Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
19 Aug 2018 06:41 #116291
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Hi Rod,
Still hangs on 'for'
19 Aug 2018 08:15 #116292
by tecno
After your edit
Line 46 = mixed declarations
gearengaded is undeclared
Its best practice to define variables at the head of the function. The exception might be if you have a low memory environment.
I don't think the halcompile environment likes a definition of the loop variable in the for statement. Also you are mixing types by assigning an int (geartouse) to a long (eg. S32) so try this:
FUNCTION(_) { static double speeds[7][2] = { { 160.0, 80.0}, { 270.0, 160.0}, { 450.0, 270.0}, { 750.0, 450.0}, {1250.0, 750.0}, {1500.0, 1250.0}, {2500.0, 1500.0}, }; // Gears are number from 1 (lowest) to 7 // Check which gear to use with this speed Sxxx long geartouse = -1; int i; for (i=0; i<7; i++) { if (speed <= speeds[i][0] && speed > speeds[i][1]) geartouse = (long) i+1L; } // Which gear is engaged int gearengaged = 1*input_a + 2*input_b + 3*input_c + 4*input_d + 5*input_e + 5*higear; if (geartouse == gearengaged) { // Everything ok gearshift = 0; wantedgear = gearengaged; speedratio = speed/speeds[gearenaged-1][0]; } else { // Should change gear gearshift = 1; wantedgear = geartouse; speedratio = speed/speeds[(int)geartouse-1][0]; } }
I'm not sure if halcompile will like 1L which signifies 1 is a long type. If it complains, try "(long) 1" instead
OOPS just edited as an explicit typedef is required on the line where speedratio is defined.
After your edit
19 Aug 2018 09:08 - 19 Aug 2018 09:22 #116293
by Hakan
Replied by Hakan on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
I added the ratios here and started with a very rudimentary error check on the inputs. Also the enable_in/out signal added.
It compiles fine here on "master".
component gearbox3 "LinuxCNC HAL component for Tecno's gearbox";
author "Rod Webster Hakan Bastedt";
pin in bit input_a "input a";
pin in bit input_b "input b";
pin in bit input_c "input c";
pin in bit input_d "input d";
pin in bit input_e "input e";
pin in bit higear "true if in high gear";
pin in bit enable_in "Enable signal. Input";
pin out bit enable_out "Enable signal. Output";
pin in float speed "Spindle speed in RPM as in Sxxx";
pin out bit gearshift "Need to shift gear, true if high";
pin out s32 wantedgear "Shift to this gear if told so";
pin out float speedratio "max RPM for machine divided by maximum RPM for gear";
param rw float maxrpm "maximum RPM for machine";
function _;
license "GPL";
#include <rtapi_math.h>
FUNCTION(_) {
{ 160.0, 80.0},
{ 270.0, 160.0},
{ 450.0, 270.0},
{ 750.0, 450.0},
{1250.0, 750.0},
{1500.0, 1250.0},
{2500.0, 1500.0},
static double ratios[7] = {
0.064, 0.108, 0.18, 0.3, 0.5, 0.6, 1.0};
int geartouse = -1;
int i;
geartouse = i+1;
// Is at least one of the inputs active? Calculate gear from inputs.
int inputs_sum = 1*input_a + 2*input_b + 3*input_c + 4*input_d + 5*input_e;
int gearengaged;
if (higear)
gearengaged = inputs_sum + 2; // inputs_sum 4,5 => gear 6,7
else
gearengaged = inputs_sum; // inputs_sum 1,2,3,4,5 => gear 1,2,3,4,5
if (inputs_sum > 0 && geartouse == gearengaged) { // Everything ok
gearshift = 0;
speedratio = ratios[gearengaged-1];
enable_out = enable_in;
gearshift = 1;
speedratio = ratios[geartouse-1];
enable_out = 0;
$ halcompile --compile gearbox3.comp
Compiling realtime gearbox3.c
Linking gearbox3.so
Last edit: 19 Aug 2018 09:22 by Hakan.
19 Aug 2018 09:24 #116294
by tecno
Does not compile here on 2.7.14
author "Rod Webster Håkan Båstedt";
function _;
license "GPL";
FUNCTION(_) {
{ 160.0, 80.0},
{ 270.0, 160.0},
{ 450.0, 270.0},
{ 750.0, 450.0},
{1250.0, 750.0},
{1500.0, 1250.0},
{2500.0, 1500.0},
int geartouse = -1;
int i;
geartouse = i+1;
int gearengaged;
if (higear)
else
gearshift = 0;
gearshift = 1;
enable_out = 0;
bengt@debian:~/linuxcnc/configs/sim.gmoccapy$ halcompile --compile gearbox3.comp
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
CC [M] /tmp/tmpQ__mt1/gearbox3.o
gearbox3.comp: In function ‘_’:
gearbox3.comp:48:3: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmpQ__mt1/gearbox3.mod.o
LD [M] /tmp/tmpQ__mt1/gearbox3.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
19 Aug 2018 09:31 - 19 Aug 2018 09:32 #116295
by Hakan
Ok, I think i am a bit C++-centric.
Changeto
Also change the line with inputs_sum.
Change
int geartouse = -1;
int geartouse;
geartouse = -1;
Last edit: 19 Aug 2018 09:32 by Hakan.
19 Aug 2018 09:33 - 19 Aug 2018 09:34 #116296
by tecno
bengt@debian:~/linuxcnc/configs/sim.gmoccapy$ halcompile --compile gearbox3.compmake KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
CC [M] /tmp/tmpMfZqkR/gearbox3.o
gearbox3.comp:42:3: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
gearbox3.comp:49:3: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
MODPOST 1 modules
CC /tmp/tmpMfZqkR/gearbox3.mod.o
LD [M] /tmp/tmpMfZqkR/gearbox3.ko
MODPOST 1 modules
Last edit: 19 Aug 2018 09:34 by tecno.
19 Aug 2018 09:37 - 19 Aug 2018 09:37 #116299
by Hakan
And move declarations ofto before the for loop, together with the other declarations.
inputs_sum
gearengaged
Last edit: 19 Aug 2018 09:37 by Hakan.
19 Aug 2018 09:52 #116300
by tecno
Now it compiled, did move int i;
FUNCTION(_) {
int i;
FUNCTION(_) {
int i;
CC [M] /tmp/tmpWxGYMf/gearbox3.o
MODPOST 1 modules
CC /tmp/tmpWxGYMf/gearbox3.mod.o
LD [M] /tmp/tmpWxGYMf/gearbox3.ko
19 Aug 2018 10:03 #116301
Replied by rodw on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
You guys have still got a type mismatch on this lineassigning an int to an s32 which is a long. Refer my earlier post.
I've never had a problem with this style in components.IF its not compiling or its generating compiler warnings that a syntax error in your code
int geartouse = -1;
19 Aug 2018 10:08 #116302
by tecno
But it compiled as per last edits.
Time to create page: 0.437 seconds
