Ethercat installation from repositories - how to step by step
- marq_torque
23 Sep 2023 13:34 #281473
by marq_torque
Replied by marq_torque on topic Ethercat installation from repositories - how to step by step
I wasn't knowing about this repos, I tried to download ISO in first post link is not working..., I installed Debian 12 from this link
chuangtzu.ftp.acc.umu.se/debian-cd/curre...2.1.0-amd64-xfce.iso
- marq_torque
25 Sep 2023 12:17 #281593
by marq_torque
Hey Rodw,
Can you guide me how to setup repos manually? I'm clueless
- marq_torque
25 Sep 2023 16:27 #281602
by marq_torque
Ok, ISO link in first step is broken so I followed spoiler steps and I'm at here now
$ wget -O- build.opensuse.org/projects/science:Ethe...ys/download?kind=gpg | gpg --dearmor | sudo dd of=/usr/local/share/keyrings/science_EtherLab.gpg
bash: wget: command not found
gpg: no valid OpenPGP data found.
0+0 records in
0+0 records out
0 bytes copied, 3.5656e-05 s, 0.0 kB/s
0+0 records in
0+0 records out
25 Sep 2023 19:20 #281607
Replied by rodw on topic Ethercat installation from repositories - how to step by step
sudo apt install wget
Revised download link: drive.google.com/file/d/1s2Te9JtXxb8yB9r.../view?usp=drive_link
- marq_torque
27 Sep 2023 18:29 #281729
by marq_torque
I did download and fresh install from the last link, Followed steps in first post .... I'm lost here
[sudo] password for vcam:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ethercat-dkms : Depends: libtool but it is not installable
Depends: autoconf but it is not installable
Depends: automake but it is not installable
E: Unable to correct problems, you have held broken packages.
27 Sep 2023 20:30 #281738
We do not preinstall ethercat
try:sudo apt update
sudo apt upgrade
sudo apt install -y linux-headers-$(uname -r)
sudo apt install ethercat-master libethercat-dev
You will also need to install the linux ethercat driver as per the first post.
try:sudo apt update
sudo apt upgrade
- marq_torque
28 Sep 2023 04:29 #281767
by marq_torque
Oh okay, I'll follow the instructions and share the progress.
Thanks Rodw
Thanks Rodw
18 Oct 2023 23:00 #283261
by eduard
Replied by eduard on topic Ethercat installation from repositories - how to step by step
Hi Rod,
prevoiusly I istalled LCNC booted from USB stick, but with this file, not booting up? Did you have any suggestions? I write it with etcher, like previously.
Thanks.
Thanks.
19 Oct 2023 03:38 #283270
have you set the boot order in the BIOS so that it tries the usb stick first.
You have not given us any useful information about what is happening.
Also what hardware?
Also what hardware?
19 Oct 2023 08:26 #283284
by eduard
Yes, you are right. I thought the problem is mutch simpler.
So, I have a mintbox mini, linux pc which has UEFI bios and can boot in uefi, legacy and dual mode. I set dual, and foot from usb drive.
The regular LCNC image written by etcher booting fine from the same usb stick, and the ethercat version can not, with very same process and parameters.
Time to create page: 0.257 seconds
