Joining two motors
10 Aug 2020 07:39 #177801
On an inch machine, that setting is fine.
Replied by cmorley on topic 2 motors on one axis
In the ini file there are missing
In the hal file, delete the ....maxerror......=0.005 lines.
- Thank you received: 5935
10 Aug 2020 08:16 #177804
Replied by tommylight on topic 2 motors on one axis
Nice to know, thank you Chris.
- Aldenflorio
- Topic Author
- Thank you received: 13
10 Aug 2020 12:23 - 10 Aug 2020 12:26 #177811
by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
I’m using 2.9. Ok thank you. I’m not good at editing the files but I’ll try and let you know when I get home. Thank you
Last edit: 10 Aug 2020 12:26 by Aldenflorio.
10 Aug 2020 18:18 #177833
ok here try this -replace your old file with this.
- Aldenflorio
- Topic Author
10 Aug 2020 22:07 - 10 Aug 2020 22:53 #177840
by Aldenflorio
Sorry, im kinda having trouble replacing this. I’m not sure if I’m really doing it right. Again I’m not familiar with this so I’m just trying to take what you posted and replace the one in the folder. Do I have to decompress it or something?
Last edit: 10 Aug 2020 22:53 by Aldenflorio.
10 Aug 2020 23:06 #177841
by bevins
Chris is wanting you to replace your ini file with these contents. First copy your <filename>.ini to another name so you can revert back if you have to.
Open Chris's file select all text copy then open your ini file, select all then paste. save and then do your stuff.
Replied by bevins on topic 2 motors on one axis
- Aldenflorio
- Topic Author
10 Aug 2020 23:09 - 10 Aug 2020 23:09 #177842
by Aldenflorio
That’s what I thought. But when I open my ini file it opens as like some terminal and I can’t select all the text or paste
Last edit: 10 Aug 2020 23:09 by Aldenflorio.
10 Aug 2020 23:39 #177844
Here is your compressed files - with the changes
Hopefully that is easier..
11 Aug 2020 06:44 #177867
Could you post your plasma_cutter.pncconf file - I'd like to figure out why it configured wrong.
- Aldenflorio
- Topic Author
11 Aug 2020 08:06 - 11 Aug 2020 08:08 #177869
by Aldenflorio
This is it. but its after i replaced the file you sent. now im getting an error message.
imgur.com/gallery/C5s1iDR
Last edit: 11 Aug 2020 08:08 by Aldenflorio.
Time to create page: 0.172 seconds
