Joining two motors
- Aldenflorio
- Topic Author
- Thank you received: 13
15 Aug 2020 17:43 - 15 Aug 2020 17:49 #178309
by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
I will be once I’m finished this. It suggested having the machine fully up and set. Using a proma 150 thc. Yeah I know the floating head doesnt have anything to do with homing
Last edit: 15 Aug 2020 17:49 by Aldenflorio.
- Aldenflorio
- Topic Author
16 Aug 2020 03:40 - 16 Aug 2020 04:02 #178347
by Aldenflorio
It wont let me click anything. so i cant press home all, nor can i toggle the limit switch
Is this for a plasma machine? The Z usually has a switch at the top
Have set this up with pncconf
Might be a good idea to post your hal and ini files
Last edit: 16 Aug 2020 04:02 by Aldenflorio.
16 Aug 2020 06:36 - 16 Aug 2020 06:37 #178358
by Clive S
You don't have any HOME_SEQUENCE = numbers in the ini file
What do you mean by:- " nor can i toggle the limit switch"
I would suggest you use halshow to see if the switches are toggling
Replied by Clive S on topic 2 motors on one axis
Last edit: 16 Aug 2020 06:37 by Clive S.
- Aldenflorio
- Topic Author
16 Aug 2020 10:15 - 16 Aug 2020 10:15 #178376
by Aldenflorio
Sorry I meant e-stop. Oki thought that was strange, but I entered the sequence in the PnCConf Wizard page. Why isn’t it showing up then?
Where would I add it and what exactly would it look like?
Last edit: 16 Aug 2020 10:15 by Aldenflorio.
16 Aug 2020 10:47 #178379
by Clive S
You can add it by editing the ini file using notepad or any text editor but not windows
like this
HOME_SEARCH_VEL = 40
HOME_LATCH_VEL = -2
HOME_FINAL_VEL = 50
HOME_SEQUENCE = -2
HOME_USE_INDEX = False
HOME_IGNORE_LIMITS = True
you will need it for each axis with the correct sequence numbers starting with 0 and -ve the the gantry
like this
HOME_LATCH_VEL = -2
HOME_FINAL_VEL = 50
HOME_SEQUENCE = -2
The following user(s) said Thank You: Aldenflorio
- Aldenflorio
- Topic Author
16 Aug 2020 11:14 - 16 Aug 2020 11:14 #178384
by Aldenflorio
Ok once I’m back at my machine I’ll add the homing sequence. Is there a reason that my PnCConf wizard isn’t creating the ini file right? I’ve had issues like this in the past
Last edit: 16 Aug 2020 11:14 by Aldenflorio.
16 Aug 2020 18:48 #178423
Replied by cmorley on topic 2 motors on one axis
If you don't select homing pins for all axis pncconf doesn't set up home sequence properly.
- Aldenflorio
- Topic Author
17 Aug 2020 01:09 #178442
by Aldenflorio
I’ll be away for 2 weeks so I won’t be able to do anything with the table. Just putting it here so it doesn’t seem like this topic is dead
- Aldenflorio
- Topic Author
31 Aug 2020 19:46 - 31 Aug 2020 19:53 #180213
by Aldenflorio
Replied by Aldenflorio on topic Joining two motors
I’m back. And I’m at a complete loss for what’s going on. I have min and max limit switches for all motors. I have them set up as home as well. I grounded everything but the LEDs on my Mesa 7i96 board light up for the inputs with the switches. They switches are wires as normally opened. When I unconnect the switches though (bc they are no Linux doesn’t know if they are actually connected or not) it should still allow me to home. But I cannot do anything in Linux it just shows me the screen and everything is unclickable
Last edit: 31 Aug 2020 19:53 by Aldenflorio.
31 Aug 2020 20:58 #180233
by Clive S
Replied by Clive S on topic Joining two motors
Can you post your config folder zip
