GUI Discussion
03 Jan 2012 07:30 #16237 by mhaberler
Replied by mhaberler on topic Re:GUI Discussion
cmorley wrote:
... the labels you are referring to are part of a gladeVCP widget so I cannot change them unless I commit code to EMC (which I might later)
Chris,
I'm not entirely sure this is the case.
I would think that it is possible to import the widgets and customize them by defining a subclass and redefining as needed them before they are displayed. I havent tried this though.
Where's Pavel when we need him ;-)
- Michael
03 Jan 2012 10:41 - 03 Jan 2012 10:42 #16242 by cmorley
Replied by cmorley on topic Re:GUI Discussion
That would be good news.
I guess some experiments then some added docs are in order.
There are a couple other things I have come across for instance LEDs
In Gscreen I'd like to use LEDs as indicators but without HAL pins - I want to set and unset them in the program.
Thinking further I could see a want of LEDs that one can change in the program but wish that they export a HAL pin that follows the LED state.
adding HAL pins as an option: in / out / or none should not be that hard...
gladeVCP is so powerful now - it has grown farther then I imagined when I started it - I'm so glad You guys took it and ran !!
Last edit: 03 Jan 2012 10:42 by cmorley.
03 Jan 2012 10:57 #16244 by andypugh
Replied by andypugh on topic Re:GUI Discussion
cmorley wrote:
This is why for instance EMC has a non standard threading behavior. ( you must calculate the hypotenuse on tapers )
While technically if gives more feature , no machinist is going to think that way !
I am not sure if this is true only of G33 or G76 too. However, I think it is correct behaviour, as G33 is "spindle synchronised motion" not "threading".
One advantage is that you can use it equally well for a scroll as for a thread.
G33.1 is a dedicated threading operation, but in that case it is again a useful feature as (I think) it allows rigid tapping of angled holes. In that situation slaving the feed to the Z axis only could get very expensive.
03 Jan 2012 11:48 - 03 Jan 2012 11:49 #16249 by cmorley
I was speaking of g33 specifically
<rant on>
but you prove my point :) not many machinists think of threading as 'spindle sync motion' it's threading!
On the Okuma I used it could thread longitudinally, scroll or taper wit G33 ( or was it G32?)
It had a few other threading g codes such as variable pitch etc.
I will look it up in the manual when I get time...
ridged tapping is of course different hence the different g code. I've never used a 5 axis machine.
What would have made more sense is have g33 work as standard and have the current behavior as a different g code such as g33.2
Wouldn't it make sense to have the 99% common behavior standard and the 1 % an option?
I can think of little reason one would need the pitch to be parallel to an angle. Parallel to X or Z you bet.
your argument that EMC is correct because we call it 'spindle sync motion" not threading is a programmer or engineers view.
Your not wrong but why would we do that ? :)
<Rant off>
I hope i have not offended any programmers or engineers.
Tradesmen and engineers seldom see exactly eye to eye! Which is probably not all bad..
Chris m
Last edit: 03 Jan 2012 11:49 by cmorley.
03 Jan 2012 13:00 - 03 Jan 2012 14:09 #16252 by BigJohnT
Replied by BigJohnT on topic Re:GUI Discussion
To add to the fire, I wish the G84 canned cycle was official and worked. Maybe we could get someone that knows what their looking at to fix that...
I'm not sure why you would want to use G33.1 for threading unless your doing a taper thread or a fusee or something unusual. I use G76 for threading on the lathe.
Last edit: 03 Jan 2012 14:09 by BigJohnT. Reason: dumbassmistake
03 Jan 2012 14:03 #16253 by andypugh
BigJohnT wrote:
To add to the fire, I wish the G54 canned cycle was official
03 Jan 2012 14:04 #16254 by BigJohnT
According to the manual entry for G84 tapping...
This code is currently unimplemented in EMC2. It is accepted, but the behavior is undefined.
03 Jan 2012 14:07 #16255 by andypugh
OK, I was confused by the way you called it G54 (which I do recall some recent debate about, but works as far as I know)
03 Jan 2012 14:08 #16256 by BigJohnT
I'm more confused than you then lol...
04 Jan 2012 15:41 #16298 by andypugh
Odd:
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...9e2294d91f28;hb=HEAD
Line 236.
The code seems to all be there.
Time to create page: 0.427 seconds
