Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
17 Aug 2018 20:31 #116219
by Hakan
This is one of those areas where it is soo easy to make a problem. Index starting at 0 or 1.
Uhhm. I think you can replace the whole case-switch block withThis will directly calculate the engaged gear. You promise only one of the input_ABCDE is engaged at any given time?
The -1 is to make the indexing into speed_max, etc zero-based.
Replied by Hakan on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Think you found a bug there.Hmmm looking at .comp we have this
case 1: // Gear E
gear = (high_gear != 0) ? 5 : 10;
break;
Should it not be like this then? Hi gear is 5 and Lo gear is 10 right?
setp gearblocker.0.gear.10.min-speed 80
Sure somebody will correct us
gear = input_1 + 2*input_B + 3*input_C + 4*input_D + 5*input_E + 5*high_gear -1;
17 Aug 2018 20:32 #116220
by Hakan
You can test in a hal file to see if the syntax is correct.
But there are no pins called what you write above. Didn't it work in the way I wrote it?
Is this correct?
#GearShift Lo # E gear setp gearblocker.0.gear-E.min-speed 80 setp gearblocker.0.gear-E.max-speed 160 setp gearblocker.0.gear-E.ratio 0.064 # D gear setp gearblocker.0.gear-D.min-speed 160 setp gearblocker.0.gear-D.max-speed 270 setp gearblocker.0.gear-D.ratio 0.108 # C gear setp gearblocker.0.gear-C.min-speed 270 setp gearblocker.0.gear-C.max-speed 450 setp gearblocker.0.gear-C.ratio 0.18 # B gear setp gearblocker.0.gear-B.min-speed 450 setp gearblocker.0.gear-B.max-speed 750 setp gearblocker.0.gear-B.ratio 0.3 # A gear setp gearblocker.0.gear-A.min-speed 750 setp gearblocker.0.gear-A.max-speed 1250 setp gearblocker.0.gear-A.ratio 0.5 #GearShift Hi #B gear setp gerablocker.0.high_gear.gear-B.min-speed 1250 setp gerablocker.0.high_gear.gear-B.max-speed 11500 setp gearblocker.0.high_gear.gear-B.ratio 0.6 #A gear setp gerablocker.0.high_gear.gear-A.min-speed 1250 setp gerablocker.0.high_gear.gear-A.max-speed 11500 setp gearblocker.0.high_gear.gear-A.ratio 1
18 Aug 2018 00:29 #116228
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
On holiday and on the phone, so quoting is difficult.
The gears probably are switched,yes. As i explained I did it at lunchtime in a widows pc at work. It is entirely untested.
There are other ways to do it. I chose the switch block to explicitly reject invalid gear selections.
The single line calculation returns gear 5 if both B and C are selected. And that seems something to reject.
18 Aug 2018 10:42 #116242
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Relax and have fun on your holiday.
18 Aug 2018 10:44 #116243
by tecno
So down in my shop and trying to install linuxcnc-dev but no-go in my Mint installation. Need to get my comp file working.
Any clues what can be wrong?
sudo apt-get install linuxcnc-dev is what I try to use
18 Aug 2018 11:10 #116246
by tecno
Hmmm appears o be installed but again errors
bengt@CombiMll ~/linuxcnc/configs/CM_GEARBOX $ sudo halcompile --compile gearbox3.comp
File "/usr/bin/halcompile", line 1353, in <module>
main()
File "/usr/bin/halcompile", line 1322, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1192, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 417, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
Can you guys see what is wrong in the comp file
Cheers
Bengt
main()
Cheers
Bengt
18 Aug 2018 16:30 #116276
by tecno
Some progress, fixed some typos and now it complaints about this on line 12. We are making progress
pin out int wantedgear "Shift to this gear if told so";
Something with int
Something with int
component gearbox3 "LinuxCNC HAL component for Tecno's gearbox";
author "Rod Webster Håkan Båstedt";
pin in bit input_a "input a";
pin in bit input_b "input b";
pin in bit input_c "input c";
pin in bit input_d "input d";
pin in bit input_e "input e";
pin in bit higear "true if in high gear";
pin in float speed "Spindle speed in RPM as in Sxxx";
pin out bit gearshift "Need to shift gear, true if high";
pin out float speedratio "max RPM for machine divided by maximum RPM for gear";
param rw float maxrpm "maximum RPM for machine";
function _;
license "GPL";
#include <rtapi_math.h>
FUNCTION(_) {
static double speeds[7][2] = {
{ 160.0, 80.0}
{ 270.0, 160.0},
{ 450.0, 270.0},
{ 750.0, 450.0},
{1250.0, 750.0},
{1500.0, 1250.0},
{2500.0, 1500.0},
// Gears are number from 1 (lowest) to 7
// Check which gear to use with this speed Sxxx
int geartouse = -1;
for (int i=0; i<7; i++) {
if (speed <= speeds[i][0] && speed > speeds[i][1])
geartouse = i+1;
// Which gear is engaged
int gearengaged = 1*input_a + 2*input_b + 3*input_c + 4*inpud_d + 5*input_e + 5*higear;
if (geartouse == gearengaged) { // Everything ok
gearshift = 0;
wantedgear = gearengaged;
speedratio = speed/speeds[gearenaged-1][0];
} else { // Should change gear
gearshift = 1;
wantedgear = geartouse;
speedratio = speed/speeds[geartouse-1][0];
18 Aug 2018 21:50 - 18 Aug 2018 21:58 #116283
by Hakan
I also want to claim the holiday reason
I think it is the "int" that is wrong, There seems to be no such datatype for hal pins.
Either "s32" or "u32" for signed or unsigned integer.
Chose "s32" so you can have -1 for "no suitable gear found".
Regarding the gear calculation. The one-line way doesn't add any
failure protection. If that is important, you need to expand on that.
Andy's way may be better. You have to see and judge what is important
for you.
for you.
Last edit: 18 Aug 2018 21:58 by Hakan.
19 Aug 2018 05:57 #116288
by tecno
No worries here Håkan, I appreciate all the help I can get. Made some progress now for loop error.
bengt@debian:~/linuxcnc/configs/sim.gmoccapy$ halcompile --install gearbox3.compmake KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
CC [M] /tmp/tmpxFPQ1m/gearbox3.o
gearbox3.comp: In function ‘_’:
gearbox3.comp:39:5: error: ‘for’ loop initial declarations are only allowed in C99 mode
gearbox3.comp:39:5: note: use option -std=c99 or -std=gnu99 to compile your code
gearbox3.comp:45:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
gearbox3.comp:50:33: error: ‘gearenaged’ undeclared (first use in this function)
gearbox3.comp:50:33: note: each undeclared identifier is reported only once for each function it appears in
make[4]: *** [/tmp/tmpxFPQ1m/gearbox3.o] Fel 1
make[3]: *** [_module_/tmp/tmpxFPQ1m] Fel 2
make[2]: *** [sub-make] Fel 2
make[1]: *** [all] Fel 2
make[1]: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
make: *** [modules] Fel 2
19 Aug 2018 06:33 - 19 Aug 2018 06:36 #116290
Replied by rodw on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Its best practice to define variables at the head of the function. The exception might be if you have a low memory environment.
I don't think the halcompile environment likes a definition of the loop variable in the for statement. Also you are mixing types by assigning an int (geartouse) to a long (eg. S32) so try this:
I'm not sure if halcompile will like 1L which signifies 1 is a long type. If it complains, try "(long) 1" instead
OOPS just edited as an explicit typedef is required on the line where speedratio is defined.
FUNCTION(_) {
{ 160.0, 80.0},
{ 270.0, 160.0},
{ 450.0, 270.0},
{ 750.0, 450.0},
{1250.0, 750.0},
{1500.0, 1250.0},
{2500.0, 1500.0},
long geartouse = -1;
int i;
for (i=0; i<7; i++) {
geartouse = (long) i+1L;
int gearengaged = 1*input_a + 2*input_b + 3*input_c + 4*input_d + 5*input_e + 5*higear;
gearshift = 0;
gearshift = 1;
speedratio = speed/speeds[(int)geartouse-1][0];
Last edit: 19 Aug 2018 06:36 by rodw. Reason: OOPS just edited as an explicit typedef is required on the line where speedratio is defined.
Time to create page: 0.360 seconds
