Joining two motors
11 Aug 2020 08:15 #177870
by Clive S
It would be helpful if you post the files directly to the forum as an attachment.
If the forum is saying "unsupported file type" just change the extension to .txt
Replied by Clive S on topic 2 motors on one axis
This is it. but its after i replaced the file you sent. now im getting an error message.
imgur.com/gallery/C5s1iDR
- Aldenflorio
- Topic Author
- Thank you received: 13
11 Aug 2020 08:17 - 11 Aug 2020 08:18 #177871
by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
Is this better?
Last edit: 11 Aug 2020 08:18 by Aldenflorio.
12 Aug 2020 02:30 #177977
Replied by cmorley on topic 2 motors on one axis
The error message mentions it can't connect to the mesa board - couldn't get mac address.
Thanks for the pncconf file
- Aldenflorio
- Topic Author
12 Aug 2020 02:34 - 12 Aug 2020 02:34 #177978
by Aldenflorio
Ah that does make sense. Thank you. I’ll let you know how it works when I plug in the mesa
Last edit: 12 Aug 2020 02:34 by Aldenflorio.
12 Aug 2020 03:43 #177981
I see you didn't select a homing pin for the Z axis. That is why pncconf didn't add the sequence numbers.
I'll have to think about how to handle that better.
- Aldenflorio
- Topic Author
12 Aug 2020 03:57 - 12 Aug 2020 03:57 #177983
by Aldenflorio
Once I plugged in the board it worked. I have limit switches for each axis (4 for the y, 2 for the x, and one for the z) if that changes anything. I know I have to set up a soft limit and use the switches as a hard limit (at least that’s what I think I have to do) but I’m not sure how to do any of that
Last edit: 12 Aug 2020 03:57 by Aldenflorio.
- Aldenflorio
- Topic Author
12 Aug 2020 07:11 #177996
by Aldenflorio
I’m trying to jog the motors so that I can see if they run together, but it won’t let me jog them manually
12 Aug 2020 07:13 #177997
by Clive S
Would it be possible to add a debounce with amount check box for switch in pncconf ?
12 Aug 2020 07:31 #177999
by phillc54
Replied by phillc54 on topic 2 motors on one axis
You cannot jog synchronised joints until they are homed, then you can jog that axis.I’m trying to jog the motors so that I can see if they run together, but it won’t let me jog them manually
- Aldenflorio
- Topic Author
12 Aug 2020 16:53 - 12 Aug 2020 16:53 #178045
by Aldenflorio
Ok, so I have to make a soft limit and use the limit switches as a hard limit right?
Last edit: 12 Aug 2020 16:53 by Aldenflorio.
Time to create page: 0.117 seconds
