GUI Discussion
09 Jan 2012 00:11 #16455 by cmorley
Replied by cmorley on topic Re:GUI Discussion
hmm handheld must be pretty damn small - I bet you would need a screen specifically designed for it.
So the feedback I have says every one hates check buttons for the coolant status.
So do I ! I added them cause they were quick while I worked on underlaying code to control them.
i think I would rather LEDs but could make the label toggle different colors..
10 Jan 2012 03:38 - 10 Jan 2012 03:45 #16503 by KPA
Replied by KPA on topic Re:GUI Discussion
BigJohnT wrote:
..Don't know if many people use both mist and flood on a machine... for me it is one or the other so coolant on/off works.
On my bigger machines I'd use both depending on the tool - mist (air) for a lot of my Sandvik coated carbide, flood for everything else. If you flood the high end carbide you get cracks in the cutting edge.
cmorley wrote:
Here is a pic of Gscreen in Redmond theme a little more mainstream.
Damn! ..Very clean!!
My thoughts..
- Tighten up the buttons on the side, you'll need that real-estate for even more buttons!
- every time I see that MV I think Muzzle Velocity :) (as I do rifle building)
- you may want to toggle coolant to "Off / Mist / Flood / Aux" as only one state would be valid at any one time. This is a problem I see in Axis, you could have both mist and flood on at the same time. You may want an AUX coolant toggle as well - It's useful when you setup external high pressure coolant - useful when chambering gun barrels in a lathe. You would setup the Aux to take some M-code.
- have a look at the Centroid Control. They use a very thin line gauge as a load meter on each axis - pretty slick.
- A thought.. you may want to have your function buttons along the bottom, and your page buttons along the side. You may end up with two rows of buttons along the bottom. I see this as emulating the touchpad buttons on commercial controllers.
- Need a tool page! Something of a very simple tool offset setting page. Setting offsets is one area that every new user has trouble with. I take my queue for this from Centroid as well.
- Am I right in assuming your G-Code scroll/edit would be on a separate page?
- Lastly, I think you shouldn't hesitate to use some of the icons from Axis. It will give it the "a member of the family" feel.
Overall a very nice look!
Jay
Last edit: 10 Jan 2012 03:45 by KPA.
10 Jan 2012 12:01 #16516 by BigJohnT
Replied by BigJohnT on topic Re:GUI Discussion
Yea, I have air and flood on the VMC but mist was confusing me into thinking of those little misting units they sell for knee mills.
10 Jan 2012 12:43 #16518 by cncbasher
Replied by cncbasher on topic Re:GUI Discussion
yea definatley a Off / Mist /Flood / and Aux option would be real good as i have a few machines i can use that one
10 Jan 2012 20:36 #16546 by KPA
Right.. Now I've got it. Hmm.. Seems to me I only see flood and mist out there as the usual choices.
Jay
28 Jan 2012 06:52 #17216 by cmorley
I haven't done much on Gscreen lately.
I had to add some code to gladevcp to be able to save g code edits.
So a fairly recent pull is required.
But now you can edit gcode directly. It's still a little clumsy - you must remember to save the changes
or else the gcode on the screen will be different from whats run.
A few other experimental changes to try different controls of the layout...
File Name: gscreen.zip
File Size:43 KB
28 Jan 2012 07:57 #17217 by mhaberler
Replied by mhaberler on topic Re:GUI Discussion
just tried this
mah@ubuntu-10:~/emc2-mw/configs/sim/gscreen$ python gscreen.py
**** Gscreen GLADE ERROR: With xml file: /home/mah/emc2-mw/configs/sim/gscreen/gscreen_test.glade
gscreen_test.glade missing?
-mah
28 Jan 2012 08:26 #17219 by cmorley
Yes I screwup while switching from testing file.
on line 39 of gscreen.py change to:
xmlname = os.path.join(BASE,"gscreen/gscreen.glade")
28 Jan 2012 08:29 #17220 by cmorley
or here its fixed with ability to toggle different views too:
File Name: gscreen-a1...be17.zip
File Size:43 KB
01 Feb 2012 14:27 - 01 Feb 2012 14:29 #17315 by cncbasher
Chris ,
i'm getting gscreen.py line 62 , no module named linuxcnc
am i missing something ?
i'm using latest master , so just wondering if a paths missing etc
due to name changes
Dave
Last edit: 01 Feb 2012 14:29 by cncbasher.
