Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
16 Aug 2018 13:07 #116138
There is no problem running a loop that can only ever execute 10 times. like this one.
The problem is any loop that can potentially wait an unknown and long time.
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
I'm not a fan of ever using for() loop in an interrupt service routine (which is what the servo-thread is).
16 Aug 2018 13:11 #116140
HAL_label looks like it could display the required gear:
linuxcnc.org/docs/2.7/html/gui/gladevcp.html#gladevcp:hal-label
But a telltale LED on the high / low and ABCDE levers when a gear change is needed would be cooler.
The gear you need is an "int pin". It must be possible to get the int from that pin into the glade view. "Must" as in "I guess".
16 Aug 2018 13:12 #116141
Did you figure out that you need to "setp" all the speed limits and gear ratios to the correct values in the HAL file?
16 Aug 2018 13:13 #116142
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
No
16 Aug 2018 13:15 #116143
by tecno
Yes I agree that this would be very cool to have.
16 Aug 2018 13:27 #116148
OK, well, you need to "setp" all the speed limit and ratio pins before it will work properly
No
16 Aug 2018 13:57 #116151
by tecno
So it is following net signals that need to be setp ?
# gearbox input signals
# gearbox Hi/Lo
net gearblocker.0.high-gear <= hm2_7i76e.0.7i76.0.0.input-15
# gearbox A - B - C - D - E
net gearblocker.0.gear-A <= hm2_7i76e.0.7i76.0.0.input-10
net gearblocker.0.gear-B <= hm2_7i76e.0.7i76.0.0.input-11
net gearblocker.0.gear-C <= hm2_7i76e.0.7i76.0.0.input-12
net gearblocker.0.gear-D <= hm2_7i76e.0.7i76.0.0.input-13
net gearblocker.0.gear-E <= hm2_7i76e.0.7i76.0.0.input-14
Any example to kick me on the right track
Will be on and off next few days as hunting season started today here.
# gearbox Hi/Lo
16 Aug 2018 13:59 #116152
No, those nets are correct, butt here are 30 other pins to set the values of.
16 Aug 2018 14:02 #116153
by tecno
30 ???
16 Aug 2018 14:13 #116158
Yes. You have 10 gears and each has a max, min and gear ratio pin.
Time to create page: 0.379 seconds
