2000
DIRHOLD = 2000
STEPLEN = 2500
STEPSPACE = 2500
# PID tuning params
DEADBAND = 0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.00011
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 0.0005
[SPINDLE_9]
# PID tuning params
DEADBAND = 0
P = 50
I = 200
D = .2
FF0 = 0
FF1 = 0
FF2 = 0
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 50
SCALE = 6000
MINLIM = 0
MAXLIM = 6000
[EMCIO]
# Name of IO controller program, e.g., io
EMCIO = io
# cycle time, in seconds
CYCLE_TIME = 0.100
# tool table file
TOOL_TABLE = tool.tbl
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/debian/linuxcnc/configs/LinuxCNC_Mesa7i92'
Machine configuration file is 'LinuxCNC_Mesa7i92.ini'
INIFILE=/home/debian/linuxcnc/configs/LinuxCNC_Mesa7i92/LinuxCNC_Mesa7i92.ini
PARAMETER_FILE=hm2-stepper.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./LinuxCNC_Mesa7i92.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:13:00:32
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0: IO Pin 004 (P2-03): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): IOPort
hm2/hm2_7i92.0: IO Pin 008 (P2-05): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): Encoder #0, pin A (Input)
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Encoder #0, pin B (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Encoder #0, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): IOPort
hm2/hm2_7i92.0: IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0: IO Pin 018 (P1-14): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #5, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #5, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #9, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): StepGen #6, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0: IO Pin 025 (P1-05): StepGen #6, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): StepGen #7, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): StepGen #7, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 028 (P1-08): StepGen #8, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 029 (P1-09): StepGen #8, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 030 (P1-10): Encoder #1, pin A (Input)
hm2/hm2_7i92.0: IO Pin 031 (P1-11): Encoder #1, pin B (Input)
hm2/hm2_7i92.0: IO Pin 032 (P1-12): Encoder #1, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Killing task linuxcncsvr, PID=2021
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./LinuxCNC_Mesa7i92.hal:93: Ini variable '[AXIS_0]STEP_SCALE' not found.
2021
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[13429.122934] usb 1-4: USB disconnect, device number 4
[18428.844109] usb 1-4: new high-speed USB device number 5 using ehci_hcd
[18429.094535] usb 1-4: New USB device found, idVendor=1b1c, idProduct=1ab1
[18429.094542] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[18429.094546] usb 1-4: Product: Voyager
[18429.094550] usb 1-4: Manufacturer: Corsair
[18429.094553] usb 1-4: SerialNumber: AA00000000000070
[18429.095233] scsi7 : usb-storage 1-4:1.0
[18430.378735] scsi 7:0:0:0: Direct-Access Corsair Voyager 1100 PQ: 0 ANSI: 0 CCS
[18430.381784] sd 7:0:0:0: Attached scsi generic sg6 type 0
[18430.921071] sd 7:0:0:0: [sdg] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB)
[18430.922182] sd 7:0:0:0: [sdg] Write Protect is off
[18430.922188] sd 7:0:0:0: [sdg] Mode Sense: 43 00 00 00
[18430.923306] sd 7:0:0:0: [sdg] No Caching mode page found
[18430.923313] sd 7:0:0:0: [sdg] Assuming drive cache: write through
[18430.927682] sd 7:0:0:0: [sdg] No Caching mode page found
[18430.927690] sd 7:0:0:0: [sdg] Assuming drive cache: write through
[18430.928720] sdg: sdg1
[18430.934828] sd 7:0:0:0: [sdg] No Caching mode page found
[18430.934837] sd 7:0:0:0: [sdg] Assuming drive cache: write through
[18430.934845] sd 7:0:0:0: [sdg] Attached SCSI removable disk
[18433.196501] FAT-fs (sdg1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[19172.200836] usb 1-4: USB disconnect, device number 5
[20044.632022] usb 1-4: new high-speed USB device number 6 using ehci_hcd
[20044.882526] usb 1-4: New USB device found, idVendor=1b1c, idProduct=1ab1
[20044.882534] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[20044.882539] usb 1-4: Product: Voyager
[20044.882542] usb 1-4: Manufacturer: Corsair
[20044.882546] usb 1-4: SerialNumber: AA00000000000070
[20044.883302] scsi8 : usb-storage 1-4:1.0
[20046.846977] scsi 8:0:0:0: Direct-Access Corsair Voyager 1100 PQ: 0 ANSI: 0 CCS
[20046.849074] sd 8:0:0:0: Attached scsi generic sg6 type 0
[20047.928443] sd 8:0:0:0: [sdg] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB)
[20047.929554] sd 8:0:0:0: [sdg] Write Protect is off
[20047.929561] sd 8:0:0:0: [sdg] Mode Sense: 43 00 00 00
[20047.930679] sd 8:0:0:0: [sdg] No Caching mode page found
[20047.930686] sd 8:0:0:0: [sdg] Assuming drive cache: write through
[20049.553425] sd 8:0:0:0: [sdg] No Caching mode page found
[20049.553433] sd 8:0:0:0: [sdg] Assuming drive cache: write through
[20049.554459] sdg: sdg1
[20049.557924] sd 8:0:0:0: [sdg] No Caching mode page found
[20049.557932] sd 8:0:0:0: [sdg] Assuming drive cache: write through
[20049.557940] sd 8:0:0:0: [sdg] Attached SCSI removable disk
[20049.789982] FAT-fs (sdg1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Last edit: 06 Mar 2017 00:48 by andypugh.
05 Mar 2017 23:59 #89070
The error:
Means you have got a mis-matched set of hal/ini files
(it looks like a Mesa sample ini file and a pncconf created hal file)
These are not going to agree on variable names...
- Thank you received: 5928
05 Mar 2017 23:59 #89071
Replied by tommylight on topic Mesa 7i92M Support
In the ini file you have scale for all 3 axis, but the step_scale is missing for all 3 of them, just add them.
I just got out my 7i92 and will do some testing tomorrow.
- tuffduck33
06 Mar 2017 00:19 #89072
by tuffduck33
Not sure how I managed that but I did. Best course of action? Create new files from pncconf ?
06 Mar 2017 00:52 #89073
I would say "go back to the config where most things worked" which I think was a Mesa sample config without a working charge pump?
That was close, you seem to have gone backwards since.
PnCConf is definitely no longer your friend at this point.
Time to create page: 0.423 seconds
