Joining two motors
- Thank you received: 5935
12 Sep 2020 20:58 #181929
Replied by tommylight on topic Joining two motors
Replied on the other topic.Now I need to incorporate the floating head. How do I do that? When the limit switch is triggered on the floating head it says “Joint 3 on limit switch error” then it stops moving and doesn’t allow me to jog the motors
The following user(s) said Thank You: Aldenflorio
13 Sep 2020 00:30 #181948
You may need
HOME_IGNORE_LIMITS = YES
in your ini file.
Replied by rodw on topic Joining two motors
It give the same error message when it triggers the other limit switches that aren’t part of homing
You may need
in your ini file.
- Aldenflorio
- Topic Author
- Thank you received: 13
13 Sep 2020 00:32 #181949
by Aldenflorio
Replied by Aldenflorio on topic Joining two motors
Its there. thank you though
Time to create page: 0.132 seconds
