GUI Discussion
04 Jan 2012 19:16 #16311
by BigJohnT
Replied by BigJohnT on topic Re:GUI Discussion
Looks like mhaberler got it to work (was lacking a bit of code) I've tested it briefly but need to set up a mill sim with spindle feedback for further testing. BTW Andy did you notice the warning in resolver.c? Read back on the developer irc for a possible fix jepler posted.
05 Jan 2012 09:13 #16322
Replied by cmorley on topic Re:GUI Discussion
Ok as promised:
Here is a testing version of Gscreen.
It is _absolutely_ for just checking out the concepts.
Please do not try to run a real machine with this!
it has minimal functionality anyways.
- allhome, unhome
- zero or set, selected axis(s) ( or spindle) of the current system
- spinbox for setting input
- Estop/machine on, combined on a single button
- toggle coolants
- change theme
- toggle the second screen on or off
- display graphics of current loaded program
- display status of the spindle speed, coolants and coordinate system.
- double click the graphics will hide a status screen making the graphics bigger
- display a single line of error message
- Toggle the ABS,REL,DTG display so one is larger
- lotsa buttons that don't do anything:)
As it uses gladeVCP widgets it may not work with 8.04 (I haven't tested it I'm using 10.04)
If you don't have the the blue-joy theme it will look quite different - maybe better? wiki.linuxcnc.org/cgi-bin/emcinfo.pl?GTK_Themes
Currently Gscreen must be run in tandem with another screen.
I suggest running AXIS in simulation. This allows you do test things that Gscreen won't do right now such as load programs or jog.
remember to start a SIMULATED EMC screen (eg. AXIS ) first then
unzip Gscreen somewhere, open a terminal to it, then type: python gscreen.py
play with the screen - double click buttons etc the terminal may give clues to whats happening in the background.
remember we are a conceptual - experimental at this stage
Comments welcome !
Chris M
- allhome, unhome
- toggle coolants
- change theme
Comments welcome !
Chris M
05 Jan 2012 09:28 #16324
by cncbasher
Replied by cncbasher on topic Re:GUI Discussion
ok Chris will give it a go
05 Jan 2012 10:15 #16327
by Rick G
Replied by Rick G on topic Re:GUI Discussion
Hello Chris,
Looks like I'll need to do some downloading to try..
File "gscreen.py", line 27, in <module>
from gladevcp.gladebuilder import GladeBuilder
ImportError: No module named gladevcp.gladebuilder
Rick G
Rick G
05 Jan 2012 11:13 #16328
by cncbasher
looking good Chris , just as i imagined , simple and uncluttered .
i'll certianly be changing to it in due course.
no problems encountered running it either
05 Jan 2012 11:14 #16329
by cncbasher
have you got Glade installed Rick ?
05 Jan 2012 12:12 #16335
Replied by andypugh on topic Re:GUI Discussion
cncbasher wrote:
I can see a reasonable argument for a completely GladeVCP-based GUI to be part of the standard distribution.
Then users can have a totally customisable interface using only the Glade editor (Like Mach3 offers, but also with the Linux-like ability to completely screw things up).
So, thinking that way, what is missing? I think the main thing is probably a pre-defined action-button for loading a file?
05 Jan 2012 12:18 #16337
by BigJohnT
Hi Chris,
When I tried to run the screen I get this error
Am I missing something?
john@zotac:~/emc2/chris/gscreen_test1$ python gscreen.py
06 Jan 2012 01:18 - 06 Jan 2012 01:20 #16368
John Rick - missing dependencies?
I see a list here:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?GladeVcp
and here: (they may be the same)
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ackages_for_gladevcp
Andy there is a file loading widget but i have not figured out how to use it nor how to use the MDI widget...
Chris M
I see a list here:
Chris M
Last edit: 06 Jan 2012 01:20 by cmorley.
06 Jan 2012 12:01 #16376
by Rick G
Hello Chris,
I had tried that but still had error, will have to go back and see.
Although I have Glade installed I never used it before so I will look into that.
Rick G
Rick G
Time to create page: 0.303 seconds
