26 Mar 2013 18:51 - 26 Mar 2013 21:33 #31907
by tjamscad
Replied by tjamscad on topic Gmoccapy - A new screen for linuxcnc
I found build comming up short when I tried it also. I recomend building from source. I have done this and Gmoccapy works just fine. Here is my in stall script, it builds a simulator and works in 12.04 and 10.04. Just edit out what you dont need but, it will install and Gmoccapy works as intended. Make sure you set the permissions to run as program.
Last edit: 26 Mar 2013 21:33 by tjamscad.
26 Mar 2013 19:40 #31908
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Have you forgotten to add the install script?
I think it would be a good Idea to include your script in the WIKI page.
Norbert
Norbert
The following user(s) said Thank You: tjamscad
26 Mar 2013 21:25 #31921
by bjames28
Replied by bjames28 on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert,
Thanks for the explanation. I see that compiling from source is the safe way right now. I hope though that soon the buildbot version will be available. I'll also try the HAL examples and MPG, thanks for the hint.
The Wiki is great help.
BTW: on wiki the screenshot says "spindel" and "Zurücksetzen". Can you translate it?
26 Mar 2013 21:33 - 26 Mar 2013 22:02 #31923
by tjamscad
Norbert,
Yes, the forum doesn't like scripts i forgot that.
Norbert
Norbert,
Last edit: 26 Mar 2013 22:02 by tjamscad.
26 Mar 2013 23:10 #31929
by newbynobi
In my glade file the button is called clear and because of my local settings it is automatically translated to "Zurücksetzen", I know that this is ugly and wrong translated, but at the moment I believe the most important is more documentation.
At a first step, I changed "spindel" to "Spindle" and the button lost its text and got an icon.
I will replace the images in a minute or so.
BTW: How can I upload images to the WIKI? At the moment I link to my own server.
@tjamscad
Wow, what a long script. I will see to include it to the WIKI later on, or may be I make a shorter one based on the live CD.
@tjamscad
27 Mar 2013 00:00 #31934
by tjamscad
Yes, it is but from a fresh install of either 10.04 or 12.04 it works right out of the gate and you dont do anything but start it.
@tjamscad
27 Mar 2013 01:58 - 27 Mar 2013 02:00 #31936
by newbynobi
The WIKI for gmoccapy is nearly finshed, please take a look and tell me what you miss!
gmoccapy wiki
OK, the videos in English are next to do!
Norbert
gmoccapy wiki
Norbert
Last edit: 27 Mar 2013 02:00 by newbynobi.
The following user(s) said Thank You: bjames28
27 Mar 2013 02:45 #31937
by bjames28
Hi Norbert,
Lots of useful information on wiki. Great!!
Thanks!
Thanks!
27 Mar 2013 02:47 #31938
by bjames28
Hi tjamscad
Your script works well.
27 Mar 2013 04:08 #31941
by tjamscad
Thanks, I guess that means you have it running and everything loaded up right?
Hi tjamscad
Time to create page: 0.316 seconds
