Arc OK intermitent issues on torch fire
05 Apr 2021 18:02 #204929
by txtrone
Just so I am clear. The 'derived' ArcOk is from a plasma source with ArcOk output, and the 'reed version' is the 'synthesized' method?
When you say the reed version has no way of failing 'if it is done right' ... what are 'wrong' ways you see it done? Also, does it need any tweaking?
Replied by txtrone on topic Arc OK intermitent issues on torch fire
The derived arcok from THCAD works perfectly although i am sure there might be situations where it might fail but not due the the way it works but due to how plasma sources work.
The reed version has no way of failing if done right as it relies on a big amount of current passing through that wire.
By now i have 4 machines using the derived arcok from thcad and they never failed, but that needs a bit of tweaking...
05 Apr 2021 18:14 #204931
by txtrone
Synthesized = reed relay method?
I have NO issues at all with synthesised ArcOK.
- Thank you received: 5934
05 Apr 2021 20:25 #204954
Replied by tommylight on topic Arc OK intermitent issues on torch fire
Synthesized = derived = from THACD so no reed or plasma's own ARCOK signal.
It is synthesized or derived from the voltage measured with THCAD and generates the (missing) arcok signal if the voltage is between the setpoints set as "OK High Volts" and "OK Low Volts" in PlasmaC.
The following user(s) said Thank You: txtrone
05 Apr 2021 20:38 #204962
by txtrone
Thanks for the explanation tommylight. Sometimes the simplest solutions are the best.
I already have ArcOk wired from my CPC port, so I will go that route for now. It's good to know that other options exist.
16 Jun 2021 11:59 #212194
by Talon2006
Replied by Talon2006 on topic Arc OK intermitent issues on torch fire
I was having this same issue, and putting in a relay is what solved my issue ultimately.
No amount of denouncing the arc ok, or configure changes helped my problem. It wasn’t a matter of the program getting the arc ok, it was a matter of the hypertherm not getting a “strong” enough signal to trigger the arc.
Time to create page: 0.191 seconds
