Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
14 Aug 2018 10:19 #116028
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
OK, I think it works.
1:st part with halcompile gearblokcer.comp no errors
2:nd part with halcompile --compile gearblocker.comp there is a list of errors See enclosed compile.txt
Is all OK or not?
Is all OK or not?
14 Aug 2018 10:51 - 14 Aug 2018 10:52 #116030
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
No, there are typos and errors in the file.
Firstly, I have copy-and-paste errors, the cases should be 1, 2, 4, 8, 16, default
"case else" is wrong. it should be "default:" I have been coding too much Visual Basic recently, and that is the VB equivalent.
Also, I have got some of the internal names of the pins mixed up (should be gear_min_speed() )
I also spotted an off-by-one error in the gear numbering (the HAL pins always start at zero, so we need to number gears from zero)
Last edit: 14 Aug 2018 10:52 by andypugh.
14 Aug 2018 10:58 #116032
Replied by rodw on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Andy, a very nice piece of code. You are better than me! I refuse to do anything in Visual Basic!
14 Aug 2018 11:26 #116034
by tecno
14 Aug 2018 12:01 #116036
Andy's left some typos so you can learn more about C coding
Change Line 47 to:
The error tells you exactly the problem
gearblocker.comp:47:23: error: ‘spindle_speed_’ undeclared (first use in this function)
spindle_speed_’ should be spindle_speed_in’
Change Line 47 to:
motor_speed_out = spindle_speed_in * gear_ratio(gear);
14 Aug 2018 12:10 - 14 Aug 2018 12:11 #116038
by tecno
bengt@debian:~/linuxcnc$ halcompile --compile gearblocker.comp
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
CC [M] /tmp/tmpnTwZlQ/gearblocker.o
gearblocker.comp: In function ‘_’:
gearblocker.comp:23:5: warning: unused variable ‘i’ [-Wunused-variable]
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmpnTwZlQ/gearblocker.mod.o
LD [M] /tmp/tmpnTwZlQ/gearblocker.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
I got a .ko file now so I assume all is OK even with above warning?
MODPOST 1 modules
Last edit: 14 Aug 2018 12:11 by tecno.
14 Aug 2018 12:21 #116040
by tecno
FUNCTION(_){
int i; <<<<<<<<<<<<<<<<<<<<<<<<<<<<<< delete this line ?
14 Aug 2018 12:47 #116043
by tecno
No warning after deleting that line.
Now to fiddle with HAL
14 Aug 2018 13:07 #116044
by tecno
I have added following lines to HAL
So how to do with following lines in COMP
# gearbox input signals
# gearbox Hi/Lo
net gearblocker.0.high-gear <= hm2_7i76e.0.7i76.0.0.input-15
# gearbox A - B - C - D - E
net gearblocker.0.gear-A <= hm2_7i76e.0.7i76.0.0.input-10
net gearblocker.0.gear-B <= hm2_7i76e.0.7i76.0.0.input-11
net gearblocker.0.gear-C <= hm2_7i76e.0.7i76.0.0.input-12
net gearblocker.0.gear-D <= hm2_7i76e.0.7i76.0.0.input-13
net gearblocker.0.gear-E <= hm2_7i76e.0.7i76.0.0.input-14
loadrt gearblocker
addf gearblocker.0 servo-thread
component gearblocker;
pin in bit spindle-enable-in;
pin out bit spindle-enable-out;
pin in float spindle-speed-in;
pin out float motor-speed-out;
pin in float gear.#.min-speed[10];
pin in float gear.#.max-speed[10];
pin in float gear.#.ratio[10];
14 Aug 2018 13:22 #116045
Yeh, you've done the right thing. It was just C politely telling you there was a variable that had not been used.
Warnings are basically telling you there is a problem that might be a problem but its not a fatal error so it will compile OK. Its best to eliminate them though as sometimes they can bite you.
FUNCTION(_){
Time to create page: 0.199 seconds
