newbie failed to compile Bitfile
14 Feb 2019 23:48 - 15 Feb 2019 00:11 #126505
by dremeier
newbie failed to compile Bitfile was created by dremeier
Hello Guys,
I received my Mesa-Set:
-7I44 Eight Channel RS-422/485 interface/ RJ45 Breakout
-7I87 Remote isolated Analog input card
-7I47S 8/12 Channel motion oriented RS-422 interface with analog out
-7I90HD Parallel/SPI Anything I/O card
-6I24-25 FPGA based PCI Anything I/O card
I installed ISE Design Suit 14.7 on Debian.
Loaded the sources "fivei24"
Edit the FPGA to xc6slx25-2ftg256
copy a suitable Pin-file, renamed it and edit as follow:
also edit the TopPCIHostMot2.vhd (full as attached)
If I run "Generate Programming File" I got "Process "Generate Programming File" completed successfully" but I´ve a lot of Warnings, I don´t want to ignore. The Warnings also attached.
Does someone has a suggestion how to correct this?
I also don´t understand how to count the Tags I want, StepGens are clear, but for example the sserial states just 01 "(SSerialTag, x"00", ClockLowTag, x"01", SSerialCommand...." but I´ve 8. (I copied from other files with 8 sserial). Maybe somone can explain the lines in the PIN_files.vdh ?
Andre
library IEEE;
use IEEE.std_logic_1164.all; -- defines std_logic types
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Copyright (C) 2007, Peter C. Wallace, Mesa Electronics
-- http://www.mesanet.com
-- edit by Andre Meier
use work.IDROMConst.all;
package PIN_2x7i74s_1x7i44_72_andre is
constant ModuleID : ModuleIDType :=(
(WatchDogTag, x"00", ClockLowTag, x"01", WatchDogTimeAddr&PadT, WatchDogNumRegs, x"00", WatchDogMPBitMask),
(IOPortTag, x"00", ClockLowTag, x"03", PortAddr&PadT, IOPortNumRegs, x"00", IOPortMPBitMask),
(QcountTag, x"02", ClockLowTag, x"08", QcounterAddr&PadT, QCounterNumRegs, x"00", QCounterMPBitMask),
(PWMTag, x"00", ClockHighTag, x"02", PWMValAddr&PadT, PWMNumRegs, x"00", PWMMPBitMask),
(StepGenTag, x"02", ClockLowTag, x"08", StepGenRateAddr&PadT, StepGenNumRegs, x"00", StepGenMPBitMask),
(SSerialTag, x"00", ClockLowTag, x"01", SSerialCommandAddr&PadT, SSerialNumRegs, x"10", SSerialMPBitMask),
(LEDTag, x"00", ClockLowTag, x"01", LEDAddr&PadT, LEDNumRegs, x"00", LEDMPBitMask),
(NullTag, x"00", NullTag, x"00", NullAddr&PadT, x"00", x"00", x"00000000"),
constant PinDesc : PinDescType :=(
-- Base func sec unit sec func sec pin P1 7i47s
IOPortTag & x"00" & StepGenTag & StepGenStepPin, -- I/O 00 TX4
IOPortTag & x"00" & StepGenTag & StepGenDirPin, -- I/O 01 TX5
IOPortTag & x"01" & StepGenTag & StepGenStepPin, -- I/O 02 TX6
IOPortTag & x"01" & StepGenTag & StepGenDirPin, -- I/O 03 TX7
IOPortTag & x"00" & QCountTag & QCountQAPin, -- I/O 04 RX0
IOPortTag & x"02" & QCountTag & QCountQAPin, -- I/O 05
IOPortTag & x"00" & QCountTag & QCountQBPin, -- I/O 06 RX1
IOPortTag & x"02" & QCountTag & QCountQBPin, -- I/O 07
IOPortTag & x"00" & QCountTag & QCountIDXPin, -- I/O 08 RX2
IOPortTag & x"02" & QCountTag & QCountIDXPin, -- I/O 09
IOPortTag & x"01" & QCountTag & QCountQAPin, -- I/O 10
IOPortTag & x"03" & QCountTag & QCountQAPin, -- I/O 11
IOPortTag & x"01" & QCountTag & QCountQBPin, -- I/O 12
IOPortTag & x"03" & QCountTag & QCountQBPin, -- I/O 13
IOPortTag & x"01" & QCountTag & QCountIDXPin, -- I/O 14
IOPortTag & x"03" & QCountTag & QCountIDXPin, -- I/O 15
IOPortTag & x"00" & NullTag & x"00", -- I/O 16 7I47S SPARE ISOLATED OUT
IOPortTag & x"00" & PWMTag & PWMBDirPin, -- I/O 17 7I47S DIRECTION
IOPortTag & x"00" & PWMTag & PWMCEnaPin, -- I/O 18 7I47S PWMENABLE
IOPortTag & x"00" & PWMTag & PWMAOutPin, -- I/O 19 7I47S PWMOUT
IOPortTag & x"02" & StepGenTag & StepGenStepPin, -- I/O 20 TX0
IOPortTag & x"02" & StepGenTag & StepGenDirPin, -- I/O 21 TX1
IOPortTag & x"03" & StepGenTag & StepGenStepPin, -- I/O 22 TX2
IOPortTag & x"03" & StepGenTag & StepGenDirPin, -- I/O 23 TX3
-- P2 7i47s
IOPortTag & x"04" & StepGenTag & StepGenStepPin, -- I/O 00 TX4
IOPortTag & x"04" & StepGenTag & StepGenDirPin, -- I/O 01 TX5
IOPortTag & x"05" & StepGenTag & StepGenStepPin, -- I/O 02 TX6
IOPortTag & x"05" & StepGenTag & StepGenDirPin, -- I/O 03 TX7
IOPortTag & x"04" & QCountTag & QCountQAPin, -- I/O 04 RX0
IOPortTag & x"06" & QCountTag & QCountQAPin, -- I/O 05
IOPortTag & x"04" & QCountTag & QCountQBPin, -- I/O 06 RX1
IOPortTag & x"06" & QCountTag & QCountQBPin, -- I/O 07
IOPortTag & x"04" & QCountTag & QCountIDXPin, -- I/O 08 RX2
IOPortTag & x"04" & QCountTag & QCountIDXPin, -- I/O 09
IOPortTag & x"05" & QCountTag & QCountQAPin, -- I/O 10
IOPortTag & x"07" & QCountTag & QCountQAPin, -- I/O 11
IOPortTag & x"05" & QCountTag & QCountQBPin, -- I/O 12
IOPortTag & x"07" & QCountTag & QCountQBPin, -- I/O 13
IOPortTag & x"05" & QCountTag & QCountIDXPin, -- I/O 14
IOPortTag & x"07" & QCountTag & QCountIDXPin, -- I/O 15
IOPortTag & x"01" & PWMTag & PWMBDirPin, -- I/O 17 7I47S DIRECTION
IOPortTag & x"01" & PWMTag & PWMCEnaPin, -- I/O 18 7I47S PWMENABLE
IOPortTag & x"01" & PWMTag & PWMAOutPin, -- I/O 19 7I47S PWMOUT
IOPortTag & x"06" & StepGenTag & StepGenStepPin, -- I/O 20 TX0
IOPortTag & x"06" & StepGenTag & StepGenDirPin, -- I/O 21 TX1
IOPortTag & x"07" & StepGenTag & StepGenStepPin, -- I/O 22 TX2
IOPortTag & x"07" & StepGenTag & StepGenDirPin, -- I/O 23 TX3
-- P3 7i44 8x sserial
IOPortTag & x"00" & SSerialTag & SSerialRX0Pin, -- I/O 48
IOPortTag & x"00" & SSerialTag & SSerialRX1Pin, -- I/O 49
IOPortTag & x"00" & SSerialTag & SSerialRX2Pin, -- I/O 50
IOPortTag & x"00" & SSerialTag & SSerialRX3Pin, -- I/O 51
IOPortTag & x"00" & SSerialTag & SSerialTX0Pin, -- I/O 52
IOPortTag & x"00" & SSerialTag & SSerialTXEn0Pin, -- I/O 53
IOPortTag & x"00" & SSerialTag & SSerialTX1Pin, -- I/O 54
IOPortTag & x"00" & SSerialTag & SSerialTXEn1Pin, -- I/O 55
IOPortTag & x"00" & SSerialTag & SSerialTX2Pin, -- I/O 56
IOPortTag & x"00" & SSerialTag & SSerialTXEn2Pin, -- I/O 57
IOPortTag & x"00" & SSerialTag & SSerialTX3Pin, -- I/O 58
IOPortTag & x"00" & SSerialTag & SSerialTXEn3Pin, -- I/O 59
IOPortTag & x"00" & SSerialTag & SSerialRX4Pin, -- I/O 60
IOPortTag & x"00" & SSerialTag & SSerialRX5Pin, -- I/O 61
IOPortTag & x"00" & SSerialTag & SSerialRX6Pin, -- I/O 62
IOPortTag & x"00" & SSerialTag & SSerialRX7Pin, -- I/O 63
IOPortTag & x"00" & SSerialTag & SSerialTX4Pin, -- I/O 64
IOPortTag & x"00" & SSerialTag & SSerialTXEn4Pin, -- I/O 65
IOPortTag & x"00" & SSerialTag & SSerialTX5Pin, -- I/O 66
IOPortTag & x"00" & SSerialTag & SSerialTXEn5Pin, -- I/O 67
IOPortTag & x"00" & SSerialTag & SSerialTX6Pin, -- I/O 68
IOPortTag & x"00" & SSerialTag & SSerialTXEn6Pin, -- I/O 69
IOPortTag & x"00" & SSerialTag & SSerialTX7Pin, -- I/O 70
IOPortTag & x"00" & SSerialTag & SSerialTXEn7Pin, -- I/O 71
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin, -- added for IDROM v3
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin);
end package PIN_2x7i74s_1x7i44_72_andre;
Attachment not found
--use work.@Card@.all;
--use work.i25_x9card.all; -- needs 5i25.ucf and SP6 x9 144 pin
--use work.i74_x9card.all; -- needs 4I74.ucf and SP6 x9 144 pin
--use work.Sixi25_x9card.all; -- needs 5i25.ucf and SP6 x9 144 pin
--use work.i24_x16card.all; -- needs 5I24.ucf and SP6 x16 256 pin
use work.i24_x25card.all; -- needs 5I24.ucf and SP6 x25 256 pin
-------------------- select (or add) one pinout -----------------------
--use work.@Pin@.all;
use work.PIN_2x7i74s_1x7i44_72_andre.all;
-- 34 I/O pinouts for 5I25, 5I26 and 6I25:
Andre
Last edit: 15 Feb 2019 00:11 by dremeier.
15 Feb 2019 00:23 - 15 Feb 2019 00:54 #126508
Replied by PCW on topic newbie failed to compile Bitfile
1. Its not possible to get rid of all warnings (you can do a lot of work and _change_ the warnings somewhat if you like)
2. Sserial modules have 1 to 8 channels each (there can be a maximum of 4 sserial modules in a configuration)
3. The module ID fields are as follows:
type ModuleRecord is -- probably need an alternate way for smart modules
record
GTag : std_logic_vector(7 downto 0);
Version : std_logic_vector(7 downto 0);
Clock : std_logic_vector(7 downto 0);
NumInstances : std_logic_vector(7 downto 0);
BaseAddr : std_logic_vector(15 downto 0);
NumRegisters : std_logic_vector(7 downto 0);
Strides : std_logic_vector(7 downto 0);
MultRegs : std_logic_vector(31 downto 0);
end record;
record
end record;
Last edit: 15 Feb 2019 00:54 by PCW.
The following user(s) said Thank You: dremeier
15 Feb 2019 00:41 #126512
by dremeier
Replied by dremeier on topic newbie failed to compile Bitfile
Thanks PCW,
So I can give the bitfile a try.
nevertheless, are you performing a bitfile for me? I wrote you a email(order nr. 5142)
I don´t trust my file.
15 Feb 2019 11:06 #126532
by dremeier
In wich file I have to put this ^^ in?
record
end record;
15 Feb 2019 15:28 #126556
That is already part of the source
(in IDROMConsts.vhd)
I can build that bitfile if you like, it woudl save some time if you sent me the PIN_XXX file
15 Feb 2019 16:26 #126567
by dremeier
Here the Pin File:
I´will have a look an your sources to figure out my mistakes.
Thanks a lot
Thanks a lot
20 Feb 2019 07:50 #126807
by dremeier
please, can I remind you to build an bitfile for me?
Thanks in advanced
Thanks in advanced
20 Feb 2019 16:12 #126823
21 Feb 2019 10:31 #126855
by dremeier
Ok, thank you
did you changes in the IDROMConsts.vhd or anywhere else?
What is wrong withe the name?
21 Feb 2019 12:56 #126856
No, no changes anywhere but the PIN_XXX file and the top level file to add the pin file
(just changed the file/package name from 2X7I74S_7I44 to 2X7I47S_7I44 which doesn't affect the bitfile)
Time to create page: 0.094 seconds
