NativeCam Embedded in Debian Buster 10 no luck
23 Jan 2021 11:31 #196326
by skrap58
NativeCam Embedded in Debian Buster 10 no luck was created by skrap58
Hello,
I have used the .iso to install linuxcnc 2.8 in Virtualbox and I have also install NativeCAM and can get it to run stand alone. I am having a hard time getting it embedded with a tab in Axis. I would like to be able to design projects in Nativecam on vbox and then take the projects to my machine to run. I have tried the following command in my ini;
EMBED_TAB_COMMAND = gladevcp -x {XID} -U --catalog=mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui
with no luck. I have tried everything I could find in the forum and via search engines.
I have attached the terminal output and my .ini file.
Any help is always appreciated.
BIll
File Name: terminalouput.txt
File Size:2 KB
File Name: my-mill_20...1-22.ini
File Size:3 KB
Terminal output
wwp@wwp:~$ linuxcnc
LINUXCNC - 2.8.0
Machine configuration directory is '/home/wwp/linuxcnc/configs/NativeCAM-master/configs/sim/axis/ncam_demo.2.8'
Machine configuration file is 'mill.ini'
Starting LinuxCNC...
emc/iotask/ioControl.cc 702: can't load tool table.
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Note: Using POSIX realtime
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
note: MAXV max: 1.500 units/sec 90.000 units/min
note: LJOG max: 1.500 units/sec 90.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
(gladevcp:1531): libglade-WARNING **: 13:51:22.708: could not find glade file 'ncam.ui'
**** GLADE VCP ERROR: With xml file: ncam.ui : could not create GladeXML object
<commandline>:0: gladevcp exited without becoming ready
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x 48234638 -U --catalog=mill ncam.ui" exited with error: 1
task: 2772 cycles, min=0.000066, max=0.008623, avg=0.001142, 0 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/wwp/linuxcnc_debug.txt
and
/home/wwp/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
wwp@wwp:~$
ini file
# This config file was created 2021-01-22 08:16:22.478640 by the update_ini script
# The original config files may be found in the /home/wwp/linuxcnc/configs/my-mill/my-mill.old.old directory
# Generated by stepconf 1.1 at Mon May 21 18:39:02 2018
# overwritten when you run stepconf again
[EMC]
# The version string for this INI file.
VERSION = 1.1
MACHINE = my-mill
DEBUG = 0
[DISPLAY]
# required NativeCAM item :
NCAM_DIR = ncam
EMBED_TAB_NAME = NativeCAM
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 2.5
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 25.00
INTRO_TIME = 5
PROGRAM_PREFIX = ncam/scripts/
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[RS274NGC]
SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 47000
SERVO_PERIOD = 1000000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[HAL]
HALUI = halui
HALFILE = my-mill.hal
HALFILE = custom.hal
[HALUI]
# add halui MDI commands here (max 64)
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 0.50
MAX_LINEAR_VELOCITY = 5.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[KINS]
KINEMATICS = trivkins coordinates=XYZ
#This is a best-guess at the number of joints, it should be checked
JOINTS = 3
[AXIS_X]
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
MAX_VELOCITY = .95
MAX_ACCELERATION = 30.0
[JOINT_0]
AXIS_0]
TYPE = LINEAR
HOME = 0.1
MAX_VELOCITY = .95
STEPGEN_MAXACCEL = 37.5
SCALE =5200
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
HOME_OFFSET = 0.1
[AXIS_Y]
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
MAX_VELOCITY = .95
[JOINT_1]
TYPE = LINEAR
HOME = 0.1
MAX_VELOCITY = .95
SCALE = 5200
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
HOME_OFFSET = 0.1
[AXIS_Z]
MIN_LIMIT = -4.0
MAX_LIMIT = 0..01
MAX_VELOCITY = .95
[JOINT_2]
TYPE = LINEAR
HOME = 0.1
MAX_VELOCITY = .95
SCALE = 5200
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -4.0
MAX_LIMIT = 0..01
HOME_OFFSET = 0.1
BIll
File Size:2 KB
File Size:3 KB
Terminal output
wwp@wwp:~$ linuxcnc
LINUXCNC - 2.8.0
and
wwp@wwp:~$
ini file
[EMC]
VERSION = 1.1
MACHINE = my-mill
DEBUG = 0
[DISPLAY]
NCAM_DIR = ncam
DISPLAY = axis
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[FILTER]
py = python
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 47000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[HAL]
HALUI = halui
[HALUI]
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[KINS]
JOINTS = 3
[AXIS_X]
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
MAX_VELOCITY = .95
[JOINT_0]
AXIS_0]
TYPE = LINEAR
HOME = 0.1
MAX_VELOCITY = .95
SCALE =5200
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
HOME_OFFSET = 0.1
[AXIS_Y]
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
MAX_VELOCITY = .95
[JOINT_1]
TYPE = LINEAR
HOME = 0.1
MAX_VELOCITY = .95
SCALE = 5200
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = 0.0
MAX_LIMIT = 22.0
HOME_OFFSET = 0.1
[AXIS_Z]
MIN_LIMIT = -4.0
MAX_LIMIT = 0..01
MAX_VELOCITY = .95
[JOINT_2]
TYPE = LINEAR
HOME = 0.1
MAX_VELOCITY = .95
SCALE = 5200
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -4.0
MAX_LIMIT = 0..01
HOME_OFFSET = 0.1
- Thank you received: 5959
23 Jan 2021 12:03 #196329
Replied by tommylight on topic NativeCam Embedded in Debian Buster 10 no luck
Really ????????
forum.linuxcnc.org/nativecam/41237-nativ...an-buster-10-no-luck
forum.linuxcnc.org/38-general-linuxcnc-q...an-buster-10-no-luck
forum.linuxcnc.org/nativecam/38972-nativ...sim-axis-not-working
Two of them have the same exact title!
23 Jan 2021 12:05 #196330
Here is everything regarding NativeCAM on the net:
www.google.com/search?source=hp&ei=zxAMY...XKDYUQ4dUDCAY&uact=5
23 Jan 2021 14:11 #196334
by skrap58
Replied by skrap58 on topic NativeCam Embedded in Debian Buster 10 no luck
Thank you for your reply tommylight.
All of those posts are mine.
23 Jan 2021 16:51 #196344
by skrap58
solve by starting over and following this post
forum.linuxcnc.org/nativecam/33573-nativecam-as-embedded-tab
