Arc OK intermitent issues on torch fire
23 Dec 2020 10:33 #192945
by luftlupus
Replied by luftlupus on topic Arc OK intermitent issues on torch fire
Will do tomorrow cheers.Aha, so no need to worry about the transfer side yet.
Disconnect the plasma machine cnc port from the controller and short out pins 3 & 4, that should turn the torch on.
- Thank you received: 5934
23 Dec 2020 10:53 #192949
If the plasma turns the air on but does not fire, that is a plasma issue, not a relay issue.
Replied by tommylight on topic Arc OK intermitent issues on torch fire
Check the plasma as Phill said in the last post, stop wasting time checking ARCOK and relays while there is no way of getting it since the plasma is not cutting anything.na no pilot arc or anything i am assuming the relay is gone at this stage. it tries to fire but no arc of course just air.
The following user(s) said Thank You: luftlupus
23 Dec 2020 11:29 #192951
by phillc54
Replied by phillc54 on topic Arc OK intermitent issues on torch fire
Tom's post reminded me to say you should check that your air pressure is within specs as well.Will do tomorrow cheers.
The following user(s) said Thank You: tommylight, luftlupus
- snowgoer540
- Thank you received: 746
23 Dec 2020 11:36 #192952
by snowgoer540
Well, at least it's not a transfer-relay issue.
This is the exact problem (there's a video of it earlier in the thread) I had trying to use a SSR for "torch-on", rather than a mechanical relay. Changing relay types solved my "only air" problem.
I really hope it's his problem at this point as well, because it's easy to fix.
Replied by snowgoer540 on topic Arc OK intermitent issues on torch fire
23 Dec 2020 15:54 #192978
I read everything on this forum, so at times it is hard to follow everything exactly, but lately the "relay" issue has been raised to "nuclear" levels !
I never had issues with relays, ever, when low current is concerned as i am sure i used 3A up to 40A to turn on the plasma's, used 3A to 30A for ARCOK. Until lately most of them were old used relays. Not a single issue, ever!
SSR is a different beast, it is a semiconductor so might cause issues.
In general, if the plasma is turning on the air but there is no pilot arc or no cutting, check the air pressure as the first thing, it might have enough pressure while the valve is closed so the plasma will start, and that pressure will go down when the valve opens restricting the plasma from firing. The pressure for normal Plasma sources should be 5 to 5.5 BAR while the air is running through the nozzle, not while the air is shut off.
23 Dec 2020 15:55 #192979
Your post reminded me about chasing the wrong rabbit here !
- snowgoer540
23 Dec 2020 18:23 #192995
by snowgoer540
I agree there is way too much discussion on relays. You could say that I came here to relay that I agree
I only butted in because he IS using an SSR to turn the torch on, and I saw the exact same thing (with a Hypertherm of all brands) when I was turning the torch on the same way. For some reason that I don't understand, it was not pulled in enough to start whatever it is that starts the pilot arc. To further compound the curious nature of it, having hte ground clamp near the torch affected the strength of the pilot arc when I was using the SSR. Now that it's a regular old trusty dusty relay, pilot arc 100% of the time.
Really I'm not trying to upset anyone, I'm just tryin to be helpful, and I want to see the fella's table work...reliably.
23 Dec 2020 19:04 #193005
I just feel sorry for the new members of this forum coming here to seek help and finding more than they bargained for. The main thing is to help them make the machine work as the first and foremost, then advise on improvements and features and ..... bells and whistles?
LOL
If i did imply this in any way shape or form, sorry that was not my intention.Really I'm not trying to upset anyone, I'm just tryin to be helpful, and I want to see the fella's table work...reliably.
- snowgoer540
23 Dec 2020 21:16 #193026
by snowgoer540
mmmmmm.... bells and whistles... (Homer Simpson voice)
bells and whistles?
23 Dec 2020 22:58 - 23 Dec 2020 23:04 #193037
by luftlupus
Also thanks for everyone's help and input, I feel bad for not knowing all the electrical side of things.
So checked the air pressure that's within spec, then disconnected the CNC port and shorted the start pins but again no arc just air.
Last edit: 23 Dec 2020 23:04 by luftlupus.
Time to create page: 0.116 seconds
